Whitelist implement in ble_app_uart, code crash with error code 4.
I am using nrf52810 ,softdevice 132.
I am trying to implement whitelist in ble_app_uart code (peripheral side).I take reference from HID mouse example.
Code compiled successfully but it when i am trying to connect with central it crashed and board reboot. I try to debug the code it shows Error code 4 .
MINICOM LOGS:
<info> app_timer: RTC: initialized.
<info> app: peer_manager_init
<info> app: Debug logging for UART over RTT started.
<info> app:     m_whitelist_peer_cnt 1, MAX_PEERS_WLIST 8
<info> app: on_adv_evt || ble_adv_evt 7
<info> app: BLE_ADV_EVT_WHITELIST_REQUEST
<info> app: identities_set
<info> app: on_adv_evt || ble_adv_evt 3
<info> app: Fast advertising.
<info> app: advertising_start
<error> app: Fatal error
<warning> app: System reset
DEBUG LOG:
void app_error_handler_bare(unsigned int error_code 0x00000004)
Please find the code having changes of whitelist.
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_fstorage.h"
#include "ble_err.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                1000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   20                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(3000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define SEC_PARAM_BOND                      1                                          /**< Perform bonding. */
#define SEC_PARAM_MITM                      0                                          /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      0                                          /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS                  0                                          /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                       /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                          /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                          /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                         /**< Maximum encryption key size. */
//bool erase_bonds = true;
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static pm_peer_id_t      m_peer_id;                                 /**< Device reference handle to the current bonded central. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
static void advertising_start(bool erase_bonds);
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
//add
void whitelist_set(pm_peer_id_list_skip_t skip)
pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
    ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
    NRF_LOG_INFO("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
                   peer_id_count + 1,
                   BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
    err_code = pm_whitelist_set(peer_ids, peer_id_count);
static void identities_set(pm_peer_id_list_skip_t skip)
    pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
    err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
    NRF_LOG_INFO("identities_set\r\n");
static void delete_bonds(void)
    ret_code_t err_code;
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
    printf("delete bond\r\n");
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    NRF_LOG_INFO("pm_evt_handler || p_evt->evt_id %d \r\n",p_evt->evt_id);
     switch (p_evt->evt_id)
        case PM_EVT_CONN_SEC_SUCCEEDED:
            m_peer_id = p_evt->peer_id;
            advertising_start(false);
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            if (     p_evt->params.peer_data_update_succeeded.flash_changed
                 && (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
                NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
                // Note: You should check on what kind of white list policy your application should use.
                whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    //add
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HID_MOUSE);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    cp_init.evt_handler                    = NULL;//NULL;//on_conn_params_evt;
    // Prepare wakeup buttons.
NRF_LOG_INFO("on_adv_evt || ble_adv_evt %d\r\n",ble_adv_evt);
switch (ble_adv_evt)
case BLE_ADV_EVT_DIRECTED_HIGH_DUTY:
         NRF_LOG_INFO("Directed advertising.");
         err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_DIRECTED);
case BLE_ADV_EVT_FAST:
         NRF_LOG_INFO("Fast advertising.");
#if SWIFT_PAIR_SUPPORTED == 1
           err_code = ble_advertising_advdata_update(&m_advertising, &m_sp_advdata_buf, false);
case BLE_ADV_EVT_SLOW:
          NRF_LOG_INFO("Slow advertising.");
          err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
case BLE_ADV_EVT_FAST_WHITELIST:
         NRF_LOG_INFO("Fast advertising with whitelist.");
         err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
case BLE_ADV_EVT_SLOW_WHITELIST:
          NRF_LOG_INFO("Slow advertising with whitelist.");
case BLE_ADV_EVT_IDLE:
        sleep_mode_enter();
case BLE_ADV_EVT_WHITELIST_REQUEST:
             NRF_LOG_INFO("BLE_ADV_EVT_WHITELIST_REQUEST\r\n");
            ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            ble_gap_irk_t  whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            uint32_t       addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            uint32_t       irk_cnt  = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                                        whitelist_irks,  &irk_cnt);
            NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
                          addr_cnt, irk_cnt);
            // Set the correct identities list (no excluding peers with no Central Address Resolution).
            identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
// Apply the whitelist.
            err_code = ble_advertising_whitelist_reply(&m_advertising,
                                                       whitelist_addrs,
                                                       addr_cnt,
                                                       whitelist_irks,
                                                       irk_cnt);
           // NRF_LOG_INFO("err_code %d\r\n",err_code);
case BLE_ADV_EVT_PEER_ADDR_REQUEST:
            pm_peer_data_bonding_t peer_bonding_data;
            // Only Give peer address if we have a handle to the bonded peer.
            if (m_peer_id != PM_PEER_ID_INVALID)
                err_code = pm_peer_data_bonding_load(m_peer_id, &peer_bonding_data);
                if (err_code != NRF_ERROR_NOT_FOUND)
                    // Manipulate identities to exclude peers with no Central Address Resolution.
                    identities_set(PM_PEER_ID_LIST_SKIP_ALL);
                    ble_gap_addr_t * p_peer_addr = &(peer_bonding_data.peer_ble_id.id_addr_info);
                    err_code = ble_advertising_peer_addr_reply(&m_advertising, p_peer_addr);
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    NRF_LOG_INFO("peer_manager_init\r\n");
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
  /*      case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
             Pairing not supported
             No system attributes have been stored.
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    printf("**********");
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
static void ble_advertising_error_handler(uint32_t nrf_error)
         uint32_t err_code;
         uint8_t                adv_flags;
        ble_advertising_init_t init;
 adv_flags                            = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = adv_flags;
    //init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    //init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_whitelist_enabled = true;
init.config.ble_adv_directed_high_duty_enabled = true;
init.config.ble_adv_fast_enabled = true;
 init.config.ble_adv_directed_enabled           = false;
init.config.ble_adv_directed_interval          = 0;
init.config.ble_adv_directed_timeout           = 0;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
// init.config.ble_adv_slow_enabled = true;
// init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
// init.config.ble_adv_slow_timeout = APP_ADV_SLOW_DURATION;
init.error_handler = ble_advertising_error_handler;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        APP_ERROR_CHECK(ret);
        NRF_LOG_INFO("advertising_start\r\n");
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
   // uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    //advertising_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
   // timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
What is the issue in my code and how to resolve it.
Thanks in advance!
  • Hi Kenneth,
    Here are my minicom logs:
    <error> app: ERROR 4 [NRF_ERROR_NO_MEM]
     at /home/meghna/Desktop/DeviceDownload/nRF5_SDK_17.0.0_9d13099 (4)/components/softdevice/common/nrf_sdh.c:391
    PC at: 0x0003C8EB
    <error> app: End of error report
    FILE nrf_sdh.c : line number 391:
           void SD_EVT_IRQHandler(void)
    391:    ret_code_t ret_code = app_sched_event_put(NULL, 0, appsh_events_poll);
               APP_ERROR_CHECK(ret_code);
    How to solve the error of sched_event?
  • Hi Kenneth,
    I just resolve the issue by adding  scheduler_init() api as attatched below.
    Now Board is able to advertise and there is no error is coming but still not able to connect central .
     static void scheduler_init(void)
        APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
        bool erase_bonds;
        // Initialize.
       // uart_init();
        log_init();
        timers_init();
        ble_stack_init();
       //add
        scheduler_init();
        gap_params_init();
    /** @file
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "app_scheduler.h"
    #include "fds.h"
    #define SCHED_MAX_EVENT_DATA_SIZE       APP_TIMER_SCHED_EVENT_DATA_SIZE             /**< Maximum size of scheduler events. */
    #define SCHED_QUEUE_SIZE                10
    //#define SEC_PARAM_BOND                      1                                          /**< Perform bonding. */
    //#define SEC_PARAM_MITM                      0                                          /**< Man In The Middle protection not required. */
    //#define SEC_PARAM_LESC                      0                                          /**< LE Secure Connections not enabled. */
    //#define SEC_PARAM_KEYPRESS                  0                                          /**< Keypress notifications not enabled. */
    //#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                       /**< No I/O capabilities. */
    //#define SEC_PARAM_OOB                       0                                          /**< Out Of Band data not available. */
    ///#define SEC_PARAM_MIN_KEY_SIZE              7                                          /**< Minimum encryption key size. */
    //#define SEC_PARAM_MAX_KEY_SIZE              16                                         /**< Maximum encryption key size. */
    #define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
    #define CONNECTED_LED                   BSP_BOARD_LED_1
    //add_button
    uint8_t len = 1;
    uint8_t key;
    bool advt_val = false;
    uint32_t periph_link_cnt;
    uint8_t save_data_len = 0;
    uint8_t save_data_buff[10];
    //add
    NRF_BLE_QWRS_DEF(m_qwrs, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                                              /**< Context for the Queued Write module.*/
    //add_button
    ////static void advertising_start(void);
    //void button_status_send_to_all(uint8_t key);
    //add
    static void whitelist_set(pm_peer_id_list_skip_t skip)
                       peer_id_count + 1,
        uint32_t                err_code;
        //add
            uint32_t err_code;
                do
        uint32_t           err_code;
        // Initialize NUS.
        uint32_t err_code;
             //err_code = bsp_indication_set(BSP_INDICATE_IDLE);
            //APP_ERROR_CHECK(err_code);
          //  sleep_mode_enter();
                              addr_cnt, irk_cnt);
                                                           whitelist_addrs,
                                                           addr_cnt,
                                                           whitelist_irks,
                                                           irk_cnt);
        ble_conn_state_conn_handle_list_t conn_handles = ble_conn_state_periph_handles();
        for (uint8_t i = 0; i < conn_handles.len; i++)
            err_code = ble_nus_data_send(&m_nus,&key,&len,conn_handles.conn_handles[i]);
            if (err_code != NRF_SUCCESS &&
                err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                err_code != NRF_ERROR_INVALID_STATE &&
                err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                //NRF_LOG_DEBUG("Sent button change 0x%x on connection handle 0x%x.", button_action, conn_handles.conn_handles[i]);
        if(conn_handles.len == 0)
          printf("saving key in buffer to send later\r\n");
          save_data_buff[save_data_len++] = key;
        return NRF_SUCCESS;
    static void on_connected(const ble_gap_evt_t * const p_gap_evt)
        uint32_t    periph_link_cnt = ble_conn_state_peripheral_conn_count(); // Number of peripheral links.
        advt_val = false;
        NRF_LOG_INFO("Connection with link 0x%x established.", p_gap_evt->conn_handle);
        // Assign connection handle to available instance of QWR module.
        for (uint32_t i = 0; i < NRF_SDH_BLE_PERIPHERAL_LINK_COUNT; i++)
            if (m_qwrs[i].conn_handle == BLE_CONN_HANDLE_INVALID)
                err_code = nrf_ble_qwr_conn_handle_assign(&m_qwrs[i], p_gap_evt->conn_handle);
    //    err_code = app_button_enable();
    //  //  APP_ERROR_CHECK(err_code);
    //    // Update LEDs
        bsp_board_led_on(CONNECTED_LED);
        if (periph_link_cnt == NRF_SDH_BLE_PERIPHERAL_LINK_COUNT)
            bsp_board_led_off(ADVERTISING_LED);
        //else
    //        // Continue advertising. More connections can be established because the maximum link count has not been reached.
    ////        advertising_start();
    static void on_disconnected(ble_gap_evt_t const * const p_gap_evt)
        //advt_val = false;
        NRF_LOG_INFO("Connection 0x%x has been disconnected. Reason: 0x%X",
                     p_gap_evt->conn_handle,
                     p_gap_evt->params.disconnected.reason);
        if (periph_link_cnt == 0)
            bsp_board_led_off(CONNECTED_LED);
           // err_code = app_button_disable();
        if (periph_link_cnt == (NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - 1))
            // Advertising is not running when all connections are taken, and must therefore be started.
       /* sec_param.bond           = SEC_PARAM_BOND;
          sec_param.bond = true;
          sec_param.mitm = false;
          sec_param.lesc = 0;
          sec_param.keypress = 0;
          sec_param.io_caps = BLE_GAP_IO_CAPS_NONE;
          sec_param.oob = false;
          sec_param.min_key_size = 7;
          sec_param.max_key_size = 16;
        uint32_t err_code;
            case BLE_GAP_EVT_ADV_SET_TERMINATED :
                  printf("BLE_GAP_EVT_ADV_SET_TERMINATED\r\n");
                  advt_val = false;
                NRF_LOG_INFO("connected\r\n");
                on_connected(&p_ble_evt->evt.gap_evt);
                printf("BLE_GAP_EVT_DISCONNECTED\r\n");
                on_disconnected(&p_ble_evt->evt.gap_evt);
            } break;
        uint32_t err_code;
        //printf("**********");
      /*  printf("periph_link_cnt %d\r\n",periph_link_cnt);
        if(periph_link_cnt < 2 && advt_val == false)
        printf("first advertsing\r\n");
        //advertising_start(true);
       // nrf_delay_ms(2000);
        advt_val = true;
        switch (event)
                sleep_mode_enter();
              case BSP_EVENT_KEY_0 :
               uint8_t key = 'a';
              //printf("keysss %s",key);
              button_status_send_to_all(key);
            //case BSP_EVENT_KEY_1 :
            //   key = 'b';
            //   button_status_send_to_all(key);
            //   //printf("send key %c\r\n",key);
            //  break;
            // case BSP_EVENT_KEY_2 :
            //      uint8_t key = 'k';
            //      break;
            //  case BSP_EVENT_KEY_3 :
            //      uint8_t key = 'd';
            //      break;
        uint32_t       err_code;
                index++;
                    if (index > 1)
                        do
                    index = 0;
    #else
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
             uint32_t err_code;
             uint8_t                adv_flags;
        //err_code = bsp_event_to_button_action_assign(0, BSP_BUTTON_ACTION_PUSH, BSP_EVENT_KEY_0);
        //err_code = bsp_event_to_button_action_assign(1, BSP_BUTTON_ACTION_PUSH, BSP_EVENT_KEY_1);
        //err_code = bsp_event_to_button_action_assign(2, BSP_BUTTON_ACTION_PUSH, BSP_EVENT_KEY_2);
        //err_code = bsp_event_to_button_action_assign(3, BSP_BUTTON_ACTION_PUSH, BSP_EVENT_KEY_3);
            nrf_pwr_mgmt_run();
            delete_bonds();
        bool erase_bonds;
        // Initialize.
       // uart_init();
        log_init();
        timers_init();
        ble_stack_init();
        scheduler_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
       // timers_start();
        // Enter main loop.
        for (;;)
    Can u please tell me what's wrong in my code ?
  • not able to connect central
    So what happens when the Central attempts to connect?
    where is it failing?
  • Hi Awneil
    When i run code in build and debug mode,its not failing anywhere . nrf_app try to connect with peripheral for approx 30 sec then automatically disconnect.
    I am not getting where its failing and how to find what's the issue as no error is coming.
    Meghna
  • HI Awneil
    Today i again port HID mouse code in ble_app_uart code . If i am not wrong once connection established the central mac should be saved in peripheral and when we reboot the peripheral whitelist count is updated and now peripheral should advertise with whitelist .But i my case,I am able to connect Peripheral with central but when i reboot device then there is not update in whitelist count and its advertising normally.
    Here is my ble_app_uart(main.c) file with whitelist changes:
    /** @file
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "fds.h"
    #include "ble_conn_state.h"
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define APP_ADV_FAST_INTERVAL           0x0028                                      /**< Fast advertising interval (in units of 0.625 ms. This value corresponds to 25 ms.). */
    #define APP_ADV_SLOW_INTERVAL           0x00A0                                      /**< Slow advertising interval (in units of 0.625 ms. This value corresponds to 100 ms.). */
    #define APP_ADV_FAST_DURATION           3000                                        /**< The advertising duration of fast advertising in units of 10 milliseconds. */
    #define APP_ADV_SLOW_DURATION           18000
    uint8_t len = 1 ;
    //add
    #define QUEUE_FULL 1
    #define QUEUE_PARTIAL_FULL 2
    #define QUEUE_EMPTY 3
    #define QUE_LEN 30
    uint8_t arr[QUE_LEN];
    uint8_t top = 0 ,bottom = 0;
    uint8_t queue_status = QUEUE_EMPTY;
    //uint8_t g_key = 0;
    /**@brief Function for setting filtered whitelist.
     * @param[in] skip  Filter passed to @ref pm_peer_id_list.
                       peer_id_count + 1,
    /**@brief Function for setting filtered device identities.
    /**@brief Clear bond information from persistent storage.
            delete_bonds();
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    void enqueue(uint8_t key)
      if(queue_status == QUEUE_FULL)
        printf("\n Queue is full can not add more data");
        arr[top] = key;
        top++;
        if(top == QUE_LEN)
          top = 0;
        if(top == bottom)
          queue_status = QUEUE_FULL;
          queue_status = QUEUE_PARTIAL_FULL;
    //FIXME: dummy send
     // send_indication(&key,1);
    void dequeue(uint8_t *key)
         if(queue_status == QUEUE_EMPTY)
          printf("\n Nothing in queue");
          *key = arr[bottom];
          bottom++;
          if(top == bottom)
    //uint32_t send_indication(uint8_t *data, uint16_t len) {
    //    ble_gatts_hvx_params_t hvx_params;
    //    memset(&hvx_params, 0, sizeof(hvx_params));
    //    hvx_params.handle = custom_data_handle.value_handle;
    //    hvx_params.type   = BLE_GATT_HVX_INDICATION;
    //    hvx_params.offset = 0;
    //    hvx_params.p_len  = &len;
    //    hvx_params.p_data = data;
    //    return sd_ble_gatts_hvx(m_conn_handle, &hvx_params);
    /**@brief Function for handling Service errors.
    static void service_error_handler(uint32_t nrf_error)
    /**@brief Function for handling advertising errors.
        uint32_t                err_code;
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_REMOTE_CONTROL);
            uint32_t err_code;
                do
        uint32_t           err_code;
        // Initialize NUS.
        uint32_t err_code;
                m_sp_advdata.p_manuf_specific_data = NULL;
                err_code = ble_advertising_advdata_update(&m_advertising, &m_sp_advdata, NULL);
                sleep_mode_enter();
                               addr_cnt,
                               irk_cnt);
                                                           whitelist_addrs,
                                                           addr_cnt,
                                                           whitelist_irks,
                                                           irk_cnt);
                NRF_LOG_INFO("BLE_ADV_EVT_PEER_ADDR_REQUEST\r\n");
            } break;
    /*void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        uint32_t err_code;
        switch (event)
                sleep_mode_enter();
                  //enqueue();
                  uint8_t key = 0;
                  //uint8_t len = 1 ;
                  if(m_conn_handle != BLE_CONN_HANDLE_INVALID)
                  ble_nus_data_send(&m_nus,&key,&len,m_conn_handle);
                  uint8_t key = 1;
                  uint8_t key = 2;
                  uint8_t key = 3;
        uint32_t       err_code;
                index++;
                    if (index > 1)
                        do
                    index = 0;
    #else
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        uint8_t                adv_flags;
        init.advdata.include_appearance      = true;
        init.advdata.p_manuf_specific_data = &m_sp_manuf_advdata;
        memcpy(&m_sp_advdata, &init.advdata, sizeof(m_sp_advdata));
        init.config.ble_adv_fast_interval              = APP_ADV_FAST_INTERVAL;
        init.config.ble_adv_fast_timeout               = APP_ADV_FAST_DURATION;
        init.evt_handler   = on_adv_evt;
    /**@brief Function for the Event Scheduler initialization.
            nrf_pwr_mgmt_run();
    ///**@brief Function for starting advertising.
    //    uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        bool erase_bonds;
        // Initialize.
       // uart_init();
        log_init();
        timers_init();
        ble_stack_init();
        scheduler_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        // Enter main loop.
        for (;;)
    Can you please help me out where i am going wrong or am i missing something in code ?
