sdk ncs v1.3.
Example name: serial_lte_modem.
Example path: D:\ncs\v1.3.0\nrf\applications\serial_lte_modem
The error in opening this sample macro definition is as follows:
An example can be found in the annex as follows:
sdk ncs v1.3.
Is NCS installed via Toochain Manager? If so, is SES opened via Toochain Manager? Can you provide the full output (in output view) from SES?
Thanks
Øyvind
Hi Øyvind,
The following is the full log output
Kind regards. Peter.Min
Hi Peter,
My apologies for the late reply. Have you been able to solve this?
I was not able to reproduce this error. Did you try to restart SES? What version of the Toolchain Manager and nRF Connect for Desktop are you running?
Øyvind
Hi Øyvind,
Version information can be found in the figure below:
You can re-appear using the code I provided:
The code is as follows:
Hello Peter,
My sincere apologies for the late reply. I have been sleeping when reading your ticket text, and for that I apologize as well.
To enable SUPL in your project please follow the steps given under "Downloading and installing".
Øyvind
