Whitelist implement in ble_app_uart, code crash with error code 4.
I am using nrf52810 ,softdevice 132.
I am trying to implement whitelist in ble_app_uart code (peripheral side).I take reference from HID mouse example.
Code compiled successfully but it when i am trying to connect with central it crashed and board reboot. I try to debug the code it shows Error code 4 .
MINICOM LOGS:
<info> app_timer: RTC: initialized.
<info> app: peer_manager_init
<info> app: Debug logging for UART over RTT started.
<info> app:     m_whitelist_peer_cnt 1, MAX_PEERS_WLIST 8
<info> app: on_adv_evt || ble_adv_evt 7
<info> app: BLE_ADV_EVT_WHITELIST_REQUEST
<info> app: identities_set
<info> app: on_adv_evt || ble_adv_evt 3
<info> app: Fast advertising.
<info> app: advertising_start
<error> app: Fatal error
<warning> app: System reset
DEBUG LOG:
void app_error_handler_bare(unsigned int error_code 0x00000004)
Please find the code having changes of whitelist.
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_fstorage.h"
#include "ble_err.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                1000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   20                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(3000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define SEC_PARAM_BOND                      1                                          /**< Perform bonding. */
#define SEC_PARAM_MITM                      0                                          /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      0                                          /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS                  0                                          /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                       /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                          /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                          /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                         /**< Maximum encryption key size. */
//bool erase_bonds = true;
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static pm_peer_id_t      m_peer_id;                                 /**< Device reference handle to the current bonded central. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
static void advertising_start(bool erase_bonds);
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
//add
void whitelist_set(pm_peer_id_list_skip_t skip)
pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
    ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
    NRF_LOG_INFO("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
                   peer_id_count + 1,
                   BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
    err_code = pm_whitelist_set(peer_ids, peer_id_count);
static void identities_set(pm_peer_id_list_skip_t skip)
    pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
    err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
    NRF_LOG_INFO("identities_set\r\n");
static void delete_bonds(void)
    ret_code_t err_code;
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
    printf("delete bond\r\n");
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    NRF_LOG_INFO("pm_evt_handler || p_evt->evt_id %d \r\n",p_evt->evt_id);
     switch (p_evt->evt_id)
        case PM_EVT_CONN_SEC_SUCCEEDED:
            m_peer_id = p_evt->peer_id;
            advertising_start(false);
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            if (     p_evt->params.peer_data_update_succeeded.flash_changed
                 && (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
                NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
                // Note: You should check on what kind of white list policy your application should use.
                whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    //add
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HID_MOUSE);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    cp_init.evt_handler                    = NULL;//NULL;//on_conn_params_evt;
    // Prepare wakeup buttons.
NRF_LOG_INFO("on_adv_evt || ble_adv_evt %d\r\n",ble_adv_evt);
switch (ble_adv_evt)
case BLE_ADV_EVT_DIRECTED_HIGH_DUTY:
         NRF_LOG_INFO("Directed advertising.");
         err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_DIRECTED);
case BLE_ADV_EVT_FAST:
         NRF_LOG_INFO("Fast advertising.");
#if SWIFT_PAIR_SUPPORTED == 1
           err_code = ble_advertising_advdata_update(&m_advertising, &m_sp_advdata_buf, false);
case BLE_ADV_EVT_SLOW:
          NRF_LOG_INFO("Slow advertising.");
          err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
case BLE_ADV_EVT_FAST_WHITELIST:
         NRF_LOG_INFO("Fast advertising with whitelist.");
         err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
case BLE_ADV_EVT_SLOW_WHITELIST:
          NRF_LOG_INFO("Slow advertising with whitelist.");
case BLE_ADV_EVT_IDLE:
        sleep_mode_enter();
case BLE_ADV_EVT_WHITELIST_REQUEST:
             NRF_LOG_INFO("BLE_ADV_EVT_WHITELIST_REQUEST\r\n");
            ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            ble_gap_irk_t  whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            uint32_t       addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            uint32_t       irk_cnt  = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                                        whitelist_irks,  &irk_cnt);
            NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
                          addr_cnt, irk_cnt);
            // Set the correct identities list (no excluding peers with no Central Address Resolution).
            identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
// Apply the whitelist.
            err_code = ble_advertising_whitelist_reply(&m_advertising,
                                                       whitelist_addrs,
                                                       addr_cnt,
                                                       whitelist_irks,
                                                       irk_cnt);
           // NRF_LOG_INFO("err_code %d\r\n",err_code);
case BLE_ADV_EVT_PEER_ADDR_REQUEST:
            pm_peer_data_bonding_t peer_bonding_data;
            // Only Give peer address if we have a handle to the bonded peer.
            if (m_peer_id != PM_PEER_ID_INVALID)
                err_code = pm_peer_data_bonding_load(m_peer_id, &peer_bonding_data);
                if (err_code != NRF_ERROR_NOT_FOUND)
                    // Manipulate identities to exclude peers with no Central Address Resolution.
                    identities_set(PM_PEER_ID_LIST_SKIP_ALL);
                    ble_gap_addr_t * p_peer_addr = &(peer_bonding_data.peer_ble_id.id_addr_info);
                    err_code = ble_advertising_peer_addr_reply(&m_advertising, p_peer_addr);
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    NRF_LOG_INFO("peer_manager_init\r\n");
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
  /*      case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
             Pairing not supported
             No system attributes have been stored.
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    printf("**********");
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
static void ble_advertising_error_handler(uint32_t nrf_error)
         uint32_t err_code;
         uint8_t                adv_flags;
        ble_advertising_init_t init;
 adv_flags                            = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = adv_flags;
    //init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    //init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_whitelist_enabled = true;
init.config.ble_adv_directed_high_duty_enabled = true;
init.config.ble_adv_fast_enabled = true;
 init.config.ble_adv_directed_enabled           = false;
init.config.ble_adv_directed_interval          = 0;
init.config.ble_adv_directed_timeout           = 0;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
// init.config.ble_adv_slow_enabled = true;
// init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
// init.config.ble_adv_slow_timeout = APP_ADV_SLOW_DURATION;
init.error_handler = ble_advertising_error_handler;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        APP_ERROR_CHECK(ret);
        NRF_LOG_INFO("advertising_start\r\n");
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
   // uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    //advertising_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
   // timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
What is the issue in my code and how to resolve it.
Thanks in advance!
  • Hi Kenneth,
    I tried to connect peripheral(whitelist implemented) with NRF_app,when it is secured connection then only i am able to sent data peripheral to nrf-app otherwise nothing will happen...
    MINI COM logs of working peripheral(ble_app_uart) code:
    <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption
    <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
    <info> app: pm_evt_handler || p_evt->evt_id 8
    Thanks Regards
    Meghna
  • meghna said:
    <info> peer_manager_handler: Connection security failed: role: Central, conn_handle: 0x0, procedure: Encryption, error: 4102
    The error is PM_CONN_SEC_ERROR_PIN_OR_KEY_MISSING, this means (very likely) that you have deleted the bond locally on the peripheral (likely during re-programming or development), however the phone still have a bond with the peripheral. In this case you need to go to Bluetooth menu in Settings in iOS and delete the peripheral device from the list to allow the device to re-bond.
