Issues with PWM and GPIOTE: interrupt masking and missing pulses
Problems I am having with PWM:
1. Using app_PWM and GPIOTE to start and stop the PWM: When button is pressed, GPIOTE handler sets a flag that is polled to start the PWM. PWM starts "app_pwm_enable(&PWM1);" and the GPIOTE does not responds to any other button presses. I tried to manioulate the IRQ priority for the GPIOTE but no good.
2. Using driver PWM or app_PWM to produce 4MHz pulses, starting with 8MHz or 16MHz clock, there are always missing pulses.
any advice ?
thanks
    I recommend using PWM driver for this.
    Here is some example code on how to generate a defined number of 4 MHz pulses when a button on the DK is pressed.
     * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup pwm_example_main main.c
     * @ingroup pwm_example
     * @brief PWM Example Application main file.
     * This file contains the source code for a sample application using PWM.
    #include <stdio.h>
    #include <string.h>
    #include "nrf_drv_pwm.h"
    #include "app_error.h"
    #include "boards.h"
    #include "bsp.h"
    #include "app_timer.h"
    #include "nrf_drv_clock.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    static nrf_drv_pwm_t m_pwm0 = NRF_DRV_PWM_INSTANCE(0);
    #define PWM_PIN 3
    #define TOP_VALUE 4
    // Set to the number of pulses to be generated
    #define PULSES 12
    static void pwm_init(void)
        nrf_drv_pwm_config_t config =
            // These are the common configuration options we use for all PWM
            // instances.
            .irq_priority = APP_IRQ_PRIORITY_HIGH,
            .count_mode   = NRF_PWM_MODE_UP,
            .step_mode    = NRF_PWM_STEP_AUTO,
        config.base_clock = NRF_PWM_CLK_16MHz;
        config.top_value  = TOP_VALUE;
        config.load_mode  = NRF_PWM_LOAD_COMMON;
        config.output_pins[0] = PWM_PIN;
        config.output_pins[1] = NRF_DRV_PWM_PIN_NOT_USED;
        config.output_pins[2] = NRF_DRV_PWM_PIN_NOT_USED;
        config.output_pins[3] = NRF_DRV_PWM_PIN_NOT_USED;
        APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config, NULL));
    static void generate_pulse_1mhz(uint16_t pulses)
        static uint16_t /*const*/ seq_values[] ={0,0x8000};
        nrf_pwm_sequence_t const seq =
            .values.p_common = seq_values,
            .length          = NRF_PWM_VALUES_LENGTH(seq_values),
            .repeats         = 0,
            .end_delay       = 0
        nrf_drv_pwm_simple_playback(&m_pwm0, &seq, pulses,  NRF_DRV_PWM_FLAG_STOP);
    static void bsp_evt_handler(bsp_event_t evt)
        switch (evt)
            case BSP_EVENT_KEY_0:
                 generate_pulse_1mhz(PULSES);
           case BSP_EVENT_KEY_1:
                return;
    void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
        bsp_board_leds_on();
        app_error_save_and_stop(id, pc, info);
    static void init_bsp()
        APP_ERROR_CHECK(nrf_drv_clock_init());
        APP_ERROR_CHECK(app_timer_init());
        APP_ERROR_CHECK(bsp_init(BSP_INIT_BUTTONS, bsp_evt_handler));
        APP_ERROR_CHECK(bsp_buttons_enable());
        NRF_LOG_INFO("PWM example started.");
        init_bsp();
        bool accurate_HFCLK = true;
        if(accurate_HFCLK)
          // Start accurate HFCLK (XOSC), will consume more current!
          while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0) ;
        pwm_init();
        for (;;)
            // Wait for an event.
            __WFE();
            // Clear the event register.
            __SEV();
            __WFE();
            NRF_LOG_FLUSH();
