Can we expect the S130 to support multiple Slave connections?
according to the BLE 4.1 spec, a device can be able to be slave in multiple piconets at the same time. Will this ever work with the S130? I do not know how the standard thinks this is possible because a Slave must always listen to the connection parameters give by its Master. If there are two Masters, it is likely that connection events will overlap and there is no possibility to solve this issue except disconnecting. Did I get this right? What do you think?
Marius
