Need support for RSA crypto algorithm for Digital Signature
Hi Team,
For our development we are using the nRF52840 soc, We need the some example code or some project which will explains the Usage of RSA algorithm and supported API's for Digital Signature generation and Verification.
Currently we have Crypto backend (CC310, uECC, Oberon, mbed TLS) examples programs which is covering the ECC(ECDSA, ECDH) with supported ECC Curves. We need the some example code which supports the RSA.
It would be more helpful to us if we have any reference projest on RSA.
Srinivas.V
    The only RSA example in the nRF5 SDK is the RSA CryptoCell integration test (<nRF5 SDK>\examples\crypto\nrf_cc310\rsa\).
  • Hi Einar,
    Thanks for your reply.
    we have taken the code base from the "SDK>\examples\crypto\nrf_cc310\rsa", and ported into my application.
    After porting the code we are seeing some weird behaviour in some of the API's.
    The API's which are calculating the HASH as part of the API itself are not working and for the API's which are taking SHA Digest value as external are working fine.
    Not Working API's, we are getting the error code like 0x00F00441
    1. CRYS_RSA_PSS_Sign(rndState_ptr, rndGenerateVectFunc, UserContext_ptr,UserPrivKey_ptr,hashFunc,MGF,SaltLen,DataIn_ptr,DataInSize,Output_ptr,OutputSize_ptr)
    CRYS_RSA_PSS_Verify(UserContext_ptr,UserPubKey_ptr,hashFunc,MGF,SaltLen,DataIn_ptr,DataInSize,Sig_ptr)
    2. CRYS_RSA_PKCS1v15_Sign(rndState_ptr, rndGenerateVectFunc, UserContext_ptr,UserPrivKey_ptr,hashFunc,DataIn_ptr,DataInSize,Output_ptr,OutputSize_ptr)
    CRYS_RSA_PKCS1v15_Verify(UserContext_ptr,UserPubKey_ptr,hashFunc,DataIn_ptr,DataInSize,Sig_ptr)
    Working API's:
    1. CRYS_RSA_PKCS1v15_SHA256_Sign(rndState_ptr, rndGenerateVectFunc, UserContext_ptr,UserPrivKey_ptr,DataIn_ptr,Output_ptr,OutputSize_ptr)
    CRYS_RSA_PKCS1v15_SHA256_Verify(UserContext_ptr,UserPubKey_ptr,DataIn_ptr,Sig_ptr)
    2. CRYS_RSA_PSS_SHA1_Sign(rndState_ptr, rndGenerateVectFunc, UserContext_ptr,UserPrivKey_ptr,MGF,SaltLen,DataIn_ptr,Output_ptr,OutputSize_ptr)
    CRYS_RSA_PSS_SHA1_Verify(UserContext_ptr,UserPubKey_ptr,MGF,SaltLen,DataIn_ptr,Sig_ptr)
    we have taken the reference code from example project only.
    Is there any additional settings required in "sdk_config.h"  file related to SHA calculation or any other settings required to make it work for other API's.
    In example project i seen in one of the API we are sending the wrong argument like,
    CRYS_RSA_PKCS1v15_SHA512_Sign() , we are sending the "rsaSignVerifyDataVectors[test_index].rsaSignVerify_hash_SHA256" as a argument instead of "rsaSignVerify_hash_SHA512"
    Is there any example for RSA Library with Oberon also very helpful to us.
    Is there any timing analysis for this RSA library as compared to ECC Oberon or other libraries is more helpuful to us.
    Srnivas.V
  • Hi Srinivas,
    Can you specify exactly which function call returned 0x00F00441?
    The CC310 integration tests that demonstrate this require no specific changed in sdk_config.h, so that should not be the problem. If you do the same as the integration tests, it should run in your firmware as well. If you do not make progress it would be good if you can share the failing code.
    There are no examples for RSA using Oberon, but you are right it is supported. You can refer to <SDK 17>\external\nrf_oberon\include\occ_rsa.h and <SDK 17>\external\nrf_oberon\include\occ_rsa_key.h for API documentation, though.
    I do not have comparison numbers for RSA, unfortunately.
  • Hi Einar,
    Once again thanks for your reply.
    1. Can you specify exactly which function call returned 0x00F00441?
     we are getting this error (CRYS_RSA_INVALID_SIGNATURE_BUFFER_SIZE - 0x00F00441) for the API's which are calculating the SHA as part of the API itself.
     eg: CRYS_RSA_PKCS1v15_Sign()
           CRYS_RSA_PSS_Sign()
    2. Here with i have added failing code. In return value we are getting this error.
    ActualSignatureSize = rsaSignVerifyDataVectors[test_index].rsaSignVerify_KeySize;
    			/*Call CRYS_RSA_PSS_Sign for PKCS#1 ver2.1 using SHA512*/
    			ret =  CRYS_RSA_PSS_Sign(rndState_ptr, rndGenerateVectFunc,
    				&ContextPrivate,
    				&UserPrivKey,
    				CRYS_RSA_HASH_SHA512_mode,
    				CRYS_PKCS1_MGF1,
    				rsaSignVerifyDataVectors[test_index].rsaSignVerify_SaltLength,
    				rsaSignVerifyDataVectors[test_index].rsaSignVerify_input_data,//DataIn_ptr,
    				rsaSignVerifyDataVectors[test_index].rsaSignVerify_input_dataSize,//DataInSize,
    				rsaSignVerifyDataVectors[test_index].rsaSignVerify_output_signiture,//Output_ptr,
    				&ActualSignatureSize);
    			if (ret != SA_SILIB_RET_OK){
    				INTEG_TEST_PRINT("CRYS_RSA_PSS_Sign failed with 0x%x \n",ret);
    				goto endRSA;
    			/*Call CRYS_RSA_PKCS1v15_Sign PKCS#1 ver1.5 to sign on input data*/
    			ret =  CRYS_RSA_PKCS1v15_Sign(rndState_ptr, rndGenerateVectFunc,
    				&ContextPrivate,
    				&UserPrivKey,
    				CRYS_RSA_HASH_SHA256_mode,
    				INTEG_TEST_PRINT("CRYS_RSA_PKCS1v15_Sign failed with 0x%x \n",ret);
    				goto endRSA;
    We have taken the reference code from cc310 RSA example only. we haven't modified any code. Just added to my application.
    3. Working APi's, SHA is calculating external to API.
    			/*Call CRYS_RSA_PSS_SHA1_Sign PKCS#1 ver2.1 to sign on precalculated hash input using SHA1*/
    			ret =  CRYS_RSA_PSS_SHA1_Sign(rndState_ptr, rndGenerateVectFunc,
    				&ContextPrivate,
    				&UserPrivKey,
    				CRYS_PKCS1_MGF1,
    				rsaSignVerifyDataVectors[test_index].rsaSignVerify_hash_SHA1,//rsaSignVerify_input_data,
    				INTEG_TEST_PRINT("CRYS_RSA_PSS_SHA1_Sign failed with 0x%x \n",ret);
    				goto endRSA;
    			INTEG_TEST_PRINT("CRYS_RSA_PSS_SHA1_Sign passed \n");
    			/*Verify signed hash using SHA1*/
    			ret =  CRYS_RSA_PSS_SHA1_Verify(&ContextPub,
    				&UserPubKey,
    				CRYS_PKCS1_MGF1,
    				rsaSignVerifyDataVectors[test_index].rsaSignVerify_output_signiture);
    				INTEG_TEST_PRINT("CRYS_RSA_PSS_SHA1_Verify failed with 0x%x \n",ret);
    				goto endRSA;
    ret =  CRYS_RSA_PKCS1v15_SHA256_Sign(rndState_ptr, rndGenerateVectFunc,
    				&ContextPrivate,
    				&UserPrivKey,
    				rsaSignVerifyDataVectors[test_index].rsaSignVerify_hash_SHA256,
    				INTEG_TEST_PRINT("CRYS_RSA_PKCS1v15_SHA256_Sign failed with 0x%x \n",ret);
    				goto endRSA;
    			INTEG_TEST_PRINT("CRYS_RSA_PKCS1v15_SHA256_Sign passed \n");
    			/*Verify the signature*/
    			ret =  CRYS_RSA_PKCS1v15_SHA256_Verify(&ContextPub,
    				&UserPubKey,
    				INTEG_TEST_PRINT("CRYS_RSA_PKCS1v15_SHA256_Verify failed with 0x%x \n",ret);
    				goto endRSA;
    4. But the same code is working fine in as part of the example project. we have added the all required header files and include paths.
    Srinivas.V
  • Hi Srinivas,
    The only reason for getting the CRYS_RSA_INVALID_SIGNATURE_BUFFER_SIZE error is that you have specified a too small buffer size. I do not see the value of your input parameters as that is not part of your code snippets code snippets, but that must be the problem.
    Einar
