UART current consumption
I developed an application for a custom nrf52832 board. It uses the Nordic UART Service (NUS) to transmit data over BLE. This works fine.
At the moment I am trying to optimize the current consumtion of this application on the custom nrf52832 board. I have already made some measurements and I figured out the following:
If I initialize the UART by calling the uart_init() function, my current consumption increases by 1,35mA (V_cc = 1.8V). This looks a bit too high for me.
Can you please answer my following questions:
1. Is this the normal current consumption of the UART?
2. Are there any ways to lower the current consumption of the UART?
Thank you very much in advance.
    This depends a bit on which UART are used. Both the UART and the UARTE peripherals has a run current of 55 uA, but in addition, both requires the HFCLK to run, which is about 400 uA. The UARTE peripheral also adds the EasyDMA current of about 1.2 mA to the current, when the UART is active. These are numbers for 3.0V supply, I would expect them to be higher at 1.8V.
    You can try to for the UART library to use the legacy UART peripheral, by setting the following configs in your sdk_config.h file:
    #ifndef UART_LEGACY_SUPPORT
    #define UART_LEGACY_SUPPORT 0
    #ifndef UART0_CONFIG_USE_EASY_DMA
    #define UART0_CONFIG_USE_EASY_DMA 0
    With these configs, I measure about 450 uA base current.
    Another option is to disable the RX part of the UART if you do not need this in your application. We have implemented this in NRF_LOG, and I measure 4 uA base current with this, as the UART peripheral is only active when a TX operation is happening. Since UART is asynchronous, there is no way to achieve this for RX, except having RX enabled at all times, or use additional control-signals to notify the chip in advance that a transfer will happen, to make it enable the RX mode.
    Jørgen
  • I did my testing with ble_app_uart from SDK 17.0.2 on a nRF52 DK (PCA10040).
    Starting with unmodified example, I measure this current (1.875 mA):
    By adding the two changes to the sdk_config.h file I posted in my previous post (458 uA):
    Without adding the two previous changes, but setting the RX pin to UART_PIN_DISCONNECTED in comm_params passed to APP_UART_FIFO_INIT, the current is reduced to ~4 uA:
    Jørgen
    thank you very much for your reply.
    EasyDMA current is only introduced once
    This sounds very reasonable.
    1. Do you know what the typical current consumption of EasyDMA is?
    I want to analyze the current consumption of each peripheral. As I already mentioned in my original question my current increases by ~1.35mA when call uart_init().
    2. Do you know how the current consumption is distributed? (How much current draws EasyDMA and how much current draws the 16MHz clock?)
    3. Is there somewhere a summary of the typical current draws of each peripheral?
    How large is the SAADC_SAMPLES_IN_BUFFER define
    It is defined to 4. I already figured out that there is no point of using the Low Power Mode of SAADC for this application. Especially because I need EasyDMA, allowing sampling of channels directly to RAM using PPI, without CPU intervention. This is not available in Low Power Mode.
    Thank you so much in advance for answering my questions.
    Unfortunately, we do not have current numbers for each component in the chip alone. EasyDMA is always used in combination with a peripheral, so it is not easy to measure its current consumption alone.
    The major part of SAADC active current is from EasyDMA. The majority of the TIMER running current is from the HFCLK.
    Note that these values are in the nRF52840 PS and not fully accurate for nRF52832, however it gives you an idea of the magnitude of currents consumed. The currents are typical values and for 3.0V supply voltage.
    Current consumption for some peripherals (including the ones linked in 2., are presented in Current consumption chapter in the nRF52832 PS. For nRF52832, there is also current consumption numbers in the "Electrical Specifications" section of each peripheral chapter. The problem with these number is that they are typically run currents for the peripheral itself, and does not include current consumed by other requested resources (EasyDMA, Clock domains, etc).
    thank you very much for your support. I will take a look to this.
  • Hello Jorgen,
    Is there an equivalent in NCS 2.0.2? We are running into similar power issues, but unsure how the nrf5 sdk changes in this thread translate to NCS.
  • Can you please post your question in a new ticket, explaining exactly what you are looking for? NCS are quite different from nRF5 SDK.
