Unable to receive event 'NRF_EVT_POWER_FAILURE_WARNING'
soft device:s132
sdk:15.3.0
I implemented the following, but the event does not occur even if the voltage is V2.8 or less.
Do you know the reason?
NRF_SDH_SOC_OBSERVER(m_soc_observer, 0, pof_evt_dispatch, NULL);
void pof_evt_dispatch(uint32_t sys_evt, void * p_context)
    if (sys_evt == NRF_EVT_POWER_FAILURE_WARNING)
        sd_nvic_SystemReset();
static void power_pof_init(void)
    ret_code_t err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
    err_code = sd_power_pof_enable(1);
    err_code = sd_power_pof_threshold_set(NRF_POWER_THRESHOLD_V28);
sdk_config.c
// <e> NRF_SDH_SOC_ENABLED - nrf_sdh_soc - SoftDevice SoC event handler
#ifndef NRF_SDH_SOC_ENABLED
#define NRF_SDH_SOC_ENABLED 1
// <h> SoC Observers - Observers and priority levels
// <o> NRF_SDH_SOC_OBSERVER_PRIO_LEVELS - Total number of priority levels for SoC observers.
// <i> This setting configures the number of priority levels available for the SoC event handlers.
// <i> The priority level of a handler determines the order in which it receives events, with respect to other handlers.
#ifndef NRF_SDH_SOC_OBSERVER_PRIO_LEVELS
#define NRF_SDH_SOC_OBSERVER_PRIO_LEVELS 2
// <h> SoC Observers priorities - Invididual priorities
// <o> BLE_ADV_SOC_OBSERVER_PRIO
// <i> Priority with which SoC events are dispatched to the Advertising module.
#ifndef BLE_ADV_SOC_OBSERVER_PRIO
#define BLE_ADV_SOC_OBSERVER_PRIO 1
// <o> BLE_DFU_SOC_OBSERVER_PRIO
// <i> Priority with which BLE events are dispatched to the DFU Service.
#ifndef BLE_DFU_SOC_OBSERVER_PRIO
#define BLE_DFU_SOC_OBSERVER_PRIO 1
// <o> CLOCK_CONFIG_SOC_OBSERVER_PRIO
// <i> Priority with which SoC events are dispatched to the Clock driver.
#ifndef CLOCK_CONFIG_SOC_OBSERVER_PRIO
#define CLOCK_CONFIG_SOC_OBSERVER_PRIO 0
// <o> POWER_CONFIG_SOC_OBSERVER_PRIO
// <i> Priority with which SoC events are dispatched to the Power driver.
#ifndef POWER_CONFIG_SOC_OBSERVER_PRIO
#define POWER_CONFIG_SOC_OBSERVER_PRIO 0
