Flash Memory Issue
I have written these 3 functions to erase/read and write.
/////////////////////////////////////////////////////////////////////////////// SNV
const uint32_t f_addr = 0x000FF000; // Last page start address 255
// Create a pointer to that address
uint32_t * p_addr = (uint32_t *)f_addr; //cast f_addr to a pointer
uint32_t erase_SNV()
    NRF_LOG_INFO("Memory Erased");
    return sd_flash_page_erase(255);
uint32_t write_SNV(int address,uint8_t value)
    uint32_t val;
    val=value;
    NRF_LOG_INFO("Data Write in Flash");
    ret_code_t err_code;
    err_code = sd_flash_write(p_addr+address, &val, sizeof(val));
    return err_code;
uint32_t read_SNV(int address)
     NRF_LOG_INFO("The Data read from flash is: %d", *(p_addr)+address);
     return *(p_addr)+address;
When I write any value from address 1 it gives following wrong output(0 1 2 3).
    write_SNV(1,11);
    read_SNV(1);
    write_SNV(2,12);
    read_SNV(2);
    write_SNV(3,13);
    read_SNV(3);
  //  read_SNV(0);
    read_SNV(1);
    read_SNV(2);
    read_SNV(3);
But When I start address from 0 it gives the right values.
    write_SNV(0,10);
    read_SNV(0);
    write_SNV(1,11);
    read_SNV(1);
    write_SNV(2,12);
    read_SNV(2);
    write_SNV(3,13);
    read_SNV(3);
    read_SNV(0);
    read_SNV(1);
    read_SNV(2);
    read_SNV(3);
How can I save values in rondom addresses?
Thanks!
  • Look at the header file (.h file) that declares (not defines, declares) the function that writes to flash. Do you find anything there that you can use to read?
    Yes, I have found this function.
    ret_code_t nrf_fstorage_read(nrf_fstorage_t const * p_fs,
                                 uint32_t               src,
                                 void                 * p_dest,
                                 uint32_t               len)
        NRF_FSTORAGE_PARAM_CHECK(p_fs,        NRF_ERROR_NULL);
        NRF_FSTORAGE_PARAM_CHECK(p_dest,      NRF_ERROR_NULL);
        NRF_FSTORAGE_PARAM_CHECK(p_fs->p_api, NRF_ERROR_INVALID_STATE);
        NRF_FSTORAGE_PARAM_CHECK(len,         NRF_ERROR_INVALID_LENGTH);
        /* Source addres must be word-aligned. */
        NRF_FSTORAGE_PARAM_CHECK(addr_is_aligned32(src),                NRF_ERROR_INVALID_ADDR);
        NRF_FSTORAGE_PARAM_CHECK(addr_is_within_bounds(p_fs, src, len), NRF_ERROR_INVALID_ADDR);
        return (p_fs->p_api)->read(p_fs, src, p_dest, len);
    Do you intend to ever update these values? Or do you write them once, and never update them?
    Yes, I have to update values again and again.
    Do you have any other flash dependent components in your application? Peer manager, for example, for storing bonding information? If so, this will take the top 3 pages of your flash (3*4096 bytes).
    Yes, I have enabled bonding.
    Do you plan to have a bootloader? If so, that will also use some space in the top of your flash, where the size depends on what bootloader you are using.
    Yes, I have to add a secure bootloader in the future.
    If the answer to all of the questions above is no, then you can use for example 0x000FF000.
    Now from what address I should start save values? Nerd
  • I could tell you an address. You should use the page below the FDS pages that the peer manager uses. The peer manager uses the pages directly below the bootloader, so you should use the address of the page below the that again. E.g:
    IF your bootloader starts at 0x000F8000, then you will have the FDS pages (used by the peer manager) at:
    0x000F7000 -> 0x000F7FFF,
    0x000F6000 -> 0x000F6FFF, and
    0x000F5000 -> 0x000F5FFF
    So you can for example use the page
    0x000F4000 -> 0x000F4FFF for your flash data.
    Remember to set aside an extra page of reserved data in your bootloader. Let me know when you start on that what SDK version you are using and I can tell you the variable you need to change.
    Also let me know if you have changed the number of flash pages used by FDS. By default it is 3 in our examples.
    How do you intend to update the flash data? Perhaps you can explain how you intend to do it. Hint: Before erasing an entire page, you can only change bits in flash from 1's to 0's.
    BR,
    Edvin
  • Hi
     I am using nRF5SDK17009d13099 SDK.
    I think I didn't change any page.
    I am trying to use the example flash_fstorage. I am using the following command to read the value from flash but getting the following values shown in the screenshot.
        NRF_LOG_INFO("Writing \"%s\" to flash.", m_hello_world);
        rc = nrf_fstorage_write(&fstorage, 0x3f000, m_hello_world, sizeof(m_hello_world), NULL);
        APP_ERROR_CHECK(rc);
        wait_for_flash_ready(&fstorage);
        NRF_LOG_INFO("Done.");
        rc = nrf_fstorage_read(&fstorage, 0x3f000, m_hello_world_f, sizeof(m_hello_world_f));
        for(int i=0;i<sizeof(m_hello_world_f);i++)
         NRF_LOG_INFO("Read Data : %c",m_hello_world_f[i]);
    Is there any simple file where I can just call read/write functions to save/read from flash?
    Thanks!
  • I guess there is something in that flash area already. Are you running the unmodified flash_fstorage example, or did you add it to another project?
    Try to comment out the nrf_fstorage_write() and see what it prints if you don't write anything. Also, %c will only print characters if it is an ascii value. Try to print using %02x:
    If it doesn't print FF for all the values, it means that the flash is not empty. Also, you can use NRF_LOG_RAW_INFO(); if you don't want the linefeed after every char:
        NRF_LOG_INFO("Reading from flash hex:");
        for(uint8_t i=0; i<sizeof(m_hello_world); i++)
            NRF_LOG_RAW_INFO("%02x:", m_hello_world[i]);
        NRF_LOG_RAW_INFO("\r\n");
        NRF_LOG_INFO("Reading from flash char:");
            NRF_LOG_RAW_INFO("%c", m_hello_world[i]);
        NRF_LOG_INFO("done");
    I suspect that there is some data in that flash area before you try to write to it. As I mentioned, writing to flash can only change 1's to 0's, so you need to erase the page first. Try using "nrfjprog --eraseall" befoe programming the example. Also, if you add things to your project, then the address 0x3F000 may already be used by the application .hex file.
    Regarding everything else: So you are using SDK17, and you use the peer manager. Look at the sdk_config.h file of the project that uses the peer manager, and search for FDS_VIRTUAL_PAGES. This sets the number of FDS pages. By default it is 3.
    The secure_bootloader\pca10056_s140_ble bootloader has a flash start address of 0xf8000. So if you use this one, then it means that the FDS pages are on 0xF7000, 0xF6000 and 0xF5000. You can use 0xF4000->0xF4FFF.
    In your bootloader project, when you get this far, check it's sdk_config.h file. Look for NRF_DFU_APP_DATA_AREA_SIZE.
    This is the parameter saying how much of the flash beneath the bootloader that is reserved for application flash use, and this area will not be overwritten during a DFU.
    By default it is set to 12288. This is the number of bytes that are protected. One flash page is 4096 bytes long, so this corresponds to 3 pages (the FDS pages). If you want to add another page for custom data, please increase this number by 4096.
    BR,
    Edvin
    I am using the unmodified flash_fstorage example.
    Here is the data I have read after implementing your code part.
