I have set up a Beacon with nrf52840 and SDK 17. The Beacon signal is transmitted in 10s interval. The Beacon transmitter does not need to receive any response data. The default Tx power of the Beacon signal is 0dbm. When I increased the Tx power to 8dbm, I checked the Beacon signal strength with an Iphone and nrf Connect app. I found that increasing the Tx power to 8dbm has almost no effect on the receive signal strength measured by the nrf Connect App of the Iphone.
So I am curious that:
1. If I increase the Beacon Tx power to 8dbm, will it increase the Beacon coverage distance?
2. If I use another nrf52840 with a strong antenna as a receiver (the claimed range is more than 1km), will this long distance receiver increase the receive range? Or the Beacon signal coverage has nothing to do with the receiver?
Thank you in advance:)
