not able to create three or more tasks in freeRTOS in nrf52832.
 hello,
I working on nrf52832. in that I am working in freeRTOS for example I am creating two tasks using a queue. but when I create the third task not able to run any debug processing I don't know the task is created or not. and I already increased the heap size from 4092 to 8192. but the same problem faced.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_freertos.h"
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include "semphr.h"
#include "nrf_ble_qwr.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define OSTIMER_WAIT_FOR_QUEUE              2                                       /**< Number of ticks to wait for the timer queue to be ready */
NRF_BLE_QWR_DEF(m_qwr);                                             /**< Context for the Queued Write module.*/
static TaskHandle_t m_sender_thread;
static TaskHandle_t m_receiver_thread;                              /**< Definition of Logger thread. */
static TaskHandle_t m_tx1_thread;
xQueueHandle Global_queue_Handle = 0;;
    APP_ERROR_HANDLER(nrf_error);
static void log_init(void)
static void tx1(void * arg){
	 UNUSED_PARAMETER(arg);
   while (1)
	NRF_LOG_INFO("task3");
static void sender_thread(void * arg)
	volatile int i = 0;
	int rx = 0;
	NRF_LOG_INFO("task 1 : %d",uxTaskGetStackHighWaterMark( &m_sender_thread ));
    while (1)
		i++;
		xQueueReceive(Global_queue_Handle,&rx,2);
		NRF_LOG_INFO("Received1  %d ",rx);
		//NRF_LOG_INFO("send");
		xQueueSend(Global_queue_Handle,&i,2);
		NRF_LOG_INFO("send1 %d ",i);
		NRF_LOG_FLUSH();
        vTaskSuspend(NULL); // Suspend myself
static void receiver_thread(void * arg)
volatile i = 100;
int rx = 0;
NRF_LOG_INFO("task 2 : %d",uxTaskGetStackHighWaterMark( &m_receiver_thread ));
   while (1)
		 i--;
		NRF_LOG_INFO("send2 %d ",i);
		NRF_LOG_INFO("Received2  %d ",rx);
		//vTaskDelay(10);
		NRF_LOG_FLUSH();
/**@brief A function which is hooked to idle task.
 * @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
void vApplicationIdleHook( void )
vTaskResume(m_sender_thread);
vTaskResume(m_receiver_thread);
vTaskResume(m_tx1_thread);
/**@brief Function for initializing the clock.
static void clock_init(void)
    ret_code_t err_code = nrf_drv_clock_init();
/**@brief Function for application main entry.
    bool erase_bonds;
	//clock_init();
    // Initialize modules.
    log_init();
    // Do not start any interrupt that uses system functions before system initialisation.
    // The best solution is to start the OS before any other initalisation.
Global_queue_Handle = xQueueCreate(3,sizeof(int));
    // Start execution.
    if (pdPASS != xTaskCreate(sender_thread, "sender", configMINIMAL_STACK_SIZE +300 , NULL, 1, &m_sender_thread))
        APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
		NRF_LOG_INFO("NOT created1");
    if (pdPASS != xTaskCreate(receiver_thread, "receiver", configMINIMAL_STACK_SIZE +300 , NULL, 1, &m_receiver_thread))
	//configSTACK_DEPTH_TYPE uxTaskGetStackHighWaterMark2( TaskHandle_t xTask );
	if (pdPASS != xTaskCreate(tx1, "tx1", configMINIMAL_STACK_SIZE + 300, NULL, 1, &m_tx1_thread))
		NRF_LOG_INFO("NOT created2");
    // Activate deep sleep mode.
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    NRF_LOG_INFO("testing FreeRTOS example started.");
    // Start FreeRTOS scheduler.
    vTaskStartScheduler();
    for (;;)
        //APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
OUTPUT ::
00> <info> app: testing FreeRTOS example started
only this much of print I got.
help me to fix these issues. thank you
