UART current consumption
I developed an application for a custom nrf52832 board. It uses the Nordic UART Service (NUS) to transmit data over BLE. This works fine.
At the moment I am trying to optimize the current consumtion of this application on the custom nrf52832 board. I have already made some measurements and I figured out the following:
If I initialize the UART by calling the uart_init() function, my current consumption increases by 1,35mA (V_cc = 1.8V). This looks a bit too high for me.
Can you please answer my following questions:
1. Is this the normal current consumption of the UART?
2. Are there any ways to lower the current consumption of the UART?
Thank you very much in advance.
    sorry for my late reply.
    Thank you for your answer.
    Do you have multiple channels enabled in the SAADC?
    Yes, I am using 4 channels.
    what sample rate are you using for the SAADC
    1kHz (1ms) for all channels.
    I also use the SAADC in non-blocking mode and with double buffering. For accuracy I need the HFCLK.
    I already evaluated the SAADC readings and they are fine.
    example for multichannel low power SAADC
    I will take a look to this examples. I hope that I can find the reason for the increase in current consumption.
    I figured out that when I use UART_PIN_DISCONNECTED for the rx part of the UART, the current consumption increases by ~1.5mA when I call the following:
    void saadc_init(void)
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
    Unfortunaly, I am not able to determine why this causes the increase in current consumption. The call of the nrf_drv_saadc_buffer_convert(..) function is equal to the "Low Power SAADC" example with multiple channels.
    1. Do you have any ideas why this causes the increase in current consumption when I use UART_PIN_DISCONNECTED for the rx part of the UART?
    2. Do you have any ideas how to solve this issue?
  • 1. When you did not set UART_PIN_DISCONNECTED for the UART RX pin, EasyDMA was already enabled due to the UART being in RX mode. When you removed the RX part of UART, EasyDMA was not started until you start the SAADC (which uses the same EasyDMA feature for storing samples in RAM). EasyDMA current is only introduced once, not multiplied by the numbers of peripheral utilizing EasyDMA concurrently.
    2. How large is the SAADC_SAMPLES_IN_BUFFER define? In order to achieve low current, the buffers can only hold a single sample for each enabled channel. Depending on your acquisition time, 4 channels with a sample rate of 1 kHz means that the SAADC will be enabled ~5-20% of the time anyway, and with the overhead of stopping/starting the SAADC, you may not be able to see low currents like in the examples I linked. Handling this much interrupts to change buffers every 1 ms may also not work well in all application.
    thank you very much for your reply.
    This sounds very reasonable.
    1. Do you know what the typical current consumption of EasyDMA is?
    I want to analyze the current consumption of each peripheral. As I already mentioned in my original question my current increases by ~1.35mA when call uart_init().
    2. Do you know how the current consumption is distributed? (How much current draws EasyDMA and how much current draws the 16MHz clock?)
    3. Is there somewhere a summary of the typical current draws of each peripheral?
    It is defined to 4. I already figured out that there is no point of using the Low Power Mode of SAADC for this application. Especially because I need EasyDMA, allowing sampling of channels directly to RAM using PPI, without CPU intervention. This is not available in Low Power Mode.
    Thank you so much in advance for answering my questions.
    Unfortunately, we do not have current numbers for each component in the chip alone. EasyDMA is always used in combination with a peripheral, so it is not easy to measure its current consumption alone.
    The major part of SAADC active current is from EasyDMA. The majority of the TIMER running current is from the HFCLK.
    Note that these values are in the nRF52840 PS and not fully accurate for nRF52832, however it gives you an idea of the magnitude of currents consumed. The currents are typical values and for 3.0V supply voltage.
    Current consumption for some peripherals (including the ones linked in 2., are presented in Current consumption chapter in the nRF52832 PS. For nRF52832, there is also current consumption numbers in the "Electrical Specifications" section of each peripheral chapter. The problem with these number is that they are typically run currents for the peripheral itself, and does not include current consumed by other requested resources (EasyDMA, Clock domains, etc).
