How to use nrf_drv_saadc_calibrate_offset function? (negative saadc value problem)
Hello.
I am testing saadc function.
When I was connect the saadc pin with ground level, the saadc value represents negative value.
So I am searching the similar problem and I found the calibration is one method.
However, I don't know how to use the calibrate function.
I added the code like below, and I can't build the project.
   err_code = nrf_drv_saadc_calibrate_offset();
How can I added this function ? and Is there any other method can I test to remove negative saadc value ?
Thank you for reading my questions.
Best Regards,
Yclee.
