APP_TIMER is not functioning.
Hello
Created in SDK v17 and simple_timer example.
I made a simple code to control the LED using a timer. Every 500 milliseconds, the LED turns on sequentially. LED ON and OFF works well when running one line at a time with debug, but the timer doesn't seem to be running.
In sdk_config.h, APP_TIMER_ENABLE is set to 1.
#include "app_timer.h"
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_delay.h"
#define TIMEOUT_VALUE                    50000                          /**< 50 mseconds timer time-out value. */
#define TOGGLE_LED_COUNTER               (500 / (TIMEOUT_VALUE / 1000)) /**< Interval for toggling a LED. Yields to 500 mseconds. */
#define STATE_TRANSIT_COUNTER_INIT_VALUE (4 * TOGGLE_LED_COUNTER)       /**< Initial value for the state transition counter.  */
#define GENERIC_DELAY_TIME               1000                           /**< Generic delay time used by application. */
APP_TIMER_DEF(m_timer_id);
void gpio_init(void)
  nrf_gpio_cfg_output(BSP_LED_0); //board_led1
  nrf_gpio_pin_set(BSP_LED_0);
  nrf_gpio_cfg_output(BSP_LED_1); //board_led2
  nrf_gpio_pin_set(BSP_LED_1);
  nrf_gpio_cfg_output(BSP_LED_2); //board_led3
  nrf_gpio_pin_set(BSP_LED_2);
  nrf_gpio_cfg_output(BSP_LED_3); //board_led4
  nrf_gpio_pin_set(BSP_LED_3);
char Move_LED[] = {BSP_LED_0, BSP_LED_1, BSP_LED_2, BSP_LED_3};
static void timer_handler(void * p_context)
    nrf_gpio_pin_toggle(BSP_LED_3);  //0.5 sec toggle
static void timers_init(void)
    ret_code_t err_code;
    // Initialize timer module.
    err_code = app_timer_init();
    err_code = app_timer_create(&m_timer_id,
                                APP_TIMER_MODE_SINGLE_SHOT, //SINGLE_SHOT or REPEATED //single shot timer
                                timer_handler);
static void timer_start()
    // Start application timers.
    err_code = app_timer_start(m_timer_id, APP_TIMER_TICKS(500), NULL); //0.5sec delay
static void move()
      for(int i=0; i<5; i++)
        nrf_gpio_pin_set(BSP_LED_0); //led off
        timer_start();
        nrf_gpio_pin_clear(BSP_LED_0);
        timer_start();
        nrf_gpio_pin_clear(BSP_LED_1);
        timer_start();
        nrf_gpio_pin_clear(BSP_LED_2);
        timer_start();
    /*for(int i=0; i<5; i++) //not output
      for(int j=0; j<3; j++)
        nrf_gpio_pin_set(Move_LED[i]);
        timer_start();
/**@brief Function for the Power Management.
static void power_manage(void)
    // Use directly __WFE and __SEV macros since the SoftDevice is not available.
    // Wait for event.
    __WFE();
    // Clear Event Register.
    __SEV();
    __WFE();
    timers_init();
    gpio_init();
    //move();
    for (;;)
        power_manage();
        move();
Can I know the problem?
Thank you.
  • Try activating LFCLK, the app timer uses the RTC peripheral, which runs on the LFCLK clock. You can use nrfx_clock to activate it. Or simply write NRF_CLOCK->TASKS_LFCLKSTART = 1.
  • Hello!
    Thank you for helping me.
    As you said, I've added parts about nrf_clock.  And I added nrf_drv_clock.c to nRF_Drivers, but the timer still doesn't work.
    This is the file list and path.
    ../../../config
    ../../../../../../components
    ../../../../../../components/boards
    ../../../../../../components/drivers_nrf/nrf_soc_nosd
    ../../../../../../components/libraries/atomic
    ../../../../../../components/libraries/atomic_fifo
    ../../../../../../components/libraries/balloc
    ../../../../../../components/libraries/bsp
    ../../../../../../components/libraries/button
    ../../../../../../components/libraries/delay
    ../../../../../../components/libraries/experimental_section_vars
    ../../../../../../components/libraries/log
    ../../../../../../components/libraries/log/src
    ../../../../../../components/libraries/memobj
    ../../../../../../components/libraries/ringbuf
    ../../../../../../components/libraries/scheduler
    ../../../../../../components/libraries/simple_timer
    ../../../../../../components/libraries/sortlist
    ../../../../../../components/libraries/strerror
    ../../../../../../components/libraries/timer
    ../../../../../../components/libraries/util
    ../../../../../../components/toolchain/cmsis/include
    ../../../../../../external/fprintf
    ../../../../../../integration/nrfx
    ../../../../../../integration/nrfx/legacy
    ../../../../../../modules/nrfx
    ../../../../../../modules/nrfx/drivers/include
    ../../../../../../modules/nrfx/hal
    ../../../../../../modules/nrfx/mdk
    ../config
    Code for newly added A in sdk_config.h.
    // <e> NRF_CLOCK_ENABLED - nrf_drv_clock - CLOCK peripheral driver - legacy layer
    #ifndef NRF_CLOCK_ENABLED
    #define NRF_CLOCK_ENABLED 1
    // <o> CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    // <131073=> External Low Swing
    // <196609=> External Full Swing
    #ifndef CLOCK_CONFIG_LF_SRC
    #define CLOCK_CONFIG_LF_SRC 1
    // <q> CLOCK_CONFIG_LF_CAL_ENABLED  - Calibration enable for LF Clock Source
    #ifndef CLOCK_CONFIG_LF_CAL_ENABLED
    #define CLOCK_CONFIG_LF_CAL_ENABLED 0
    // <o> CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef CLOCK_CONFIG_IRQ_PRIORITY
    #define CLOCK_CONFIG_IRQ_PRIORITY 6
    // </e>
    // <e> NRFX_CLOCK_ENABLED - nrfx_clock - CLOCK peripheral driver
    #ifndef NRFX_CLOCK_ENABLED
    #define NRFX_CLOCK_ENABLED 1
    // <o> NRFX_CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    #ifndef NRFX_CLOCK_CONFIG_LF_SRC
    #define NRFX_CLOCK_CONFIG_LF_SRC 1
    // <o> NRFX_CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef NRFX_CLOCK_CONFIG_IRQ_PRIORITY
    #define NRFX_CLOCK_CONFIG_IRQ_PRIORITY 6
    // <e> NRFX_CLOCK_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRFX_CLOCK_CONFIG_LOG_ENABLED
    #define NRFX_CLOCK_CONFIG_LOG_ENABLED 0
    // <o> NRFX_CLOCK_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRFX_CLOCK_CONFIG_LOG_LEVEL
    #define NRFX_CLOCK_CONFIG_LOG_LEVEL 3
    // <o> NRFX_CLOCK_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRFX_CLOCK_CONFIG_INFO_COLOR
    #define NRFX_CLOCK_CONFIG_INFO_COLOR 0
    // <o> NRFX_CLOCK_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRFX_CLOCK_CONFIG_DEBUG_COLOR
    #define NRFX_CLOCK_CONFIG_DEBUG_COLOR 0
    I also attached the sdk_config.h.
    Is there anything else I need to add or change to use the app_timer?
    Thank you.config.zip
  • Are you calling init and start on the nrf_drv_clock? There are a lot of examples that use it, examples/peripheral/wdt is one.
  • Thank you, Jimmie!
    By adding 'NRF_CLOCK-> TASKS_LFCLKSTART = 1;' to the main(), the timer is now active.
    Can I ask you about other problems?
    The timer works fine, but I think there's a problem with the move() function that I created.
    I want to turn on LED 1,2,3 sequentially every 0.5 seconds and repeat it. So I used the timer like delay, but I think the method is wrong.
    static void move()
            //nrf_delay_ms(500);
            timer_start();
            //LED1->LED2->LED3->LED OFF (loop)
            timer_start();
            timer_start();
            timer_start();
    int main()
        for(;;)
            move();
    If I do this, LED1,2,3 will remain on. It doesn't move as set. The timer is running every half a second as set.
    What do you think about this?
    Thank you again.
