Whitelist implement in ble_app_uart, code crash with error code 4.
I am using nrf52810 ,softdevice 132.
I am trying to implement whitelist in ble_app_uart code (peripheral side).I take reference from HID mouse example.
Code compiled successfully but it when i am trying to connect with central it crashed and board reboot. I try to debug the code it shows Error code 4 .
MINICOM LOGS:
<info> app_timer: RTC: initialized.
<info> app: peer_manager_init
<info> app: Debug logging for UART over RTT started.
<info> app:     m_whitelist_peer_cnt 1, MAX_PEERS_WLIST 8
<info> app: on_adv_evt || ble_adv_evt 7
<info> app: BLE_ADV_EVT_WHITELIST_REQUEST
<info> app: identities_set
<info> app: on_adv_evt || ble_adv_evt 3
<info> app: Fast advertising.
<info> app: advertising_start
<error> app: Fatal error
<warning> app: System reset
DEBUG LOG:
void app_error_handler_bare(unsigned int error_code 0x00000004)
Please find the code having changes of whitelist.
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_fstorage.h"
#include "ble_err.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                1000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   20                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(3000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define SEC_PARAM_BOND                      1                                          /**< Perform bonding. */
#define SEC_PARAM_MITM                      0                                          /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      0                                          /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS                  0                                          /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                       /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                          /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                          /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                         /**< Maximum encryption key size. */
//bool erase_bonds = true;
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static pm_peer_id_t      m_peer_id;                                 /**< Device reference handle to the current bonded central. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
static void advertising_start(bool erase_bonds);
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
//add
void whitelist_set(pm_peer_id_list_skip_t skip)
pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
    ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
    NRF_LOG_INFO("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
                   peer_id_count + 1,
                   BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
    err_code = pm_whitelist_set(peer_ids, peer_id_count);
static void identities_set(pm_peer_id_list_skip_t skip)
    pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
    err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
    NRF_LOG_INFO("identities_set\r\n");
static void delete_bonds(void)
    ret_code_t err_code;
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
    printf("delete bond\r\n");
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    NRF_LOG_INFO("pm_evt_handler || p_evt->evt_id %d \r\n",p_evt->evt_id);
     switch (p_evt->evt_id)
        case PM_EVT_CONN_SEC_SUCCEEDED:
            m_peer_id = p_evt->peer_id;
            advertising_start(false);
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            if (     p_evt->params.peer_data_update_succeeded.flash_changed
                 && (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
                NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
                // Note: You should check on what kind of white list policy your application should use.
                whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    //add
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HID_MOUSE);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    cp_init.evt_handler                    = NULL;//NULL;//on_conn_params_evt;
    // Prepare wakeup buttons.
NRF_LOG_INFO("on_adv_evt || ble_adv_evt %d\r\n",ble_adv_evt);
switch (ble_adv_evt)
case BLE_ADV_EVT_DIRECTED_HIGH_DUTY:
         NRF_LOG_INFO("Directed advertising.");
         err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_DIRECTED);
case BLE_ADV_EVT_FAST:
         NRF_LOG_INFO("Fast advertising.");
#if SWIFT_PAIR_SUPPORTED == 1
           err_code = ble_advertising_advdata_update(&m_advertising, &m_sp_advdata_buf, false);
case BLE_ADV_EVT_SLOW:
          NRF_LOG_INFO("Slow advertising.");
          err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
case BLE_ADV_EVT_FAST_WHITELIST:
         NRF_LOG_INFO("Fast advertising with whitelist.");
         err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
case BLE_ADV_EVT_SLOW_WHITELIST:
          NRF_LOG_INFO("Slow advertising with whitelist.");
case BLE_ADV_EVT_IDLE:
        sleep_mode_enter();
case BLE_ADV_EVT_WHITELIST_REQUEST:
             NRF_LOG_INFO("BLE_ADV_EVT_WHITELIST_REQUEST\r\n");
            ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            ble_gap_irk_t  whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            uint32_t       addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            uint32_t       irk_cnt  = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                                        whitelist_irks,  &irk_cnt);
            NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
                          addr_cnt, irk_cnt);
            // Set the correct identities list (no excluding peers with no Central Address Resolution).
            identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
// Apply the whitelist.
            err_code = ble_advertising_whitelist_reply(&m_advertising,
                                                       whitelist_addrs,
                                                       addr_cnt,
                                                       whitelist_irks,
                                                       irk_cnt);
           // NRF_LOG_INFO("err_code %d\r\n",err_code);
case BLE_ADV_EVT_PEER_ADDR_REQUEST:
            pm_peer_data_bonding_t peer_bonding_data;
            // Only Give peer address if we have a handle to the bonded peer.
            if (m_peer_id != PM_PEER_ID_INVALID)
                err_code = pm_peer_data_bonding_load(m_peer_id, &peer_bonding_data);
                if (err_code != NRF_ERROR_NOT_FOUND)
                    // Manipulate identities to exclude peers with no Central Address Resolution.
                    identities_set(PM_PEER_ID_LIST_SKIP_ALL);
                    ble_gap_addr_t * p_peer_addr = &(peer_bonding_data.peer_ble_id.id_addr_info);
                    err_code = ble_advertising_peer_addr_reply(&m_advertising, p_peer_addr);
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    NRF_LOG_INFO("peer_manager_init\r\n");
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
  /*      case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
             Pairing not supported
             No system attributes have been stored.
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    printf("**********");
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
static void ble_advertising_error_handler(uint32_t nrf_error)
         uint32_t err_code;
         uint8_t                adv_flags;
        ble_advertising_init_t init;
 adv_flags                            = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = adv_flags;
    //init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    //init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_whitelist_enabled = true;
init.config.ble_adv_directed_high_duty_enabled = true;
init.config.ble_adv_fast_enabled = true;
 init.config.ble_adv_directed_enabled           = false;
init.config.ble_adv_directed_interval          = 0;
init.config.ble_adv_directed_timeout           = 0;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
// init.config.ble_adv_slow_enabled = true;
// init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
// init.config.ble_adv_slow_timeout = APP_ADV_SLOW_DURATION;
init.error_handler = ble_advertising_error_handler;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        APP_ERROR_CHECK(ret);
        NRF_LOG_INFO("advertising_start\r\n");
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
   // uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    //advertising_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
   // timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
What is the issue in my code and how to resolve it.
Thanks in advance!
  • Any update?
    Can you please tell me how to resolve this issue ?
  • Are you sure bonding is executed? The ble nus characteristic and services I believe are set to SEC_OPEN by default without requiring any bonding, maybe you should start by looking at ble_nus_init() to change from SEC_OPEN to SEC_JUST_WORKS for the services and characteristics.
    Kenneth
  • HI Kenneth,
    I tried with SEC_JUST_WORKS for the services and characteristics now i am able to connect peripheral with central and The central is add in peripheral whitelist But the problem is i am not able to sent the data by ble_nus_data_send() api?
    Do i need to make any change in ble_app_uart_c(central) code for sending data from peripheral to central?
    I am able to send data from peripheral to NRF app(mobile app).That's means my peripheral code having no problem as per my understanding if data is sending to NRF app?
    Now can u please tell me what changes i have to done in peripheral or central for data sending?
    /** @file
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "app_scheduler.h"
    #include "fds.h"
    #include "ble_conn_state.h"
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define SCHED_QUEUE_SIZE                10
    #define APP_ADV_FAST_INTERVAL           0x0028                                      /**< Fast advertising interval (in units of 0.625 ms. This value corresponds to 25 ms.). */
    #define APP_ADV_SLOW_INTERVAL           0x00A0                                      /**< Slow advertising interval (in units of 0.625 ms. This value corresponds to 100 ms.). */
    #define APP_ADV_FAST_DURATION           3000                                        /**< The advertising duration of fast advertising in units of 10 milliseconds. */
    #define APP_ADV_SLOW_DURATION           18000
    #define SCHED_MAX_EVENT_DATA_SIZE       APP_TIMER_SCHED_EVENT_DATA_SIZE             /**< Maximum size of scheduler events. */
    uint8_t len = 1 ;
    //add
    #define QUEUE_FULL 1
    #define QUEUE_PARTIAL_FULL 2
    #define QUEUE_EMPTY 3
    #define QUE_LEN 30
    uint8_t arr[QUE_LEN];
    uint8_t top = 0 ,bottom = 0;
    uint8_t queue_status = QUEUE_EMPTY;
    //uint8_t g_key = 0;
    /**@brief Function for setting filtered whitelist.
     * @param[in] skip  Filter passed to @ref pm_peer_id_list.
    static void whitelist_set(pm_peer_id_list_skip_t skip)
                       peer_id_count + 1,
    /**@brief Function for setting filtered device identities.
    /**@brief Clear bond information from persistent storage.
            delete_bonds();
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    void enqueue(uint8_t key)
      if(queue_status == QUEUE_FULL)
        printf("\n Queue is full can not add more data");
        arr[top] = key;
        top++;
        if(top == QUE_LEN)
          top = 0;
        if(top == bottom)
          queue_status = QUEUE_FULL;
          queue_status = QUEUE_PARTIAL_FULL;
    //FIXME: dummy send
     // send_indication(&key,1);
    void dequeue(uint8_t *key)
         if(queue_status == QUEUE_EMPTY)
          printf("\n Nothing in queue");
          *key = arr[bottom];
          bottom++;
          if(top == bottom)
    //uint32_t send_indication(uint8_t *data, uint16_t len) {
    //    ble_gatts_hvx_params_t hvx_params;
    //    memset(&hvx_params, 0, sizeof(hvx_params));
    //    hvx_params.handle = custom_data_handle.value_handle;
    //    hvx_params.type   = BLE_GATT_HVX_INDICATION;
    //    hvx_params.offset = 0;
    //    hvx_params.p_len  = &len;
    //    hvx_params.p_data = data;
    //    return sd_ble_gatts_hvx(m_conn_handle, &hvx_params);
    /**@brief Function for handling Service errors.
    static void service_error_handler(uint32_t nrf_error)
    /**@brief Function for handling advertising errors.
        uint32_t                err_code;
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_REMOTE_CONTROL);
            uint32_t err_code;
                do
        uint32_t           err_code;
        // Initialize NUS.
        uint32_t err_code;
                m_sp_advdata.p_manuf_specific_data = NULL;
                err_code = ble_advertising_advdata_update(&m_advertising, &m_sp_advdata, NULL);
                sleep_mode_enter();
                               addr_cnt,
                               irk_cnt);
                                                           whitelist_addrs,
                                                           addr_cnt,
                                                           whitelist_irks,
                                                           irk_cnt);
                NRF_LOG_INFO("BLE_ADV_EVT_PEER_ADDR_REQUEST\r\n");
        NRF_LOG_INFO("ble_evt_handler || p_ble_evt->header.evt_id %d\r\n",p_ble_evt->header.evt_id);
            } break;
    /*void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        err_code = nrf_ble_gatt_init(&m_gatt,NULL);
        uint32_t err_code;
        switch (event)
                sleep_mode_enter();
              case BSP_EVENT_KEY_0 :
                  //enqueue();
                  uint8_t key = 0;
                  //uint8_t len = 1 ;
                  if(m_conn_handle != BLE_CONN_HANDLE_INVALID)
                  ble_nus_data_send(&m_nus,&key,&len,m_conn_handle);
            case BSP_EVENT_KEY_1 :
                  uint8_t key = 1;
             case BSP_EVENT_KEY_2 :
                  uint8_t key = 2;
              case BSP_EVENT_KEY_3 :
                  uint8_t key = 3;
        uint32_t       err_code;
                index++;
                    if (index > 1)
                        do
                    index = 0;
    #else
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        uint8_t                adv_flags;
        init.advdata.include_appearance      = true;
        //init.srdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        //init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.advdata.p_manuf_specific_data = &m_sp_manuf_advdata;
        memcpy(&m_sp_advdata, &init.advdata, sizeof(m_sp_advdata));
        init.config.ble_adv_fast_interval              = APP_ADV_FAST_INTERVAL;
        init.config.ble_adv_fast_timeout               = APP_ADV_FAST_DURATION;
        init.evt_handler   = on_adv_evt;
        //init.error_handler = ble_advertising_error_handler;
    /**@brief Function for the Event Scheduler initialization.
    static void scheduler_init(void)
        APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
          err_code = bsp_event_to_button_action_assign(0, BSP_BUTTON_ACTION_PUSH, BSP_EVENT_KEY_0);
        err_code = bsp_event_to_button_action_assign(1, BSP_BUTTON_ACTION_PUSH, BSP_EVENT_KEY_1);
        err_code = bsp_event_to_button_action_assign(2, BSP_BUTTON_ACTION_PUSH, BSP_EVENT_KEY_2);
        err_code = bsp_event_to_button_action_assign(3, BSP_BUTTON_ACTION_PUSH, BSP_EVENT_KEY_3);
            nrf_pwr_mgmt_run();
    ///**@brief Function for starting advertising.
    //static void advertising_start(void)
    //    uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    //    APP_ERROR_CHECK(err_code);
        bool erase_bonds;
        // Initialize.
       // uart_init();
        log_init();
        timers_init();
        ble_stack_init();
        scheduler_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        // Enter main loop.
        for (;;)
    Best Regards,
    Meghna
  • You likely should take a look at the HRS central example (\examples\ble_central\ble_app_hrs_c) if you haven't already, this example support bonding as-is, and also show how to execute bonding and enable notifications on the peer device.
    If you look at the example you can find that there is a database discovery module (db_discovery_init()) that will execute a discovery of the peer GATT table and call ble_hrs_on_db_disc_evt() on complete, which again call hrs_c_evt_handler() to initiate bonding by pm_conn_secure() and enable notifications by calling ble_hrs_c_hrm_notif_enable().
    If you have setup security requirements to enable notifications, then likely you will have to wait with the ble_hrs_c_hrm_notif_enable() until pm_evt_handler() throw an PM_EVT_CONN_SEC_SUCCEEDED event.
  • Hi Kenneth ,
    I have tried HRS central example (\examples\ble_central\ble_app_hrs_c). But in HRS code when i connect peripheral with central ,in logs its shows connection security failed.
    Here are the minicom logs:
    <info> app: Starting scan.
    <info> peer_manager_handler: Peer data updated in flash: peer_id: 1, data_id: Peer rank, action: Update, no change
    <info> app: Connected.
    <info> app: GATT ATT MTU on connection 0x0 changed to 247.
    <info> peer_manager_handler: Connection security failed: role: Central, conn_handle: 0x0, procedure: Encryption, error: 4102
    <info> app: Data length for connection 0x0 updated to 251.
    <info> app: Battery Level Read as 98 %.
    But in my case i need connection security success.
    Can u please suggest which example is helpful for me?
    Thanks Regards,
    Meghna
