SDK 16.0 Adding Custom Service works but I can't see Custom Characteristic in nRF Connect
Hello!
I am new to developing with BLE so any help to this frustrating problem would be greatly appreciated!
Firstly, I am using SDK16, Soft Device 113, v.7.0.1 on a custom prototype board using an nrf52832 module.
I've worked through some of the examples on creating a custom service and associated characteristics. The project compiles without
errors and I can see my device in nRF Connect.  However, I can see only my custom service but not the characteristic I attached to it.
When I run the attach characteristic code, I get no error codes (just 0's).
static uint32_t red_char_add(ble_led_service_t * p_led_service) //might want init variable as well
	ret_code_t			err_code = 0;
    ble_gatts_char_md_t char_md;
    ble_gatts_attr_t    attr_char_value;
    ble_gatts_attr_md_t attr_md;
    ble_uuid_t          ble_uuid;
    memset(&char_md, 0, sizeof(char_md));
    memset(&attr_char_value, 0, sizeof(attr_char_value));
    memset(&attr_md, 0, sizeof(attr_md));
    memset(&ble_uuid, 0, sizeof(ble_uuid));
    char_md.char_props.read          = 1;
    char_md.char_props.write         = 1;
    char_md.p_char_user_desc         = RedLedCharName;
    char_md.char_user_desc_size      = sizeof(RedLedCharName);
    char_md.char_user_desc_max_size  = sizeof(RedLedCharName);
    char_md.p_char_pf                = NULL;
    char_md.p_user_desc_md           = NULL;
    char_md.p_cccd_md                = NULL;
    char_md.p_sccd_md                = NULL;
    // Attribute Metadata settings
    attr_md.vloc       = BLE_GATTS_VLOC_STACK;
    attr_md.rd_auth    = 0;
    attr_md.wr_auth    = 0;
    attr_md.vlen       = 0;
    // Define RedLED  UUID
    ble_uuid.type = p_led_service->uuid_type;
    ble_uuid.uuid = BLE_UUID_MAZU_HANDLE_RED_LED_CHAR;
    // Set permissions on the Characteristic value
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
    // Attribute Value settings
    attr_char_value.p_uuid       = &ble_uuid;
    attr_char_value.p_attr_md    = &attr_md;
    attr_char_value.init_len     = sizeof(uint16_t);
    attr_char_value.init_offs    = 0;
    attr_char_value.max_len      = sizeof(uint16_t);
    attr_char_value.p_value      = (uint8_t *)&redLedVal;
    err_code = sd_ble_gatts_characteristic_add(p_led_service->service_handle, &char_md,
    		                                           &attr_char_value,
    		                                           &p_led_service->red_led_handle);
    return err_code;
Similarly, my service registration code also works (with no errors):
void services_init(void)
    // Initialize Service structure and init structure to zero.
    //memset(&ledServiceVarInit, 0, sizeof(ledServiceVarInit));
    memset(&ledServiceVar, 0, sizeof(ledServiceVar));
    //Initialize LED Service
    err_code = ble_led_service_init(&ledServiceVar);
uint32_t ble_led_service_init(ble_led_service_t * p_led_service)
    uint32_t   err_code;
    ble_uuid128_t base_uuid = {BLE_UUID_LED_SERVICE_BASE_UUID};
    //Null check
    if (p_led_service == NULL)
        return NRF_ERROR_NULL;
    // Initialize service structure
    p_led_service->conn_handle = BLE_CONN_HANDLE_INVALID;
    // Add service UUID
    err_code = sd_ble_uuid_vs_add(&base_uuid, &p_led_service->uuid_type);
    VERIFY_SUCCESS(err_code);
    if (err_code != NRF_SUCCESS)
        return err_code;
    // Set up the UUID for the service (base + service-specific)
    ble_uuid.uuid = BLE_UUID_HANDLE_LED_SERVICE;
    // Set up and add the service
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_led_service->service_handle);
        return err_code;
    // Add the different characteristics in the service:
    err_code = red_char_add(p_led_service);
    return err_code;
Again, any help would be greatly appreciated!
