ESD Causing Radio Failure
I've noticed three PCA10059 Dongles have failed in the past week.  One on my desk and the two on a co-worker's desk.  Its the same failure mode where everything appears to function properly MCU-wise, however there is no Bluetooth Activity.  The steps I've tasked to debug the hardware are as follows:
1)  Check if any GPIO pins are shorted to ground or low impedance
2) Tested with different LFCLK settings incase it was a crystal issue
3) Tested reverted code and Nordic example code
4) Replaced crystals
5) Heatgun on the board to reflow
All firmware runs fine, LED sequences shows operation appears to be normal.  However there is no radio activity as all.  Its not a huge issue as I can order more dongles, but I've never seen this particular failure mode as on reference designs at that.  Is this a failure mode anyone else has seen before?
Dave
