Documentation on generating/using custom signing key for FOTA in nRF Connect SDK
Hello Nordic Team,
Over the course of development I have had to reverse engineer and pick apart various sources (DevZone, Google, Zephyr documentation, etc) in order to figure out how to properly generate and utilize a custom, private signing key for our FOTA images. I currently have a working solution but it feels more like a hack and as I frequently test on the master branch to prepare for upcoming changes, it appears that the method I am using is generating warnings.
My question is: is there any official documentation and/or guide on how to properly generate and sign images using a custom signing key and how that is integrated into a project (ie asset_tracker)?
I want to make sure that I am doing it right and that it is properly integrated into my project and build system.
Cody
  • This should get done automatically, as mentioned in this ticket and in Signing Binaries, just make sure to set CONFIG_BOOTLOADER_MCUBOOT=y  and CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="path to your key" in prj.conf of your application. Then the files mentioned here should be generated.
    Simon
  • Hey @Simon,
    Thanks for getting back to me. I ensured that the two configuration options were part of my projects prj.conf (CONFIG_BOOTLOADER_MCUBOOT and CONFIG_MCUBOOT_SIGNATURE_KEY_FILE). When I attempt to build the project, I get the following message...
    CMake Warning at /ncs_v1.4/nrf/cmake/mcuboot.cmake:303 (message):
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE is set to
    "build/key/testkey/testkey-rsa-2048.pem".
    You are using the NCS Mcuboot signing, which means this option will be
    ignored.
    Image signing in NCS is done via the MCUboot image's
    CONFIG_BOOT_SIGNATURE_KEY_FILE option.
    Consider setting CONFIG_MCUBOOT_SIGNATURE_KEY_FILE in your application
    image back to its default value, the empty string.
    /ncs_v1.4/bootloader/mcuboot/zephyr/CMakeLists.txt:1 (include)
     It looks like it relates to this commit here: https://github.com/nrfconnect/sdk-nrf/commit/45c9fbbc330ecd24eecd43c7dd0cfcdd4e93b8f4
    The commit mentions the following...
    If partition manager is in use and there are multiple images, we want to make sure users understand this option should probably be left alone, since the NCS build system has its own way of managing signing."
    Can you explain how the NCS build system has its own way of managing signing?
  • I have generated my own private key and am following the same/similar setup as asset_tracker/connectivity bridge in nRF Connect SDK v1.4.2.
    It is very strange though because CONFIG_BOOT_SIGNATURE_KEY_FILE is being set to my custom key file name and appears to be utilized.
    CMake Warning at /Users/crsharff/Development_Tools/ncs_v1.4/nrf/cmake/mcuboot.cmake:125 (message):
            --- WARNING: Using default MCUBoot key, it should not ---
            --- be used for production.                           ---
    CMake Warning at /Users/crsharff/Development_Tools/ncs_v1.4/nrf/cmake/mcuboot.cmake:133 (message):
      mcuboot_key_file /cody-custom-rsa-2048.pem
    Doing more research it appears that this error is shown because the following code block doesn't set the mcuboot_key_file because mcuboot_CONF_DIR and mcuboot_CONF_DIR appear undefined.
      if (DEFINED mcuboot_CONF_FILE)
        message(WARNING "DEFINED mcuboot_CONF_FILE")
        get_filename_component(mcuboot_CONF_DIR ${mcuboot_CONF_FILE} DIRECTORY)
        if (EXISTS ${mcuboot_CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE})
          message(WARNING "EXISTS ${mcuboot_CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE}")
          set(mcuboot_key_file ${mcuboot_CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE})
        endif()
      endif()
      # Set default key
      if (NOT DEFINED mcuboot_key_file)
        message(WARNING "
          \n"
        set(mcuboot_key_file ${MCUBOOT_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE})
        message(WARNING "mcuboot_key_file ${mcuboot_CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE}")
      endif()
  • I'll look into it tomorrow morning (CET).
  • Thanks Simon, much appreciated. The more I delve into it the more it looks like its just an issue with the logic inside mcuboot.cmake. It will print the scary message 100% of the time as long as mcuboot_CONF_FILE is not defined and mcuboot_CONF_FILE being defined does not look like a requirement for CONFIG_BOOT_SIGNATURE_KEY_FILE to be properly set by the MCUBoot overlay configuration file in my project.
    Found this other thread on the DevZone that seems to be discussing a lot of the same issues: devzone.nordicsemi.com/.../problem-with-signing-images-for-ota-dfu
  • Sorry for answering 4 days late. I've asked internally if there has been any progress on this.
  • This is fixed in this PR https://github.com/nrfconnect/sdk-nrf/pull/3580, which included in NCS v1.5.0.
    Simon
