I can see in Segger Embedded Studio v4.52 under the Build Tab, there are two methods to build the project.
1- Build > Build zephyr/zephyr.elf
2- Build > Build solution
What is the difference between the two methods?
Kind regards
Kind regards
Hi!
Let me answer these questions first:
1. In the overlay and dts files, comments are added with "// Comment" or for multiple lines "/* Comment 1 \n Comment 2 */".
The comment sign "#" is used for configuration files like prj.conf and KConfig files.
2. Yes, node-name@... means there should be some unit-address in "..." but this depends on the SoC which is why it's not included.
I'm still working on getting some more info about the ADC peripheral.
Learner said:Why can't I use the "nordic,nrf-saadc" driver since it is the native nordic adc driver?
This is what I was told by one of the developers. We can't use it because it's only made to instantiate the ADC peripheral, and that's not what this node is. I can try to find a better explanation for this.
Do you just want a way to get the raw a2d results? You can take a look at this sample code which shows how to get raw ADC data.
The light controller example that you were working with also demonstrates how to get raw ADC data from an analog input.
The reason this is complicated is that we are trying to do it through an overlay file and there is very little sample code available, as it seems this isn't the common way to do it.
Learner said:ADC raw (LSB) conversion results: ----------------------------------------------
What is this? Is this from the log file?
Heidi
Hi Heidi,
I may not always get the answer I am looking for but I do appreciate your efforts. A big THANK YOU.
Yes, I did see examples using the adc peripheral but they all use the #define and DT_ macros. I thought since almost every other hardware configuration can be done via the overlay file it would be a neat way to get the adc peripheral configured in the same way. If nordic/zephyr experts think that this is not the way to go about it then it is fine but they must let users like me know as early as possible so that no time is wasted. I may have to drop the idea of using the overlay file for the adc peripheral, which is a shame because I think it is a neater way.
Yes, I was expecting to get raw (LSB) values that I can then process/scale in my firmware. So, the "nordic,nrf-saadc" should provide that.
Please do. I cannot believe nordic do not provide a driver for their ad peripheral...
No, this is just me trying to make my post more readable and break it into sections to make life easier for the support staff like your good self.
Kind regards
Mohamed
Hi!
To get the raw ADC information, you don't need a device tree `[compatible]`, because this is just what the ADC driver returns. You only need this when there is external hardware-related information (like the resistance and capacitance of an RC-divider) that needs to be exposed to the code to convert a raw ADC reading into something meaningful. This is shown in the battery sample I have linked to previously.
The `[voltage-divider]` is intended to match the Linux binding with the same `[compatible]` name. I can't find a Linux compatible for "RC-divider" but if there is one try to use that instead.
Otherwise, users can create their own bindings and then use this as the `[compatible]`property. See the Zephyr Bindings documentation before you start writing it, for the file syntax and conventions, etc. Make sure to use a `[compatible]` that's namespaced to avoid conflict with other devicetree node identifiers; use something like `[companyname,rc-divider]`.
I spoke to one of the developers and he is going to try to write a binding and small sample for the HW setup you are using (the op-amp and RC-divider).
Learner said:Please do. I cannot believe nordic do not provide a driver for their ad peripheral...
Nordic definitely has a driver for the ADC peripheral, it's in zephyr/drivers/adc/adc_nrfx_saadc.c, and included in the general zephyr ADC driver here when CONFIG_ADC_NRFX_SAADC is enabled.
This driver is used in the battery sample here. This is what you will use in the main.c file, because not everything can be done in the device tree.
But we can wait for the binding and sample, and see if that helps you along!
Heidi
Thank you Heidi.
For now I will get rid of the overlay file and use the raw adc readings. I think this will be good enough for our application.
I am not sure what CHANNEL_INPUT adc configuration parameter. in the code fragment below does. The code has been extracted from
https://github.com/nrfconnect/sdk-zephyr/blob/master/tests/drivers/adc/adc_api/src/test_adc.c
#define ADC_1ST_CHANNEL_ID 0 Is this selecting analog input pin AIN0 i.e. port P0.04?
#define ADC_1ST_CHANNEL_INPUT NRF_SAADC_INPUT_AIN1 It is used to set .input_positive in struct adc_channel_cfg This equates to 2 but not sure what it does. What is the difference between CHANNEL_ID and CHANNEL_INPUT?
#define ADC_2ND_CHANNEL_ID 2 Is this selecting analog input pin AIN2 i.e. port P0.06?
#define ADC_2ND_CHANNEL_INPUT NRF_SAADC_INPUT_AIN2 It is used to set .input_positive in struct adc_channel_cfg This equates to 3 but not sure what it does. What is the difference between CHANNEL_ID and CHANNEL_INPUT?
Thank you
Kind regards
Mohamed
Hi!
https://github.com/pabigot/fw-nrfconnect-nrf/tree/sample/20201020a has the example in samples/myapp.
The README file has a lot of information.
This example shows how to represent analog input signals and associated hardware properties in a devicetree bindings. The described problem domain was for two analog inputs, one for an op-amp, one for an RC-divider.
There is a custom binding for the setup you described and it configures the ADC and reads the raw data. It also converts it to millivolts, but this may be useless depending on what you want to do.
________________________________________________________________________
Now onto your questions.
Learner said:#define ADC_1ST_CHANNEL_ID 0
This is just defining the first channel ID as zero and the second channel ID as 1.
Learner said:#define ADC_1ST_CHANNEL_INPUT NRF_SAADC_INPUT_AIN1
This is defining the first channel input as analog input 1 and the second channel input as analog input 2.
The real action happens a little lower down in the code, here:
static const struct adc_channel_cfg m_1st_channel_cfg = {
.gain = ADC_GAIN,
.reference = ADC_REFERENCE,
.acquisition_time = ADC_ACQUISITION_TIME,
.channel_id = ADC_1ST_CHANNEL_ID, // 0
#if defined(CONFIG_ADC_CONFIGURABLE_INPUTS)
.input_positive = ADC_1ST_CHANNEL_INPUT, // NRF_SAADC_INPUT_AIN1
So the descriptions of these two properties (`[channel_id]` and `[input positive]`) are explained in the definition of the adc_channel_cfg struct. I have pasted them below in cursive and then added clarifying comments for your specific case that are not in cursive but underlined.
channel_id: This value primarily identifies the channel within the ADC API - when a read request is done, the corresponding bit in the ´[channels]´ `[channels]´ field of the ´[adc_sequence]´ structure must be set to include this channel in the sampling. In the test_adc sample, this is done here or here.
For hardware that does not allow the selection of analog inputs for given channels, but rather have dedicated ones, this value also selects the physical ADC input to be used in the sampling.
Otherwise, when it is needed to explicitly select an analog input for the channel, or two inputs when the channel is a differential one, the selection is done in ´[input_positive]´ and ´[input_negative]´ fields. Since our hardware lets us explicitly select analog inputs, this is done here, to select NRF_SAADC_INPUT_AIN1.
Particular drivers indicate which one of the above two cases they support by selecting or not a special hidden Kconfig option named ADC_CONFIGURABLE_INPUTS. If this option is not selected, the macro CONFIG_ADC_CONFIGURABLE_INPUTS is not defined and consequently, the mentioned two fields are not present in this structure. This option is selected in the nrfx ADC driver here when you enable ADC_NRFX_SAADC.
While this API allows identifiers from range 0-31, particular drivers may support only a limited number of channel identifiers (dependent on the underlying hardware capabilities or configured via a dedicated Kconfig option). In our case, the nrfx ADC driver only allows 8 channels by setting ADC_NRFX_ADC_CHANNEL_COUNT to the range 1 to 8. This means channel_id has the range 0 to 7.
input_positive: Positive ADC input, This is a driver dependent value that identifies an ADC input to be associated with the channel. So, in our case, we are associating the ADC input NRF_SAADC_INPUT_AIN1 with the channel.
So the difference is that the ´[channel_id]´ is the index into the channel array (AIN1 has index 0, AIN2 has index 1 etc.) and ´[input_positive]´ (which is the channel input) is the specific analog input, so AIN1 and AIN2.
Another thing I wanted to clarify by using the custom binding of the sample as an example, is this line:
io-channels = <&adc 0>, <&adc 1>;
As you can see, the io-channels are ´[&adc 0]´ and ´[&adc 1]´ which maps the ADC peripheral to channel 0 and 1. This just maps the ADC node to the analog input of channel 0 and the analog input of channel 1, which is AIN1 and AIN2, which then maps to GPIO pin P0.04 and P0.05 on the PDK, according to this table describing the mapping of analog pins on the nRF5340 PDK.
So this mapping is a part of the hardware and isn't something the user needs to configure. The user just needs to configure the ADC node to specific channels in the range 0 to 7. So, for instance if you want to use AIN5 and AIN7 (which on the PDK is P0.07 and P0.26 respectively), you would need to define these io-channels.
io-channels = <&adc 4>, <&adc 6>;
Then due to the HW mapping of the board, these io-channels are GPIO pin 7 and GPIO pin 26.
This is something I just learned as well, which is why I haven't corrected it before.
Learner said:Is this selecting analog input pin AIN0 i.e. port P0.04?
So finally to answer this question, this line
´[#define ADC_1ST_CHANNEL_INPUT NRF_SAADC_INPUT_AIN1]´
along with this line
´[.input_positive = ADC_1ST_CHANNEL_INPUT]´
sets the ADC input to be the analog input AIN1 (i.e GPIO pin 0.04, though this connection exists in HW and isn't something we need to configure in SW).
I hope that was clarifying. Again sorry for sometimes coming with new and different information, but I am also learning along with you.
Heidi
