SAADC - Real sample rate is a bit higher than the configured sample rate
in my project I have a custom board with a nRF52832 chip, which reads 4 channels with a sample rate of 1kHz (1ms). The SAADC readings get transmitted to a nRF52840DK via NUS every 40ms. Overall, this setup works fine and I receive the right SAADC readings.
But I noticed something weird. I configured a sample rate of 1kHz, so I should get 1000 values for each channel every second. But my real sample rate is about 1.020 kHz, so I get about 1020 values for each channel every second.
This is how my SAADC is configured:
#define SAADC_SAMPLES_IN_BUFFER         4
#define SAADC_SAMPLE_RATE               1
    ret_code_t err_code;
    nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
    timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
    err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler);
    /* setup m_timer for compare event */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer,SAADC_SAMPLE_RATE);
    nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
    uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
void saadc_init(void)
    nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
    saadc_config.resolution = NRF_SAADC_RESOLUTION_10BIT;
    nrf_saadc_channel_config_t channel_0_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
    channel_0_config.gain = NRF_SAADC_GAIN1_4;
    channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_1_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
    channel_1_config.gain = NRF_SAADC_GAIN1_4;
    channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_2_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
    channel_2_config.gain = NRF_SAADC_GAIN1_4;
    channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_3_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7);
    channel_3_config.gain = NRF_SAADC_GAIN1_4;
    channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4;
    err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
    err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
    err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
    err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
        // set buffers
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
So here are my questions:
1. Why is the real sample rate is a bit higher than the configured sample rate?
2. Do you have any suggestions how to solve this issue?
Setup: nRF5_SDK_17.0.0_9d13099, Softdevice s132 on custom nRF52832 chip
Thank you very much in advance.
