Unable to boot SLM applicationwith MUCBooot enabled
I am on ncs master branch, when i build and load the Serial LTE Modem(SLM) application the application struck at mcuboot
The only additional configuration option i enabled in side the project file is "CONFIG_BOOTLOADER_MCUBOOT=y"
*** Booting Zephyr OS build v2.3.0-rc1-ncs1  ***
[00:00:00.004,577] [0m<inf> mcuboot: Starting bootloader
[0m[00:00:00.012,725] [0m<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
[0m[00:00:00.026,092] [0m<inf> mcuboot: Boot source: none[0m
[00:00:00.033,355] [0m<inf> mcuboot: Swap type: none[0m
[00:00:00.377,380] [0m<inf> mcuboot: Bootloader chainload address offset: 0x10000[0m
[00:00:00.385,192] [0m<inf> mcuboot: Jumping to the first image slot[0m
regards
KK
  • Hi!
    I'm not able to reproduce this error.
    I added "CONFIG_BOOTLOADER_MCUBOOT=y" to prj.conf in ncs/nrf/applications/serial_lte_modem and built it on the master branch of NCS and this was my log. I see "Ready" at the end, which means the application has begun.
    *** Booting Zephyr OS build v2.3.0-rc1-ncs1-3624-gd14bfb6a9e06  ***
    [00:00:00.338,348] [0m<inf> mcuboot: Starting bootloader
    [00:00:00.344,696] [0m<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:00:00.354,797] [0m<inf> mcuboot: Boot source: none
    [00:00:00.360,321] [0m<inf> mcuboot: Swap type: none
    [00:00:00.630,004] [0m<inf> mcuboot: Bootloader chainload address offset: 0x10000
    [00:00:00.637,786] [0m<inf> mcuboot: Jumping to the first image slot
    Ready
    I attached the merged.hex file for you to try on your device. I built it for nrf9160dk_nrf9160ns.
    0435.merged.hex
    Heidi
  • Hi Heidi,
    Not sure whats the issue, when i did a clean build by deleting the previous build directory things started working
    regards
    kk
