How to Recover if Invalid Connection Handle Passed into ble_db_discovery_start
I'm working on code that needs to discover services on the central so I'm using ble_db_discovery_start.  However, I notice that if the connection handle passed into this does not reference a valid connection, the discovery fails.  However, I'm also never able to start another discovery with the structure that was passed in.  What can I do to reset the discovery system so that I can discover services on the next connection?  I have modified the main file of ble_app_ancs_c_pca10056_s140 to demonstrate the problem by calling ble_db_discovery_start on connection handle two after everything has been initialized but nothing has connected yet.  Then, when the iPhone connects ANCS is not discovered.
 * Copyright (c) 2012 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_apple_notification_main main.c
 * @ingroup ble_sdk_app_apple_notification
 * @brief Apple Notification Client Sample Application main file. Disclaimer:
 * This client implementation of the Apple Notification Center Service can and
 * will be changed at any time by Nordic Semiconductor ASA.
 * Server implementations such as the ones found in iOS can be changed at any
 * time by Apple and may cause this client implementation to stop working.
 * This file contains the source code for a sample application using the Apple
 * Notification Center Service Client.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble_hci.h"
#include "ble_gap.h"
#include "ble_err.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "nrf_delay.h"
#include "app_scheduler.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "ble_db_discovery.h"
#include "nrf_ble_gatts_c.h"
#include "nrf_ble_ancs_c.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_gq.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define ATTR_DATA_SIZE                 BLE_ANCS_ATTR_DATA_MAX                 /**< Allocated size for attribute data. */
#define DISPLAY_MESSAGE_BUTTON_ID      1                                      /**< Button used to request notification attributes. */
#define DEVICE_NAME                    "ANCS"                                 /**< Name of the device. Will be included in the advertising data. */
#define APP_BLE_OBSERVER_PRIO          3                                      /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG           1                                      /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_FAST_INTERVAL          40                                     /**< The advertising interval (in units of 0.625 ms). The default value corresponds to 25 ms. */
#define APP_ADV_SLOW_INTERVAL          3200                                   /**< Slow advertising interval (in units of 0.625 ms). The default value corresponds to 2 seconds. */
#define APP_ADV_FAST_DURATION          3000                                   /**< The advertising duration of fast advertising in units of 10 milliseconds. */
#define APP_ADV_SLOW_DURATION          18000                                  /**< The advertising duration of slow advertising in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL              MSEC_TO_UNITS(500, UNIT_1_25_MS)       /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL              MSEC_TO_UNITS(1000, UNIT_1_25_MS)      /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                  0                                      /**< Slave latency. */
#define CONN_SUP_TIMEOUT               MSEC_TO_UNITS(4000, UNIT_10_MS)        /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000)                  /**< Time from initiating an event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(30000)                 /**< Time between each call to sd_ble_gap_conn_param_update after the first (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT   3                                      /**< Number of attempts before giving up the connection parameter negotiation. */
#define MESSAGE_BUFFER_SIZE            18                                     /**< Size of buffer holding optional messages in notifications. */
#define SECURITY_REQUEST_DELAY         APP_TIMER_TICKS(1500)                  /**< Delay after connection until security request is sent, if necessary (ticks). */
#define SEC_PARAM_BOND                 1                                      /**< Perform bonding. */
#define SEC_PARAM_MITM                 0                                      /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                 0                                      /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS             0                                      /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES      BLE_GAP_IO_CAPS_NONE                   /**< No I/O capabilities. */
#define SEC_PARAM_OOB                  0                                      /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE         7                                      /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE         16                                     /**< Maximum encryption key size. */
#define DEAD_BEEF                      0xDEADBEEF                             /**< Value used as error code on stack dump. Can be used to identify stack location on stack unwind. */
#define SCHED_MAX_EVENT_DATA_SIZE      APP_TIMER_SCHED_EVENT_DATA_SIZE        /**< Maximum size of scheduler events. */
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SCHED_QUEUE_SIZE               20                                     /**< Maximum number of events in the scheduler queue. More is needed in case of Serialization. */
#else
#define SCHED_QUEUE_SIZE               10                                     /**< Maximum number of events in the scheduler queue. */
NRF_BLE_GATTS_C_DEF(m_gatts_c);                                               /**< GATT Service client instance. Handles Service Changed indications from the peer. */
BLE_ANCS_C_DEF(m_ancs_c);                                                     /**< Apple Notification Service Client instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                     /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                       /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                           /**< Advertising module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                              /**< DB Discovery module instance. */
NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                              /**< BLE GATT Queue instance. */
               NRF_SDH_BLE_PERIPHERAL_LINK_COUNT,
               NRF_BLE_GQ_QUEUE_SIZE);
static pm_peer_id_t      m_whitelist_peers[BLE_GAP_WHITELIST_ADDR_MAX_COUNT]; /**< List of peers currently in the whitelist. */
static uint32_t          m_whitelist_peer_cnt;                                /**< Number of peers currently in the whitelist. */
static uint16_t          m_cur_conn_handle = BLE_CONN_HANDLE_INVALID;         /**< Handle of the current connection. */
static ble_gatt_db_srv_t m_peer_srv_buf[2] = {0};                             /**< Array of services with room to store both GATT Service and ANCS. */
static bool              m_ancs_discovered  = false;                          /**< Bool to keep track of when both ancs and gatts have been disovered. Only then do we want to save the peer data. */
static bool              m_gatts_discovered = false;                          /**< Bool to keep track of when both ancs and gatts have been disovered. Only then do we want to save the peer data. */
static ble_ancs_c_evt_notif_t m_notification_latest;                          /**< Local copy to keep track of the newest arriving notifications. */
static ble_ancs_c_attr_t      m_notif_attr_latest;                            /**< Local copy of the newest notification attribute. */
static ble_ancs_c_attr_t      m_notif_attr_app_id_latest;                     /**< Local copy of the newest app attribute. */
static uint8_t m_attr_appid[ATTR_DATA_SIZE];                                  /**< Buffer to store attribute data. */
static uint8_t m_attr_title[ATTR_DATA_SIZE];                                  /**< Buffer to store attribute data. */
static uint8_t m_attr_subtitle[ATTR_DATA_SIZE];                               /**< Buffer to store attribute data. */
static uint8_t m_attr_message[ATTR_DATA_SIZE];                                /**< Buffer to store attribute data. */
static uint8_t m_attr_message_size[ATTR_DATA_SIZE];                           /**< Buffer to store attribute data. */
static uint8_t m_attr_date[ATTR_DATA_SIZE];                                   /**< Buffer to store attribute data. */
static uint8_t m_attr_posaction[ATTR_DATA_SIZE];                              /**< Buffer to store attribute data. */
static uint8_t m_attr_negaction[ATTR_DATA_SIZE];                              /**< Buffer to store attribute data. */
static uint8_t m_attr_disp_name[ATTR_DATA_SIZE];                              /**< Buffer to store attribute data. */
/**@brief String literals for the iOS notification categories. used then printing to UART. */
static char const * lit_catid[BLE_ANCS_NB_OF_CATEGORY_ID] =
    "Other",
    "Incoming Call",
    "Missed Call",
    "Voice Mail",
    "Social",
    "Schedule",
    "Email",
    "News",
    "Health And Fitness",
    "Business And Finance",
    "Location",
    "Entertainment"
/**@brief String literals for the iOS notification event types. Used then printing to UART. */
static char const * lit_eventid[BLE_ANCS_NB_OF_EVT_ID] =
    "Added",
    "Modified",
    "Removed"
/**@brief String literals for the iOS notification attribute types. Used when printing to UART. */
static char const * lit_attrid[BLE_ANCS_NB_OF_NOTIF_ATTR] =
    "App Identifier",
    "Title",
    "Subtitle",
    "Message",
    "Message Size",
    "Date",
    "Positive Action Label",
    "Negative Action Label"
/**@brief String literals for the iOS notification attribute types. Used When printing to UART. */
static char const * lit_appid[BLE_ANCS_NB_OF_APP_ATTR] =
    "Display Name"
static void delete_bonds(void);
/**@brief Callback function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is an example only and does not fit a final product.
 *          You must analyze how your product should react to asserts.
 * @warning On assert from the SoftDevice, the system can recover only on reset.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Fetch the list of peer manager peer IDs.
 * @param[inout] p_peers   The buffer where to store the list of peer IDs.
 * @param[inout] p_size    In: The size of the @p p_peers buffer.
 *                         Out: The number of peers copied in the buffer.
static void peer_list_get(pm_peer_id_t * p_peers, uint32_t * p_size)
    pm_peer_id_t peer_id;
    uint32_t     peers_to_copy;
    peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ?
                     *p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
    peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
    *p_size = 0;
    while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--))
        p_peers[(*p_size)++] = peer_id;
        peer_id = pm_next_peer_id_get(peer_id);
/**@brief Function for starting advertising. */
static void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        ret_code_t ret;
        memset(m_whitelist_peers, PM_PEER_ID_INVALID, sizeof(m_whitelist_peers));
        m_whitelist_peer_cnt = (sizeof(m_whitelist_peers) / sizeof(pm_peer_id_t));
        peer_list_get(m_whitelist_peers, &m_whitelist_peer_cnt);
        ret = pm_whitelist_set(m_whitelist_peers, m_whitelist_peer_cnt);
        APP_ERROR_CHECK(ret);
        // Setup the device identies list.
        // Some SoftDevices do not support this feature.
        ret = pm_device_identities_list_set(m_whitelist_peers, m_whitelist_peer_cnt);
        if (ret != NRF_ERROR_NOT_SUPPORTED)
        ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    ret_code_t ret;
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
        case PM_EVT_BONDED_PEER_CONNECTED:
            if (p_evt->peer_id != PM_PEER_ID_INVALID)
                uint32_t data_len = sizeof(m_peer_srv_buf);
                ret = pm_peer_data_remote_db_load(p_evt->peer_id, m_peer_srv_buf, &data_len);
                if (ret == NRF_ERROR_NOT_FOUND)
                    NRF_LOG_DEBUG("Could not find the remote database in flash.");
                    ret = nrf_ble_gatts_c_handles_assign(&m_gatts_c, p_evt->conn_handle, NULL);
                    // Discover peer's services.
                    memset(&m_db_disc, 0x00, sizeof(m_db_disc));
                    ret = ble_db_discovery_start(&m_db_disc, p_evt->conn_handle);
                    // Check if the load was successful.
                    ASSERT(data_len == sizeof(m_peer_srv_buf));
                    NRF_LOG_INFO("Remote Database loaded from flash.");
                    // Assign the loaded handles to the GATT Service client module.
                    ble_gatt_db_char_t srv_changed_handles = m_peer_srv_buf[0].charateristics[0];
                                                         p_evt->conn_handle,
                                                         &srv_changed_handles);
                    // Enable indications.
                    ret = nrf_ble_gatts_c_enable_indication(&m_gatts_c, true);
                    //Load the relevant handles into a ble_ancs_c_service_t struct that can be
                    // assigned to the ANCS module.
                    ble_ancs_c_service_t ancs_handles;
                    ble_gatt_db_char_t * p_char           = m_peer_srv_buf[1].charateristics;
                    ancs_handles.control_point_char       = p_char[0].characteristic;
                    ancs_handles.notif_source_char        = p_char[1].characteristic;
                    ancs_handles.notif_source_cccd.handle = p_char[1].cccd_handle;
                    ancs_handles.data_source_char         = p_char[2].characteristic;
                    ancs_handles.data_source_cccd.handle  = p_char[2].cccd_handle;
                    ret = nrf_ble_ancs_c_handles_assign(&m_ancs_c, p_evt->conn_handle,
                                                        &ancs_handles);
        } break;
        case PM_EVT_CONN_SEC_SUCCEEDED:
            // Check it the Service Changed characteristic handle exists in our client instance.
            // If it is invalid, we know service discovery is needed.
            // (No database was loaded during @ref PM_EVT_BONDED_PEER_CONNECTED)
            if (m_gatts_c.srv_changed_char.characteristic.handle_value == BLE_GATT_HANDLE_INVALID)
        } break;
            advertising_start(false);
        } break;
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            // Note: You should check on what kind of white list policy your application should use.
            if (     p_evt->params.peer_data_update_succeeded.flash_changed
                 && (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
                NRF_LOG_DEBUG("New Bond, add the peer to the whitelist if possible");
                NRF_LOG_DEBUG("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
                               m_whitelist_peer_cnt + 1,
                               BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
                if (m_whitelist_peer_cnt < BLE_GAP_WHITELIST_ADDR_MAX_COUNT)
                    // Bonded to a new peer, add it to the whitelist.
                    m_whitelist_peers[m_whitelist_peer_cnt++] = p_evt->peer_id;
                    // The whitelist has been modified, update it in the Peer Manager.
        } break;
/**@brief Function for setting up GATTC notifications from the Notification Provider.
 * @details This function is called when a successful connection has been established.
static void apple_notification_setup(void)
    ret_code_t ret;
    nrf_delay_ms(100); // Delay because we cannot add a CCCD to close to starting encryption. iOS specific.
    ret = ble_ancs_c_notif_source_notif_enable(&m_ancs_c);
    ret = ble_ancs_c_data_source_notif_enable(&m_ancs_c);
    NRF_LOG_DEBUG("Notifications Enabled.");
/**@brief Function for printing an iOS notification.
 * @param[in] p_notif  Pointer to the iOS notification.
static void notif_print(ble_ancs_c_evt_notif_t * p_notif)
    NRF_LOG_INFO("\r\nNotification");
    NRF_LOG_INFO("Event:       %s", (uint32_t)lit_eventid[p_notif->evt_id]);
    NRF_LOG_INFO("Category ID: %s", (uint32_t)lit_catid[p_notif->category_id]);
    NRF_LOG_INFO("Category Cnt:%u", (unsigned int) p_notif->category_count);
    NRF_LOG_INFO("UID:         %u", (unsigned int) p_notif->notif_uid);
    NRF_LOG_INFO("Flags:");
    if (p_notif->evt_flags.silent == 1)
        NRF_LOG_INFO(" Silent");
    if (p_notif->evt_flags.important == 1)
        NRF_LOG_INFO(" Important");
    if (p_notif->evt_flags.pre_existing == 1)
        NRF_LOG_INFO(" Pre-existing");
    if (p_notif->evt_flags.positive_action == 1)
        NRF_LOG_INFO(" Positive Action");
    if (p_notif->evt_flags.negative_action == 1)
        NRF_LOG_INFO(" Negative Action");
/**@brief Function for printing iOS notification attribute data.
 * @param[in] p_attr Pointer to an iOS notification attribute.
static void notif_attr_print(ble_ancs_c_attr_t * p_attr)
    if (p_attr->attr_len != 0)
        NRF_LOG_INFO("%s: %s", (uint32_t)lit_attrid[p_attr->attr_id],
                     nrf_log_push((char *)p_attr->p_attr_data));
    else if (p_attr->attr_len == 0)
        NRF_LOG_INFO("%s: (N/A)", (uint32_t)lit_attrid[p_attr->attr_id]);
 * @param[in] p_attr Pointer to an iOS App attribute.
static void app_attr_print(ble_ancs_c_attr_t * p_attr)
        NRF_LOG_INFO("%s: %s", (uint32_t)lit_appid[p_attr->attr_id], (uint32_t)p_attr->p_attr_data);
        NRF_LOG_INFO("%s: (N/A)", (uint32_t) lit_appid[p_attr->attr_id]);
/**@brief Function for printing out errors that originated from the Notification Provider (iOS).
 * @param[in] err_code_np Error code received from NP.
static void err_code_print(uint16_t err_code_np)
    switch (err_code_np)
        case BLE_ANCS_NP_UNKNOWN_COMMAND:
            NRF_LOG_INFO("Error: Command ID was not recognized by the Notification Provider. ");
        case BLE_ANCS_NP_INVALID_COMMAND:
            NRF_LOG_INFO("Error: Command failed to be parsed on the Notification Provider. ");
        case BLE_ANCS_NP_INVALID_PARAMETER:
            NRF_LOG_INFO("Error: Parameter does not refer to an existing object on the Notification Provider. ");
        case BLE_ANCS_NP_ACTION_FAILED:
            NRF_LOG_INFO("Error: Perform Notification Action Failed on the Notification Provider. ");
/**@brief Function for initializing the timer module.
static void timers_init(void)
    ret_code_t ret;
    ret = app_timer_init();
/**@brief Function for handling events from the GATT Servive client module.
   @param[in] p_evt GATT Service event.
static void gatts_c_evt_handler(nrf_ble_gatts_c_evt_t * p_evt)
    ret_code_t ret = NRF_SUCCESS;
    switch (p_evt->evt_type)
        case NRF_BLE_GATTS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_DEBUG("GATT Service and Service Changed characteristic found on server.");
                                                 p_evt->conn_handle,
                                                 &p_evt->params.srv_changed_char);
            ret = pm_peer_id_get(p_evt->conn_handle, &peer_id);
            memset(&m_peer_srv_buf[0], 0, sizeof(m_peer_srv_buf[0]));
            m_peer_srv_buf[0].charateristics[0] = p_evt->params.srv_changed_char;
            m_gatts_discovered = true;
            if(m_gatts_discovered && m_ancs_discovered)
                ret = pm_peer_data_remote_db_store(peer_id,
                                                   (ble_gatt_db_srv_t *)m_peer_srv_buf,
                                                   sizeof(m_peer_srv_buf),
                                                   NULL);
                if (ret == NRF_ERROR_STORAGE_FULL)
                    ret = fds_gc();
        } break;
        case NRF_BLE_GATTS_C_EVT_DISCOVERY_FAILED:
            NRF_LOG_DEBUG("GATT Service or Service Changed characteristic not found on server.");
        case NRF_BLE_GATTS_C_EVT_DISCONN_COMPLETE:
            NRF_LOG_DEBUG("GATTS Service client disconnected connection handle %i.",
        case NRF_BLE_GATTS_C_EVT_SRV_CHANGED:
            NRF_LOG_DEBUG("Service Changed indication received.");
/**@brief Function for handling the Apple Notification Service client.
 * @details This function is called for all events in the Apple Notification client that
 *          are passed to the application.
 * @param[in] p_evt  Event received from the Apple Notification Service client.
static void ancs_c_evt_handler(ble_ancs_c_evt_t * p_evt)
        case BLE_ANCS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_DEBUG("Apple Notification Center Service discovered on the server.");
            ret = nrf_ble_ancs_c_handles_assign(&m_ancs_c, p_evt->conn_handle, &p_evt->service);
            // Copy the needed ANCS handles into a ble_gatt_db_srv_t struct that will be stored in
            // flash.
            memset(&m_peer_srv_buf[1], 0, sizeof(m_peer_srv_buf[1]));
            p_char[0].characteristic = p_evt->service.control_point_char;
            p_char[1].characteristic = p_evt->service.notif_source_char;
            p_char[1].cccd_handle    = p_evt->service.notif_source_cccd.handle;
            p_char[2].characteristic = p_evt->service.data_source_char;
            p_char[2].cccd_handle    = p_evt->service.data_source_cccd.handle;
            m_ancs_discovered = true;
            if (m_gatts_discovered && m_ancs_discovered)
                                                   NULL);
                    ret = fds_gc();
            apple_notification_setup();
        } break;
        case BLE_ANCS_C_EVT_NOTIF:
            m_notification_latest = p_evt->notif;
            notif_print(&m_notification_latest);
        case BLE_ANCS_C_EVT_NOTIF_ATTRIBUTE:
            m_notif_attr_latest = p_evt->attr;
            notif_attr_print(&m_notif_attr_latest);
            if (p_evt->attr.attr_id == BLE_ANCS_NOTIF_ATTR_ID_APP_IDENTIFIER)
                m_notif_attr_app_id_latest = p_evt->attr;
        case BLE_ANCS_C_EVT_DISCOVERY_FAILED:
            NRF_LOG_DEBUG("Apple Notification Center Service not discovered on the server.");
        case BLE_ANCS_C_EVT_APP_ATTRIBUTE:
            app_attr_print(&p_evt->attr);
        case BLE_ANCS_C_EVT_NP_ERROR:
            err_code_print(p_evt->err_code_np);
            // No implementation needed.
/**@brief Function for initializing GAP connection parameters.
 * @details Use this function to set up all necessary GAP (Generic Access Profile)
 *          parameters of the device. It also sets the permissions and appearance.
    ret_code_t              ret;
    ret = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME));
    ret = sd_ble_gap_ppcp_set(&gap_conn_params);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t ret = nrf_ble_gatt_init(&m_gatt, NULL);
/**@brief Function for handling the Apple Notification Service client errors.
static void apple_notification_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling a Connection Parameters error.
    ret_code_t             ret;
    cp_init.disconnect_on_fail             = true;
    cp_init.evt_handler                    = NULL;
    ret = ble_conn_params_init(&cp_init);
/**@brief Function for handling Database Discovery events.
 * @details This function is a callback function to handle events from the database discovery
 *          module. Depending on the UUIDs that are discovered, this function should forward the
 *          events to their respective service instances.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_ancs_c_on_db_disc_evt(&m_ancs_c, p_evt);
    nrf_ble_gatts_c_on_db_disc_evt(&m_gatts_c, p_evt);
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    ret_code_t           ret;
    ret = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    ret = pm_sec_params_set(&sec_param);
    ret = pm_register(pm_evt_handler);
 * @brief Delete all data stored for all peers.
    ret_code_t err_code;
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
    uint32_t ret = bsp_indication_set(BSP_INDICATE_IDLE);
    // Prepare wakeup buttons.
    ret = bsp_btn_ble_sleep_mode_prepare();
    ret = sd_power_system_off();
 * @details This function is called for advertising events that are passed to the application.
    ret_code_t ret;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising");
            ret = bsp_indication_set(BSP_INDICATE_ADVERTISING);
        case BLE_ADV_EVT_SLOW:
            NRF_LOG_INFO("Slow advertising");
            ret = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
        case BLE_ADV_EVT_FAST_WHITELIST:
            NRF_LOG_INFO("Fast advertising with Whitelist");
            ret = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
        case BLE_ADV_EVT_WHITELIST_REQUEST:
            ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            ble_gap_irk_t  whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            uint32_t       addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            uint32_t       irk_cnt  = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            ret = pm_whitelist_get(whitelist_addrs, &addr_cnt, whitelist_irks, &irk_cnt);
            NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
                           addr_cnt,
                           irk_cnt);
            // Apply the whitelist.
            ret = ble_advertising_whitelist_reply(&m_advertising,
                                                  whitelist_addrs,
                                                  addr_cnt,
                                                  whitelist_irks,
                                                  irk_cnt);
    pm_handler_secure_on_connection(p_ble_evt);
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            ret = bsp_indication_set(BSP_INDICATE_CONNECTED);
            m_cur_conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
            ret = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_cur_conn_handle);
            NRF_LOG_INFO("Disconnected.");
            if (p_ble_evt->evt.gap_evt.conn_handle == m_ancs_c.conn_handle)
                m_ancs_c.conn_handle = BLE_CONN_HANDLE_INVALID;
            break; // BLE_GAP_EVT_DISCONNECTED
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
            ret = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys);
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
            ret = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle,
        case BLE_GATTS_EVT_TIMEOUT:
            ret = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle,
 * @param[in] event  Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    ret_code_t ret;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            ret = sd_ble_gap_disconnect(m_cur_conn_handle,
            if (ret != NRF_ERROR_INVALID_STATE)
        case BSP_EVENT_WHITELIST_OFF:
            if (m_ancs_c.conn_handle == BLE_CONN_HANDLE_INVALID)
                ret = ble_advertising_restart_without_whitelist(&m_advertising);
        case BSP_EVENT_KEY_0:
            ret = nrf_ble_ancs_c_request_attrs(&m_ancs_c, &m_notification_latest);
        case BSP_EVENT_KEY_1:
            if (m_notif_attr_app_id_latest.attr_id == BLE_ANCS_NOTIF_ATTR_ID_APP_IDENTIFIER
                && m_notif_attr_app_id_latest.attr_len != 0)
                NRF_LOG_INFO("Request for %s: ", (uint32_t)m_notif_attr_app_id_latest.p_attr_data);
                ret = nrf_ble_ancs_c_app_attr_request(&m_ancs_c,
                                                      m_notif_attr_app_id_latest.p_attr_data,
                                                      m_notif_attr_app_id_latest.attr_len);
        case BSP_EVENT_KEY_2:
            if (m_notification_latest.evt_flags.positive_action == true)
                NRF_LOG_INFO("Performing Positive Action.");
                ret = nrf_ancs_perform_notif_action(&m_ancs_c,
                                                    m_notification_latest.notif_uid,
                                                    ACTION_ID_POSITIVE);
        case BSP_EVENT_KEY_3:
            if (m_notification_latest.evt_flags.negative_action == true)
                NRF_LOG_INFO("Performing Negative Action.");
                                                    ACTION_ID_NEGATIVE);
    uint32_t ram_start = 0;
    // Enable BLE stack.
    ret_code_t             ret;
    ble_ancs_c_init_t      ancs_c_init;
    nrf_ble_gatts_c_init_t gatts_c_init;
    ret = nrf_ble_qwr_init(&m_qwr, &qwr_init);
    // Init the GATTS client module.
    memset(&gatts_c_init, 0, sizeof(gatts_c_init));
    gatts_c_init.evt_handler  = gatts_c_evt_handler;
    gatts_c_init.p_gatt_queue = &m_ble_gatt_queue;
    ret = nrf_ble_gatts_c_init(&m_gatts_c, &gatts_c_init);
    // Init the Apple Notification Center Service client module.
    memset(&ancs_c_init, 0, sizeof(ancs_c_init));
    ret = nrf_ble_ancs_c_attr_add(&m_ancs_c,
                                  BLE_ANCS_NOTIF_ATTR_ID_APP_IDENTIFIER,
                                  m_attr_appid,
                                  ATTR_DATA_SIZE);
    ret = nrf_ble_ancs_c_app_attr_add(&m_ancs_c,
                                      BLE_ANCS_APP_ATTR_ID_DISPLAY_NAME,
                                      m_attr_disp_name,
                                      sizeof(m_attr_disp_name));
                                  BLE_ANCS_NOTIF_ATTR_ID_TITLE,
                                  m_attr_title,
                                  ATTR_DATA_SIZE);
                                  BLE_ANCS_NOTIF_ATTR_ID_MESSAGE,
                                  m_attr_message,
                                  ATTR_DATA_SIZE);
                                  BLE_ANCS_NOTIF_ATTR_ID_SUBTITLE,
                                  m_attr_subtitle,
                                  ATTR_DATA_SIZE);
                                  BLE_ANCS_NOTIF_ATTR_ID_MESSAGE_SIZE,
                                  m_attr_message_size,
                                  ATTR_DATA_SIZE);
                                  BLE_ANCS_NOTIF_ATTR_ID_DATE,
                                  m_attr_date,
                                  ATTR_DATA_SIZE);
                                  BLE_ANCS_NOTIF_ATTR_ID_POSITIVE_ACTION_LABEL,
                                  m_attr_posaction,
                                  ATTR_DATA_SIZE);
                                  BLE_ANCS_NOTIF_ATTR_ID_NEGATIVE_ACTION_LABEL,
                                  m_attr_negaction,
                                  ATTR_DATA_SIZE);
    ancs_c_init.evt_handler   = ancs_c_evt_handler;
    ancs_c_init.error_handler = apple_notification_error_handler;
    ancs_c_init.p_gatt_queue  = &m_ble_gatt_queue;
    ret = ble_ancs_c_init(&m_ancs_c, &ancs_c_init);
/**@brief Function for initializing the advertising functionality.
    ret_code_t             ret;
    ble_advertising_init_t init;
    static ble_uuid_t m_adv_uuids[1]; /**< Universally unique service identifiers. */
    m_adv_uuids[0].uuid = ANCS_UUID_SERVICE;
    m_adv_uuids[0].type = m_ancs_c.service.service.uuid.type;
    init.advdata.name_type                = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance       = true;
    init.advdata.flags                    = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt  = 0;
    init.advdata.uuids_complete.p_uuids   = NULL;
    init.advdata.uuids_solicited.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_solicited.p_uuids  = m_adv_uuids;
    init.config.ble_adv_whitelist_enabled = true;
    init.config.ble_adv_fast_enabled      = true;
    init.config.ble_adv_fast_interval     = APP_ADV_FAST_INTERVAL;
    init.config.ble_adv_fast_timeout      = APP_ADV_FAST_DURATION;
    init.config.ble_adv_slow_enabled      = true;
    init.config.ble_adv_slow_interval     = APP_ADV_SLOW_INTERVAL;
    init.config.ble_adv_slow_timeout      = APP_ADV_SLOW_DURATION;
    ret = ble_advertising_init(&m_advertising, &init);
/**@brief Function for initializing buttons and LEDs.
 * @param[out] p_erase_bonds  True if the clear bonds button was pressed to wake the application up.
    uint32_t ret;
    bsp_event_t startup_event;
    ret = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    ret = bsp_btn_ble_init(NULL, &startup_event);
/**@brief Function for initializing the Event Scheduler.
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
/**@brief Function for initializing the database discovery module.
static void db_discovery_init(void)
    ble_db_discovery_init_t db_init;
    memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
    db_init.evt_handler  = db_disc_handler;
    db_init.p_gatt_queue = &m_ble_gatt_queue;
    ret_code_t ret = ble_db_discovery_init(&db_init);
static void log_init(void)
    ret_code_t ret = NRF_LOG_INIT(NULL);
    app_sched_execute();
        nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    scheduler_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    db_discovery_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Apple Notification Center Service client example started.");
    advertising_start(erase_bonds);
    const uint32_t ret_val = ble_db_discovery_start(&m_db_disc, 2);
    NRF_LOG_INFO("DB DISCOVERY START: %lu", ret_val);
    // Enter main loop.
    for (;;)
        idle_state_handle();
  • Hi Kenneth,
    Could you let me know why ble_db_discovery_start() was called with invalid connection handler ? It's quite important to monitor the connection handle and assign it to BLE_CONN_HANDLE_INVALID when it's disconnected. I would suggest to put a check to avoid calling ble_db_discovery_start() if the connection handle is BLE_CONN_HANDLE_INVALID
    If for some reasons it was called with invalid handle, I think you would need to re-initialize the ble_db_discovery, using ble_db_discovery_init(). It will however, erase the info on all connections.
  • I was actually able to resolve the issue by increasing the number of connections allowed - the connection handle specified was above the max connections.  The reason I was doing this was to test the robustness of this process - since a disconnect can be triggered by the remote at any time, it will ultimately be a race condition as to when this is called, as the connection handle can become invalid after checking if its valid but before the discover is called and I wanted to make sure that this wouldn't leave our device non-functional.  However, the code handles that just fine as is.
  • Hi Kenneth,
    Thanks for letting me know. My understanding is that the softdevice will return an error if you call an API using an invalid connection handle (just disconnected).  I guess it depends on the implementation of the module if it would handle the error correctly. Seems that you now have a working solution :)
