Convert a arduino code, what should i change, haptic feedback gloves
#include <MPU6050_tockn.h>
#include <Wire.h>
MPU6050 mpu6050(Wire);
// Flex sensors to track finger bends
const int flexSensorPin = A0; // The flex sensor for pin 0
const int flexSensorPin2 = A1; // The flex sensor for pin 1
const int flexSensorPin3 = A2; // The flex sensor for pin 2
const int flexSensorPin4 = A3; // The flex sensor for pin 3
const int flexSensorPin5 = A4; // The flex sensor for pin 4
// Joystick + button to move the virtual hand - Could easily be replaced with Vive Tracker
const int xPin = A5;
const int yPin = A6;
const int buttonPin = 3; // joystick button press - up on z axis
const int buttonPin2 = 4; // button press - down on z axis
// Vibration motors to simulate haptics
const int indexMotorPin = 12;
const int middleMotorPin = 11;
const int ringMotorPin = 10;
const int pinkyMotorPin = 9;
const int palmMotorPin = 8;
const int palmMotorPin2 = 7;
const int palmMotorPin3 = 6;
void setup() {
  Serial.begin(9600);
  Wire.begin();
  mpu6050.begin();
  mpu6050.calcGyroOffsets(true); // Calibrate the gyro offsets
  pinMode(flexSensorPin, INPUT);
  pinMode(flexSensorPin2, INPUT);
  pinMode(flexSensorPin3, INPUT);
  pinMode(flexSensorPin4, INPUT);
  pinMode(flexSensorPin5, INPUT);
  pinMode(xPin, INPUT);
  pinMode(yPin, INPUT);
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(buttonPin2, INPUT_PULLUP);
  pinMode(indexMotorPin, OUTPUT);
  digitalWrite(indexMotorPin, LOW);
  pinMode(middleMotorPin, OUTPUT);
  digitalWrite(middleMotorPin, LOW);
  pinMode(ringMotorPin, OUTPUT);
  digitalWrite(ringMotorPin, LOW);
  pinMode(pinkyMotorPin, OUTPUT);
  digitalWrite(pinkyMotorPin, LOW);
  pinMode(palmMotorPin, OUTPUT);
  digitalWrite(palmMotorPin, LOW);
  pinMode(palmMotorPin2, OUTPUT);
  digitalWrite(palmMotorPin2, LOW);
  pinMode(palmMotorPin3, OUTPUT);
  digitalWrite(palmMotorPin3, LOW);
void loop() {
  mpu6050.update();
  // Output physical inputs to Unity
  Serial.print(analogRead(flexSensorPin)); // A0
  Serial.print(","); //delimiter
  Serial.print(analogRead(flexSensorPin2)); // A1
  Serial.print(analogRead(flexSensorPin3)); // A2
  Serial.print(analogRead(flexSensorPin4)); // A3
  Serial.print(analogRead(flexSensorPin5)); // A4
  Serial.print(",");
  Serial.print(analogRead(xPin) / 1024.0);
  Serial.print(",");
  Serial.print(analogRead(yPin) / 1024.0);
  Serial.print(",");
  Serial.print(digitalRead(buttonPin) ? (digitalRead(buttonPin2) ? 0.5 : 0) : (digitalRead(buttonPin2) ? 1 : 0.5));
  Serial.print(",");
  Serial.print(mpu6050.getAngleX());
  Serial.print(",");
  Serial.print(mpu6050.getAngleY());
  Serial.print(",");
  Serial.println(mpu6050.getAngleZ());
  // Read vibration types for each finger from Unity
  String message = Serial.readStringUntil('~');
  ChooseVibrationType(indexMotorPin, message[0]);
  ChooseVibrationType(middleMotorPin, message[1]);
  ChooseVibrationType(ringMotorPin, message[2]);
  ChooseVibrationType(pinkyMotorPin, message[3]);
  ChooseVibrationType(palmMotorPin, message[4]);
  ChooseVibrationType(palmMotorPin2, message[4]);
  ChooseVibrationType(palmMotorPin3, message[4]);
void ChooseVibrationType(int pinNum, char vibeType) {
  switch(vibeType) {
  case '0': // Off
    digitalWrite(pinNum, LOW);
  case '1': // On
    digitalWrite(pinNum, HIGH);
  case '2': // Waterfall
    if(random(0,5) > 3) {
    } else {
This is a arduino code, but got to do it in nrf52840dk can you tell me what should i change , i have given code link and library https://github.com/AurekSkyclimber/DIY-Haptic-Glove https://github.com/tockn/MPU6050_tockn
  • Hi Saver
    I suggest starting with learning how to use the nRF Connect SDK, and working your way outwards from there. Using the arduino code as a reference will be helpful, but just changing the includes, constants and function calls from this project will propably be more time-consuming and frustrating than actually helpful.
    You will need to change all the constants for pin-inputs and -outputs to the corresponding pins on the nRF52840, in addition you will need to change the function calls from calling the arduino libraries to calling the appropriate function from one of the Nordic SDK libraries you choose to include in your project.
    Here's a link to the getting started guide for the nRF Connect SDK: Getting Started NCS
    Here's a link to the documentation some of the different libraries in the NCS Libraries
    Update: An NCS compatible driver for the MPU5060 could be found through the Zephyr project: MPU6050 Zephyr Driver. Learn more about using Zephyr with NCS here: Getting started with Zephyr and Developing with Zephyr
    Best Regards
    Robin.
