Interrupt not firing
Hello DevZone,
SDK 15.0.0 SD S140
Currently working without an active SoftDevice but even with an active SoftDevice these problems keep occurring.
I'm currently working with a couple of SPI devices connected to my nRF52840.
I am using an app timer to create periodic moments to read out my SPI device.
I have allocated a GPIOTE and a PPI channel to the SPI->EVENTS_END to set it and in the SPI handler I clear the GPIOTE.
In the image you can see the device working properly and communicating with 6 devices.
The top 6 signals are the chip selects, white is MISO, brown is MOSI, red is SCK and green is the GPIOTE pin.
If I zoom in to one packet you can clearly see that the GPIOTE pin is set and cleared.
A second later I need to communicate again with all six devices but for some reason my interrupt handler isn't called.
The GPIOTE pin is set indicating that the event has happened but the interrupt handler isn't called.
By not calling the handler the SPI appears to be always busy since I clear the busy flag in the interrupt handler.
I have checked in the register group if something is changed or something but it isn't.
Everything seems to work but then again it doesn't.
If my code wasn't working I would not have had six successful transmissions and I cannot figure out what is going on.
