"Pairing rejected by Nordic_HRM"
While I am going to pair with my android 9 Asus mobile phone with SDK 17 nRF52840. It in my mobile showing "Pairing rejected by Nordic_HRM". After that  I have added a some code line to
static void peer_manager_init(bool erase_bonds);
sec_param.bond = false;
sec_param.mitm = false;
sec_param.lesc = 0;
sec_param.keypress = 0;
sec_param.oob = false;
sec_param.min_key_size = 7;
sec_param.max_key_size = 16;
sec_param.kdist_own.enc = 0;
sec_param.kdist_own.id = 0;
sec_param.kdist_peer.enc = 0;
sec_param.kdist_peer.id = 0;
And getting same "Pairing rejected by Nordic_HRM"
After that I have added this code,
sec_param.bond = true;
sec_param.lesc = 0;
sec_param.io_caps = BLE_GAP_IO_CAPS_NONE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
Please give some solution.
  • Hi
    Could it be that the pairing information is stored in one of the devices, as errors like these are prone to happen if one of the devices thinks it is connected to the other one? On the nRF side, please try doing an nrfjprog --eraseall with the nRF Command line tools or with the nRF Connect for Desktop Programmer application. On the Asus mobile, please try deleting bonding information as well.
    Simon
  • Hi
    Setting sec_param.bond = false; as you've done in the first snippet will cause this "pairing rejected" message as well, as this will disable the bonding feature. I would suggest leaving the parameters as they are by default in the ble_app_hrs example project (see snippet below).
    // Defines used to initialize the peer manager
    #define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                      1                                       /**< LE Secure Connections enabled. */
    #define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
    // peer manager initialization
    static void peer_manager_init(void)
        ret_code_t           err_code;
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    Did you have any luck erasing the bonding information on the nRF side, as that was the only way I was able to reproduce the "Pairing rejected by Nordic_HRM" message here on my side.
    Simon
  • Yes, it is working. But I observed if I forget the "Nordic_HRM" from paired device on my Asus mobile end, then until I clear memory of nordic devices, I can not again paired nordic device again. How can I again pair again the nodic devices with my same mobile without clear Nordic memory. Please help.
  • Hi
    There are a few ways around this. The simplest one is likely to just erase bonding information on the nRF side as well upon a reset of the device, via a button, or whenever it fails to connect due to rejected pairing. deleting bonds can be done by a function like this for example.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
    Note that most examples, by default, checks during start-up if button 2 on the DK is pressed down, and if true calls this delete_bonds() function.
    Simon
