I can make the RTC work with interrupts and __WFI(). I absolutely can't get events and __RFE() to work for the RTC. However, it works if I replace the __RFE() with __NOP(), so the RTC and events *seem* to be configured properly.
I've just got to be missing something stupidly obvious. Any help would be appreciated.
Thanks.
Code included which works on a nrf52832 (PCA10040 board):
#include <stdbool.h> #include <stdint.h> // $SDK/modules/nrfx #include "mdk/nrf52_bitfields.h" #include "hal/nrf_gpio.h" #include "hal/nrf_clock.h" #include "hal/nrf_rtc.h" #include "delay/nrf_delay.h" #define PIN_LED 19 // LED1 static unsigned irq_counter = 0; #define RTC_USE_IRQ 0 #define RTC_USE_EVENT 1 #if RTC_USE_IRQ void RTC0_IRQHandler(void) { nrf_rtc_event_clear(NRF_RTC0,NRF_RTC_EVENT_TICK); irq_counter++; // every 8 IRQs, we toggle the led -> 1Hz rate if(irq_counter %8 == 0) nrf_gpio_pin_toggle(PIN_LED); } int main(void) // THIS VERSION WORKS FINE { nrf_gpio_cfg_output(PIN_LED); nrf_gpio_pin_set(PIN_LED); // LED is off // Irq setup NVIC_SetPriority(RTC0_IRQn, 15); // Lowes priority NVIC_ClearPendingIRQ(RTC0_IRQn); NVIC_EnableIRQ(RTC0_IRQn); // Start LFCLK clock nrf_clock_lf_src_set(NRF_CLOCK_LFCLK_RC); // 32KHz RC nrf_clock_task_trigger(NRF_CLOCK_TASK_LFCLKSTART); // Set prescaler to the max value (12-bit) // -> 8Hz counter frequency nrf_rtc_prescaler_set(NRF_RTC0,(1<<12) -1); nrf_rtc_event_enable(NRF_RTC0, NRF_RTC_INT_TICK_MASK); /* yes INT mask must be used here */ nrf_rtc_int_enable(NRF_RTC0,NRF_RTC_INT_TICK_MASK); nrf_rtc_task_trigger(NRF_RTC0,NRF_RTC_TASK_START); while(1) { __WFI(); }; } #endif #if RTC_USE_EVENT int main(void) // THIS VERSION FAILS { nrf_gpio_cfg_output(PIN_LED); nrf_gpio_pin_set(PIN_LED); // LED is off // Start LFCLK clock nrf_clock_lf_src_set(NRF_CLOCK_LFCLK_RC); // 32KHz RC nrf_clock_task_trigger(NRF_CLOCK_TASK_LFCLKSTART); // Set prescaler to the max value (12-bit) // -> 8Hz counter frequency nrf_rtc_prescaler_set(NRF_RTC0,(1<<12) -1); nrf_rtc_event_enable(NRF_RTC0, NRF_RTC_INT_TICK_MASK); /* yes INT mask must be used here */ nrf_rtc_task_trigger(NRF_RTC0,NRF_RTC_TASK_START); while(1) { if (nrf_rtc_event_pending(NRF_RTC0, NRF_RTC_EVENT_TICK)) { // __WFE could be a NOP()--so you have to check nrf_rtc_event_clear(NRF_RTC0,NRF_RTC_EVENT_TICK); irq_counter++; // every 8 IRQs, we toggle the led -> 1Hz rate if(irq_counter %8 == 0) nrf_gpio_pin_toggle(PIN_LED); } __WFE(); // If you replace this with __NOP() things work fine--so events are triggering }; } #endif
