What could explain a HardFault when entering in critical region?
We are developing an application which is using the app_scheduler (especially to put events etc.)
It seems that sometimes (very rarely) we detected a Hard Fault when the app_scheduler is calling the CRITICAL_REGION_ENTER() macro (into the app_scheduler.c). We have retrieved core registers when the panic appears:
  • The program counter pointed to "sd_nvic_critical_region_enter" from sdk/import/s110_nrf51822/include/nrf_soc.h line 474 where we can find the supervisor call in order to disable irq.
  • IPSR = 0x3 --> HardFault
Any ideas about what could induce this hard fault?
Thx!
  • Check if you are using APP_TIMER and if you have set RTC1 interrupt handler priority to APP_HIGH, then like RK said it will cause an hardfault in app_scheculer
    below m_evt_schedule_func = app_timer_evt_schedule (set in APP_TIMER_INIT macro)
    RTC1_IRQHandler->timer_timeouts_check()->timeout_handler_exec->m_evt_schedule_func->app_sched_event_put->CRITICAL_REGION_ENTER
  • good observation sebastien, there is a limitation on how you use CRITICAL_REGION_xx macro. You cannot use it when softdevice is disabled and have the macro SOFTDEVICE_PRESENT defined in your project. you can just use below when you are not using softdevice
    static uint32_t m_in_critical_region = 0;
    void critical_region_enter(void)
        __disable_irq();
        m_in_critical_region++;
    void critical_region_exit(void)
        m_in_critical_region--;
        if (m_in_critical_region == 0)
            __enable_irq();
    This code is also available in components\libraries\util\app_util_platform.c
        __disable_irq();
            __enable_irq();
