i need to send 32 bits packet , someone help me to configurate radio ( radio_config.c) to be able to transmit this number of bits .
Check if this thread helps
The LFLEN is 4 bit long so you can achieve a maximum of 15 bit with it so if you set it to 0 and (i am not sure of this part) if you set STATLEN field to 4 bytes, then i guess it will fulfill your purpose. This is how it is done in radio transmit example. I think this should work
#define PACKET_LENGTH_FIELD_SIZE (0UL) /**< Packet length field size in bits. */
#define PACKET_STATIC_LENGTH (4UL) //!< Packet static length in bytes
please update this thread.
