nRF52840 SDK16 - Passing unique ID DEVICEID in advertising data
Hi everyone,
I want instead of MAC address to advertise my device using its 64bit unique ID. What I am considering, is to use the p_data array for that purpose and more specific to advertise using scan responce format as follows
ble_advertising_init_t init;
uint8_t uniqueID[]={01,02,03,04,05,06,07,08};
init.srdata.p_manuf_specific_data->data.size = sizeof(uniqueID) / sizeof(uniqueID[0]);
init.srdata.p_manuf_specific_data->data.p_data = uniqueID;
My problem is that it isn't work.. I do not see the uniqueID while advertising
So my questions are:
1. Is it possible and wise to advertise the unique ID?
2. What it the best method of doing this?
Thanks in advance
Nick
  • I don't see any obvious errors from the short code snippet, are you getting any error code? Have you tried to do this change in for instance the \ble_app_blinky example which for instance are using scan response data?
    Also make sure that you set manuf_data.company_identifier before calling ble_advdata_encode().
    Kenneth
  • Hi Kenneth and thank you for your responce,
    I've just saw the \ble_app_blinky example and I realized that the structure of my advertising_init() function differs. However, is similar with the \ble_app_hrs example
    The \ble_app_blinky example uses the ble_advdata_encode & sd_ble_gap_adv_set_configure functions, while \ble_app_hrs example uses the ble_advertising_init & ble_advertising_conn_cfg_tag_set to setup the advertising_init
    Could you provide me some clarifications?
    This is my advertising_init() function. Should I follow the blinky example?
    static void advertising_init(void) {
      ret_code_t err_code;
      ble_advertising_init_t init; // configuration structure
      uint8_t uniqueID[]={01,02,03};
      init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
      init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
      init.advdata.uuids_complete.uuid_cnt = 1;
      init.advdata.uuids_complete.p_uuids = &m_adv_uuids[0];
      init.config.ble_adv_fast_enabled = true;
      init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
    Nick
    You can choose either. It's just two different engineers making each example. One is using a ble advertising module to setup the advertisement, while the other is using the softdevice api directly.
    If you open the ble_app_hids_mouse example you can for instance see how it is setting up manufacturer packet in the advertisement by searching for SWIFT_PAIR_SUPPORTED in main.c
    Kenneth
  • Thank you Kenneth,
    I will also try the softdevice API and will look the ble_app_hids_mouse example and will return with a feedback.
    In the meanwhile, can you spot any error with my advertising_init funciton that prevents from advertising scan responce data?
  • Based on the ble_app_hids_mouse example I figured out how to implement it. Thanks a lot!!
