After implementing my own services, I run into a problem when trying to read the value.of a characteristic. I basically have four services, of which one only holds one read/write characteristic. Now my next step was to try to read and write this characteristic.
But the function sd_ble_gatts_value_get returns the error NRF_ERROR_NOT_FOUND. Since my service implementation is based on the Nordic UART service, my services now all have - among others - the two functions on_connect and on_write. Since I want to read the characteristic value when the data is written, I added the function sd_ble_gatts_value_get to the on_write function. Please correct me if I got something wrong in this concept.
So my fault curiously only happens when using sd_ble_gatts_value_get in the function on_write, not in on_connect (where it was in the example originally).
This is the code from on_write:
ret_code_t err_code;
ble_dcs_evt_t evt;
ble_dcs_client_context_t * p_client;
ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
ble_gatts_value_t gatts_val;
uint8_t cccd_value[2];
memset(&gatts_val, 0, sizeof(ble_gatts_value_t));
gatts_val.p_value = cccd_value;
gatts_val.len = sizeof(cccd_value);
gatts_val.offset = 0;
err_code = sd_ble_gatts_value_get(p_ble_evt->evt.gap_evt.conn_handle,
p_dcs->cmd.cccd_handle,
&gatts_val);
if (err_code != NRF_SUCCESS)
NRF_LOG_ERROR("Attribute could not be read. Error code: 0x%08X", err_code);
if (*(gatts_val.p_value) == 0x06)
And this is how I added the characteristic I am attempting to read (the initialization of the service is always successfull)
memset(&add_char_params, 0, sizeof(add_char_params));
add_char_params.uuid = BLE_UUID_DCS_CMD_CHAR;
add_char_params.uuid_type = p_dcs->uuid_type;
add_char_params.max_len = BLE_DCS_MAX_CMD_CHAR_LEN;
add_char_params.init_len = sizeof(uint8_t);
add_char_params.is_var_len = false;
add_char_params.char_props.write = 1;
add_char_params.char_props.write_wo_resp = 1;
add_char_params.char_props.read = 1;
add_char_params.read_access = SEC_OPEN;
add_char_params.write_access = SEC_OPEN;
err_code = characteristic_add(p_dcs->service_handle, &add_char_params, &p_dcs->cmd);
return err_code;
Used SW and HW:
- SDK17.0.2
- S140
- PCA10056
Thank you for any hints.
