BLE APP CLI example (CLI over BLE UART): poor reliability
I'm trying to implement CLI over BLE UART for one of our company projects. I started from the experimental ble_app_cli example in the SDK. I'm using SDK 15.3.0 on the Nordic PCA10056 SDK board. I keep running into instability problems of various kinds.
In order to narrow down the problem, I decided to simply use the example as is, and see if I can reproduce the issues. For the most part, I end up facing the same problems.
Steps to reproduce:
  • start the example in debug mode, so that I can see that's happening.
  • connect to the device using an Android BLE Terminal emulator (I use this one https://play.google.com/store/apps/details?id=de.kai_morich.serial_bluetooth_terminal&hl=en&gl=US)
  • see the CLI prompt, send led on and led off commands, it all works
  • walk away so that the smartphone loses BLE connection
  • at least 50% of the times, the PCA10056 device doesn't get the disconnect event, and the device gets into a state where the BLE stack is not communicating anymore. It's also possible to get into the same state using for example the UART functionality of the nRF Toolbox and sending bogus commands
  • I added a NRF_LOG_INFO("BLE Cli enabled");/NRF_LOG_INFO("BLE Cli disabled"); after the nrf_cli_init()/uninit for the BLE CLI in ble_evt_handler(), and I can see that the BLE cli gets initialized but never disconnects/uninits, leaving the stack connected even if the phone is disconnected
Is anyone using the CLI over BLE UART? I know I could implement some sort of watchdog, and that the example is only meant as an example, but the reliability I'm seeing so far makes the use of the CLI over the air a bit questionable. Usually the Nordic examples are a lot more robust than this
What am I doing wrong?
  • I am trying to reproduce this, but so far without any luck.
    Thanks for the tests. Here's how to reproduce it, using SDK15.3 (I reproduced it even with the newer SDKs, but our project needs to use SDK15.3, so I hope we can work on that. Otherwise I can create repro steps for 17.0.2, but all the relevant files are identical to 15.3.0)
    Use the experimental\ble_app_cli example for PCA10056, and make the following changes to sdk_config.h
    #define BLE_NUS_CONFIG_LOG_ENABLED 1
    #define BLE_NUS_CONFIG_LOG_LEVEL 4
    #define APP_TIMER_KEEPS_RTC_ACTIVE 1  // needed for MMD
    #define NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 0  // without this, Jlink RTT doesn't output
    #define NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED 1
    #define NRF_CLI_BLE_UART_CONFIG_LOG_LEVEL 4
    #define NRF_SDH_LOG_ENABLED 1   // this should already be enabled
    #define NRF_SDH_LOG_LEVEL 4
    #define NRF_SDH_SOC_LOG_ENABLED 1   // this should already be enabled
    #define NRF_SDH_SOC_LOG_LEVEL 4
    Add the following to main.c (I include the 2 lines preceding the change and the 2 following)
        nrf_cli_ble_uart_config_t config = { .conn_handle = m_conn_handle };
        err_code = nrf_cli_init(&m_ble_cli, &config, true, true, NRF_LOG_SEVERITY_INFO);
        NRF_LOG_INFO("BLE Cli enabled");    // add this line
        APP_ERROR_CHECK(nrf_cli_task_create(&m_ble_cli));
        (void)nrf_cli_uninit(&m_ble_cli);
        NRF_LOG_INFO("BLE Cli disabled");       // add this
        bool erase_bonds;
    #if CONFIG_JLINK_MONITOR_ENABLED                            // enable MMD
        NVIC_SetPriority(DebugMonitor_IRQn, _PRIO_SD_LOW);      // MMD
    #endif                                                      // MMD
        core_init();
    Make the following changes to ble_app_cli_pca10056_s140.emProject to add the MMD files and to enable it. Also make sure it's debug level 3 and optimization 0. Copy the 3 MMD files under examples\ble_peripheral\experimental\ble_app_cli\pca10056\s140\ses
    <folder Name="Segger_MMD">
      <file file_name="JLINK_MONITOR_ISR_SES.s" />
      <file file_name="JLINK_MONITOR.c" />
    </folder>
    <configuration
    Name="Debug"
    JLinkExecuteCommand="SetMonModeDebug = 1;SetMonModeVTableAddr = 0x31000"
    c_preprocessor_definitions="DEBUG;CONFIG_JLINK_MONITOR_ENABLED"
    gcc_optimization_level="None" />
    Compile and run in debug mode. Connect to the PCA10056 with nRFConnect. You will notice that there is no log output (not even the "BLE CLI enabled" we just added.
    Change the following in sdh_config.h to ensure the logs are printed as soon as they happen
    #define NRF_LOG_BUFSIZE 2048
    #define NRF_LOG_DEFERRED 0
    You will see that as soon as you connect to the PCA10056, the program hangs
    You can then set again #define NRF_LOG_DEFERRED 1 and add a NRF_FLUSH() after the "BLE CLI enable/disabled" messages to at least monitor connection/disconnection
    NRF_LOG_FLUSH();
    NRF_LOG_FLUSH();
    Re-execute the code in debug mode and connect to the PCA10056 with nRF Connect. You will see the "BLE CLI enabled" message. Then disconnect nRF Connect. You will not see a "BLE CLI disabled" message and the PCA10056 is now unreachable by nRF Connect until you restart it
    P.S. I cannot find a way to include files. It would be easier for you if there was a way to upload my files, so that you won't have to edit manually
  • MMD should work on any Cortex-M (except M0).
    You need a J-Link, though; nobody else seems to support it - even ARM themselves!
    Yep. I looked into making it work for the STM32 (using JLINK), but I lost interest after a while. I also happened to have found a long dormant bug in the MMD code itself, when FP code is enabled   https://forum.segger.com/index.php/Thread/7292-SOLVED-Bug-in-Monitor-Mode-Debug-example-when-using-FP-enabled-code-variable-add/  Slight smile
    I sure am glad Nordic made it work seamlessly and included the Jlink in the SDK boards
  • You can drag'n'drop them. The easiest would be a zipped folder containing the project folder, which includes all the files you have edited here (main, sdk_config and the project file).
    There is also an option to insert->Image/video/file -> and then click "upload" (which doesn't look like a button after the last update).
    However, I will try to do the changes that you did.
    I'll try without monitor mode debugging first, because I am not familiar with it.
    I see that when I enabled NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED is set to 1, it stops logging after you connect to the device (after the lines saying that notifications are not enabled). I believe the reason for this is that the CLI, which also is a log backend, will log things in the cli_ble_uart_write() function, which is used to process the logs. This means that whenever something is logged, it is queued using NRF_LOG_INFO(), which in turn triggers cli_ble_uart_write(), which triggers the next NRF_LOG_INFO(""); and so on. Hence, since this keeps on adding to the tasks, the idle_task() in main() is no longer called. Try to set a breakpoint there, and you will see that it is not hit after the connection is entered.
    So you have 3 choices:
    1: set NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED to 0,
    2: set NRF_CLI_LOG_BACKEND to 0 (this will stop all logs from being printed over CLI).
    3: Remove all calls to NRF_LOG_... in cli_ble_uart_write():
    static ret_code_t cli_ble_uart_write(nrf_cli_transport_t const * p_transport,
                                         const void *                p_data,
                                         size_t                      length,
                                         size_t *                    p_cnt)
        ASSERT(p_cnt);
        nrf_cli_ble_uart_internal_t * p_instance =
                                 CONTAINER_OF(p_transport, nrf_cli_ble_uart_internal_t, transport);
        ret_code_t err_code = NRF_SUCCESS;
        if (p_instance->p_cb->service_started)
            *p_cnt = length;
            err_code = nrf_ringbuf_cpy_put(p_instance->p_tx_ringbuf, p_data, p_cnt);
    //        NRF_LOG_INFO("Conn_handle:%d, write req:%d, buffered:%d",
    //                                                     p_instance->p_cb->conn_handle, length, *p_cnt);
    //        NRF_LOG_HEXDUMP_DEBUG(p_data, *p_cnt);
    //        NRF_LOG_INFO("Conn_handle:%d, write req:%d. Notifications not enabled",
    //                     p_instance->p_cb->conn_handle, length);
            *p_cnt = length;
            p_instance->p_cb->handler(NRF_CLI_TRANSPORT_EVT_TX_RDY, p_instance->p_cb->p_context);
        return err_code;
    If you still encounter issues with the disconnection. What does the log say after the disconnect if you implement one of the three workarounds above?
    BR,
    Edvin
    Thanks Edvin. I missed that. Glad I asked Slight smile
    Ok, I tried what you suggested, and the only suggestion that worked well enough was #3, comment out the NRF_LOG calls in cli_ble_uart_write().
    The logs don't crash anymore (good!) but I still get into the same state where no connection is accepted. Steps to repro: execute the code in debug mode, connect with nRF Toolbox UART functionality. You will see the <info> app: BLE Cli enabled message. Then walk away until the BLE signal is lost, the button at the bottom of the nRF app will say "connecting..." but nothing happens. The message <info> app: BLE Cli disabled is never reached (even putting a breakpoint there, nothing). If you try to reconnect manually, in the scan screen the Nordic_CLI device doesn't show (because the PCA10056 is in a non working state).There is no way to reconnect to the PCA10056 short of restarting it
    Unlike before, you can break into the debugger (assuming you have MMD enabled), but with no real useful information (usually it's in task_yeld())
    I'm enclosing all modified files in this ZIP. Please note that I did not follow the exact folder structure of the SDK for the nrf_cli_ble_uart.c file (which you need to manually copy into components\libraries\cli\ble_uart. MMD is enabled on that build, and completely transparent
    ble_app_cli.zip
    Appreciate any help you can provide
     That can mean that you are too far away, but the phone can't pick up any advertisements. Try to sniff the connection. Does the nRF advertise? Does the phone send a connection request? Does the same thing happen if you try to use nRF Connect, and just unplug the connectivity DK/dongle? This was what I tested. Sorry, but it is a bit difficult for me to walk away from it, because I use Remote Desktop and the DKs are connected to my computer in the office. I tried a couple of times yesterday to just unplug the DK it was connected to (I was using nRF Connect for Desktop). That will cause the connection to time out, because the central disappears, but I never ran into any issues.
    BR,
    Edvin
