Hello, i have a question about program interaction with softdevice and using timeslot API.
I have custom board with nRF52811 chip on it and want to realize peripheral and central functionality. At first i used SD140 with SDK v16, but SD140 is quiet large and i didn't have enough FLASH memory for my program. So my question is: it is possible to use, for example, SD112/SD113 only for peripheral purposes and timeslot API or anything else for central purposes (observing advertising packets)?
UPD: i found a "experimental_ble_app_multiactivity_beacon" example in SDK v11, in "scanner_beacon.h" states: "This module implements an Scanner which can be run in parallel with the S110 (thus allowing, for example, to scan while in a connection or while advertising)" and S110 is Bluetooth Low Energy Peripheral protocol stack for the nRF51 Series SoCs. So i conclude that i can run scanning with peripheral-only softdevice. But there is a new question: after i finished working with scanning timeslot session, do i need to restore advertising parameters and registers to their initial values or softdevice will do it for me?
