Timer event handler problem
Dear all,
I just writing a little piece of code (no softdevice, using sdk 17.00), that in theory toggle a led based on 2 compare (CC[0] and CC[1]).
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup nrf_dev_timer_example_main main.c
 * @ingroup nrf_dev_timer_example
 * @brief Timer Example Application main file.
 * This file contains the source code for a sample application using Timer0.
#include <stdbool.h>
#include <stdint.h>
#include "nrf.h"
#include "nrf_drv_timer.h"
#include "bsp.h"
#include "app_error.h"
// Mettendo lo 0 nella macro, sto settando il compare = 0
const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(4);
const nrf_drv_timer_t TIMER_TIMESTAMP = NRF_DRV_TIMER_INSTANCE(2);
void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context)
  switch(event_type)
    case NRF_TIMER_EVENT_COMPARE0:
       TIMER_TIMESTAMP.p_reg->TASKS_CAPTURE[0] = 1;
       printf("ON: %d\n", TIMER_TIMESTAMP.p_reg->CC[0]);
       bsp_board_led_on(BSP_BOARD_LED_0);
    case NRF_TIMER_EVENT_COMPARE1:
       printf("OFF: %d\n", TIMER_TIMESTAMP.p_reg->CC[0]);
      bsp_board_led_off(BSP_BOARD_LED_0);
      TIMER_LED.p_reg->TASKS_STOP = 1;
void timer_timestamp_event_handler(nrf_timer_event_t event_type, void* p_context)
static void timer_init()
  ret_code_t err_code;
  timer_cfg.bit_width = NRF_TIMER_BIT_WIDTH_8;
  timer_cfg.frequency = NRF_TIMER_FREQ_31250Hz;
  err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer_led_event_handler);
  // Setting compare
  TIMER_LED.p_reg->CC[0] = 10; // 320 us
  TIMER_LED.p_reg->INTENSET = 0x1UL << 16UL;
  TIMER_LED.p_reg->CC[1] = 40;  //1280 us
  TIMER_LED.p_reg->INTENSET = 0x1UL << 16UL+1;
  // Timer timestamp
  timer_cfg.frequency = NRF_TIMER_FREQ_1MHz;
  err_code = nrf_drv_timer_init(&TIMER_TIMESTAMP, &timer_cfg, timer_timestamp_event_handler);
  // Starting timer
  TIMER_TIMESTAMP.p_reg->TASKS_START = 1;
  TIMER_LED.p_reg->TASKS_START = 1;
    timer_init();
    while (1)
        __WFI();
The strange thing is that, if the 2 compare are pretty high (1 second or more) there is no problem, while if the values are low, something strange happened:
1) Why isn't the timer stopped instantly? (but it needs two cycles)
2) Why are the timestamps not correct? (I expected that OFF - ON = 960)
Thanks to everyone,
Elia
  • Hi Elia,
    Since you are handling the stopping of the timer in the interrupt handler, the CPU requires some time to wakeup and call the interrupt handler when the interrupt is generated. Since you have configured the timer with only 8-bits width, it will overflow when the internal counter reaches 255. This will happen after ~8 ms, which means that the CPU should have plenty of time to handle the interrupt before this if nothing it blocking the handling of the interrupt. I tested your code on my DK, but I'm not able to reproduce any of the issues you are listing. This is the output from my run:
    <info> app: ON: 322
    <info> app: OFF: 1282
    I'm not sure how you have implemented the printf statements, but could these slow down the application and cause this behavior?
    As you can see above, I'm seeing a delta of exactly 960 in my run. Again, I believe that something must be slowing down your code, causing this.
    I have attached my test-project. Can you have a run with this and see what values it is giving you? 4578.timer_cc.zip
    It is possible to configure PPI to trigger the STOP and CAPTURE tasks in hardware when the events are generated. This would prevent you from relaying on constant interrupt latency for giving correct results.
    Jørgen
  • Dear Jorgen,
    Unfortunately nothing is print on the Debug terminal: why??
    Elia
  • Are you running the code on a nRF52840 DK? It is outputting the log on the Debug Terminal when I run it. Which version of Segger Embedded Studio are you using? I tested this on v4.50.
    If not, try using Segger J-Link RTT Viewer directly.
  • Ok, I manage to print the log on debug terminal and in fact now it's working as expected (the log are the same as you): so thank you! From now on, I will use NRF_LOG_INFO instead of printf.
    Elia
