Build zephyr.elf versus Build solution
I can see in Segger Embedded Studio v4.52 under the Build Tab, there are two methods to build the project.
1- Build > Build zephyr/zephyr.elf
2- Build > Build solution
What is the difference between the two methods?
Kind regards
  • Thank you Heidi for your help.
    The spi1 node has a cs-gpios property, which means that the unit addresses for node a and b (0 and 1 respectively) are indexes into the cs-gpios array (an index representing the peripheral's chip select line number). The spi1 node has no cs-gpios, so node c has no chip select configured in the device tree, and therefore its unit address is left at 0 (if there is no chip select line, 0 is used).
    I can see what you are saying here. However, it is still rather confusing because looking at the definition of sub-node (a) and sub-node (c) they are identical but in fact they are telling us different information about the sub-node.
    * a: spi-dev-a@0 {
    * reg = <0>;
    * c: spi-dev-c@0 {
    * reg = <0>;
    This is the template you want to follow:
    This is how my overlay file looks,
    n: node {
    compatible = " ";
    io-channels = <&adc 4>;
    label = "AIN_0";
    &pwm0 {
    ch0-pin = < 29 >;
    The project now loads but I am getting build errors. I am including the build log and the devicetree_unfixed.h.
    The lower leg is not a resistor, but the other one is a resistor? Or are you using a capacitive divider where both elements are capacitors?
    Yes, the upper leg is a resistor and the lower leg is a capacitor.
    Kind regards
    Mohamed
  • If I include in main.c
    #include <hal/nrf_saadc.h>
    and use this overlay file
    &pwm0 {
       ch0-pin = < 29 >;
          n: node {
             compatible = "voltage-divider";
             label = "AIN_0";
    then I get a different error,
    devicetree error: 'output-ohms' is marked as required in 'properties:' in C:/Zypher/v1.3.0/zephyr/dts/bindings\adc\voltage-divider.yaml, but does not appear in <Node /node in 'nrf5340pdk_nrf5340_cpuapp.dts.pre.tmp'>
    This suggests I need to add these two lines to the device tree fragment in the overlay file
    output-ohms = <???>;
    full-ohms = <(??? + ???)>;
    But I am not sure if the "voltage-divider" works with an R-C circuit?
    Finally, get_binding() does not bind AIN_0, it can only bind ADC_0.
    Are you sure the label line can have something other than ADC_0?
    Maybe I Should make changes to the source code (the light intensity controller example) in main.c when I am using the overlay file ?
    Kind regards
    Mohamed
  • Hi!
     I agree that it might be confusing, but you cannot look at the unit-addresses of nodes alone, you always have to look at the unit-address in context to the parent node. And when you look at the parent node of sub-node a versus sub-node c it becomes clear that sub-node a's "0" means an index into the cs-gpios array and sub-node c's "0" is just "NULL".
    For the binding, I was wrong, you cannot just use the raw string as the argument. You need to use the following macros for the first and second IO-channel respectively:
    DT_IO_CHANNELS_LABEL_BY_IDX(DT_NODELABEL(n),0)
    DT_IO_CHANNELS_LABEL_BY_IDX(DT_NODELABEL(n),1)
    As for the issue with the voltage-divider, I am just as confused as you but I will ask around if anyone has any experience using it with the circuit you are using.
     What do you mean by this? I assume you will have to change the main.c file, firstly to bind the IO-channels.
    Heidi
  • Good morning Heidi,
    Yes, of course, to get the binding to work using the new labels with the DT_ macros.
    ADC raw (LSB) conversion results:        ----------------------------------------------
    I used ADC on various microcontrollers before and the ADC peripherals were straight forward to use and always provided raw (LSB) a2d results. Whys is it so complicated with this SoC/zephyr?
    Why can't I use the "nordic,nrf-saadc" driver since it is the native nordic adc driver?
    General questions:        ------------------------
    1- How can I add a comment in the overlay and dts files? I added few lines with a leading # but it caused problems. Does the # need to be in a particular location on a line?
    2- I sometimes see fragment of DeviceTree code containing this @... Does this mean the user has to replace the ... with a number?
    Thank you.
    Kind regards
    Mohamed
