BLE APP CLI example (CLI over BLE UART): poor reliability
I'm trying to implement CLI over BLE UART for one of our company projects. I started from the experimental ble_app_cli example in the SDK. I'm using SDK 15.3.0 on the Nordic PCA10056 SDK board. I keep running into instability problems of various kinds.
In order to narrow down the problem, I decided to simply use the example as is, and see if I can reproduce the issues. For the most part, I end up facing the same problems.
Steps to reproduce:
  • start the example in debug mode, so that I can see that's happening.
  • connect to the device using an Android BLE Terminal emulator (I use this one https://play.google.com/store/apps/details?id=de.kai_morich.serial_bluetooth_terminal&hl=en&gl=US)
  • see the CLI prompt, send led on and led off commands, it all works
  • walk away so that the smartphone loses BLE connection
  • at least 50% of the times, the PCA10056 device doesn't get the disconnect event, and the device gets into a state where the BLE stack is not communicating anymore. It's also possible to get into the same state using for example the UART functionality of the nRF Toolbox and sending bogus commands
  • I added a NRF_LOG_INFO("BLE Cli enabled");/NRF_LOG_INFO("BLE Cli disabled"); after the nrf_cli_init()/uninit for the BLE CLI in ble_evt_handler(), and I can see that the BLE cli gets initialized but never disconnects/uninits, leaving the stack connected even if the phone is disconnected
Is anyone using the CLI over BLE UART? I know I could implement some sort of watchdog, and that the example is only meant as an example, but the reliability I'm seeing so far makes the use of the CLI over the air a bit questionable. Usually the Nordic examples are a lot more robust than this
What am I doing wrong?
  • Try to sniff the connection. Does the nRF advertise?
    Thanks Edvin. As I said, the PCA10056 is not working anymore. After losing the signal, I get back to the same desk where the PCA10056 is, and try nRF Connect and/or nRF Toolbox, and there is nothing from the PCA10056 to sniff
    I don't understand what you mean by "disconnect the DK". I use the example simply with a single PCA10056 and an Android phone to connect to it. I don't use the very complex Python-script of the test, since that adds unneeded complexity and requires more hardware
    In that example, the PCA10056 should work as a BLE UART device, and you can connect to it with any device that can establish a BLE UART connection (e.g. an Android phone using nRF Toolbox UART).
    So the PCA10056 is started, an Android phone with nRF toolbox UART used to connect to the PCA10056, walk far enough to lose the connection, then walk back into range. At that point, the PCA10056 is dead
     Ok, I thought that if you had two PCA10056, you could try to use nRF Connect for Desktop with one of the DKs, and connect to the other DK running your own application. Bu "disconnecting the DK" I meant that you could unplug the DK that is running the nRF Connect FW, which would make it immediately unresponsive (similar to what you would see if you walk out of range with a phone). I am still not able to reproduce this.
    Does this behavior depend on your sdk_config.h definitions? Does it happen if you use an unmodified SDK and the unmodified example, without any changes to the sdk_config.h file? Or does it only happen when you enable the logging from the CLI module?
    BR,
    Edvin
  • you could try to use nRF Connect for Desktop with one of the DKs, and connect to the other DK running your own application.
    Unfortunately I do not have two DKs. But in any case that would not be a realistic configuration for our scenario where a smartphone will be used to configure the nRF52 device currently under development, and a rugged Android device used to QA test and configure the final product at the end of the production line
    I tried with the example as is, no changes, compiled in Release mode, connected the first time using UART in nRF Toolbox. Same problem: as soon as the connection is lost, the PCA10056 gets into a non-working state and never recovers. Neither nRF Connect nor nRF Toolbox can see the device.
    The example turns on one of the PCA10056 leds when connected. That led never turns off when the device is in the non-responding state, which probably means that the PCA10056 thinks it's still connected and never even goes into sleep mode. That is consistent with the code never reaching the nrf_cli-uninit() inside BLE_GAP_EVT_DISCONNECTED
  • I still can't reproduce that. Can you send me:
    1: A zipped folder that contains the project file that you used to compile this application that has the issue when you disconnect. Please let me know what IDE you are using (and I assume you are still using SDK15.3.0.
    2: The hex file that you are reproducing this with.
    BR,
    Edvin
  • Edvin, I'm not sure what other ZIP file I can send you. I'm using the 15.3.0 SDK, yes. and the ZIP file I previously uploaded contains everything needed to reproduce the problem. You simply need to unzip that file over the SDK 15.3.0 example in examples\ble_peripheral\experimental\ble_app_cli, overwriting the files with the same name. In addition to that, you need to copy the nrf_cli_ble_uart.c file inside the ZIP file over the same file in the SDK in components\libraries\cli\ble_uart. The only other alternative would be to upload the whole SDK, but that's probably too big for the forum
    I'm using Segger 4.52a, with the 8.32a CPU support package, but as you can see below, that makes no difference
    Here is the HEX file compiled with Release settings, you will also need to flash the S140 softdevice in the SDK 15.3.0 to make it work. Please note that this HEX is actually identical to the SDK example, no change at all (since there is no need to change logs and other for Release, nor MMD). So this hex is pretty much the app portion of the HEX file in examples\ble_peripheral\experimental\ble_app_cli\hex (that one also has the softdevice)
    ble_app_cli_pca10056_s140.hex
    So the simplest way to reproduce the problem is simply to flash the examples\ble_peripheral\experimental\ble_app_cli\hex\ble_app_cli_pca10056_s140.hex file onto a PCA10056, connect with an Android device to NORDIC_CLI, then walk away enough to lose signal (or put the phone into a metal box), and the PCA10056 is stuck and never recovers. There's no need to use any parts of my example. So the example, as provided by Nordic, doesn't work reliably
    Just in case, my device is a Pixel 3, but I can reproduce it even with an iPhone using the iOS version of nRF Toolbox... for some reason, it  takes a bit longer to get the PCA10056 to hang with the iPhone, but it hangs nonetheless. You just need to wait 20 seconds or so once it loses the signal before getting close again to the PCA10056
    EDIT: I just tried flashing the examples\ble_peripheral\experimental\ble_app_cli\hex\ble_app_cli_pca10056_s140.hex from SDK 17.0.2 and that one seems to work as expected, and can handle loss of signal, even using the serial terminal app. Unfortunately that doesn't really help us, because we are forced to use SDK15.3.0 (to avoid having to re-validate the entire firmware) and I cannot debug the app flow to understand where it hangs in 15.3.0, and where instead it works in 17.0.2. Also17.0.2 uses a completely different S140 sofdevice, so not much I can learn from this
