in my project I have a custom board with a nRF52832 chip, which reads 4 channels with a sample rate of 1kHz (1ms). The SAADC readings get transmitted to a nRF52840DK via NUS every 40ms. Overall, this setup works fine and I receive the right SAADC readings.
But I noticed something weird. I configured a sample rate of 1kHz, so I should get 1000 values for each channel every second. But my real sample rate is about 1.020 kHz, so I get about 1020 values for each channel every second.
This is how my SAADC is configured:
#define SAADC_SAMPLES_IN_BUFFER 4 #define SAADC_SAMPLE_RATE 1 void saadc_sampling_event_init(void) { ret_code_t err_code; err_code = nrf_drv_ppi_init(); APP_ERROR_CHECK(err_code); nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG; timer_config.frequency = NRF_TIMER_FREQ_31250Hz; err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler); APP_ERROR_CHECK(err_code); /* setup m_timer for compare event */ uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer,SAADC_SAMPLE_RATE); nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false); nrf_drv_timer_enable(&m_timer); uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0); uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get(); /* setup ppi channel so that timer compare event is triggering sample task in SAADC */ err_code = nrf_drv_ppi_channel_alloc(&m_ppi_channel); APP_ERROR_CHECK(err_code); err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr); APP_ERROR_CHECK(err_code); } void saadc_sampling_event_enable(void) { ret_code_t err_code = nrf_drv_ppi_channel_enable(m_ppi_channel); APP_ERROR_CHECK(err_code); } void saadc_init(void) { ret_code_t err_code; nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG; saadc_config.resolution = NRF_SAADC_RESOLUTION_10BIT; nrf_saadc_channel_config_t channel_0_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4); channel_0_config.gain = NRF_SAADC_GAIN1_4; channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4; nrf_saadc_channel_config_t channel_1_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5); channel_1_config.gain = NRF_SAADC_GAIN1_4; channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4; nrf_saadc_channel_config_t channel_2_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6); channel_2_config.gain = NRF_SAADC_GAIN1_4; channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4; nrf_saadc_channel_config_t channel_3_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7); channel_3_config.gain = NRF_SAADC_GAIN1_4; channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4; err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_channel_init(0, &channel_0_config); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_channel_init(1, &channel_1_config); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_channel_init(2, &channel_2_config); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_channel_init(3, &channel_3_config); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); } void saadc_callback(nrf_drv_saadc_evt_t const * p_event) { if (p_event->type == NRF_DRV_SAADC_EVT_DONE) { ret_code_t err_code; // set buffers err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); ... } }
So here are my questions:
1. Why is the real sample rate is a bit higher than the configured sample rate?
2. Do you have any suggestions how to solve this issue?
Setup: nRF5_SDK_17.0.0_9d13099, Softdevice s132 on custom nRF52832 chip
Thank you very much in advance.
