PIC18F4550 with Nordic nRF24L01
I am trying to get wireless communication implemented on a robotics project I am working on. I'm using a PIC18F4550, PIC18F2550, and two Nordic nRF24L01's. I'm having trouble on the transmission side; for some reason the IRQ pin does not toggle to indicate that a packet has been successfully sent.
I've included the code below, any help is much appreciated.
	Wireless communication using a PIC18F4550 (master) and nRF24L01 (slave) - Transmitter
		Includes
// Include files
#include <p18cxxx.h>						// Finds correct header for any PIC18
#include <delays.h>							// Enables you to add varying amount of NOPs (Delays)
#include <stdlib.h>
#include <spi.h>							// Just in case we want to cheat with SPI
// Define names for LED pins
//#define LED1 		PORTAbits.RA0			// blinky light (code is running)
#define LED1 		LATAbits.LATA0			// blinky light (code is running)
// Define names for SPI connection pins
//#define CE 			PORTAbits.RA2			// Chip Enable (CE)			-- Pin that activates RX or TX mode
#define CE 			LATAbits.LATA2			// Chip Enable (CE)			-- Pin that activates RX or TX mode
#define IRQ 		PORTBbits.RB2			// Interrupt Request (IRQ)	-- Pin that signals transmission
#define SDO 		TRISCbits.TRISC7		// Serial Data Out (SDO)	-- Pin that data goes out from
#define SDI 		TRISBbits.TRISB0		// Serial Data In (SDI)		-- Pin that data comes in to
#define SCK 		TRISBbits.TRISB1		// Serial Clock (SCK)		-- Pin that sends clock signal to sync all  SPI devices
// Define names for "Slave Select" pins
//#define SS  		PORTAbits.RA4			// Slave Select (SS)		-- Pin that selects "slave" module to communicate with
#define SS  		LATAbits.LATA4			// Slave Select (SS)		-- Pin that selects "slave" module to communicate with
#define select 		0						// Device is "active low," define "select" as 0
#define deselect	1
// Define names for SPI configuration pins
#define SMP			SSPSTATbits.SMP			// Sample Bit (SMP)			-- Pin that sets where to sample data
#define CKP			SSPCON1bits.CKP			// Clock Polarity (CKP)		-- Pin that sets where SCK will idle
#define CKE			SSPSTATbits.CKE			// Clock Edge Select (CKE)	-- Pin that sets which transition transmission takes place
#define SSPEN		SSPCON1bits.SSPEN		// Serial Prt Enbl (SSPEN)	-- Pin that will enable serial port and configure SCK, SDO, SDI and SS as serial port pins
#define WCOL		SSPCON1bits.WCOL		// Write Collision (WCOL)	-- Detect bit
//#define WCOL_LED	PORTCbits.RC1			// Write Collision (WCOL)	-- Pin for collision visual
#define WCOL_LED	LATCbits.LATC1			// Write Collision (WCOL)	-- Pin for collision visual
// Define commands for Nordic via SPI
#define R_REGISTER		0x00
#define W_REGISTER		0x20
#define R_RX_PAYLOAD	0x61
#define W_TX_PAYLOAD	0xA0
#define FLUSH_TX		0xE1
#define FLUSH_RX		0xE2
#define REUSE_TX_PL		0xE3
#define NOP				0xFF
// Define Nordic registers
#define CONFIG			0x00
#define EN_AA			0x01
#define EN_RXADDR		0x02
#define SETUP_AW		0x03
#define SETUP_RETR		0x04
#define RF_CH			0x05
#define RF_SETUP		0x06
#define STATUS			0x07
#define OBSERVE_TX		0x08
#define CD				0x09
#define RX_ADDR_P0		0x0A
#define RX_ADDR_P1		0x0B
#define RX_ADDR_P2		0x0C
#define RX_ADDR_P3		0x0D
#define RX_ADDR_P4		0x0E
#define RX_ADDR_P5		0x0F
#define TX_ADDR			0x10
#define RX_PW_P0		0x11
#define RX_PW_P1		0x12
#define RX_PW_P2		0x13
#define RX_PW_P3		0x14
#define RX_PW_P4		0x15
#define RX_PW_P5		0x16
#define FIFO_STATUS		0x17
		Function Prototypes & Variables
void initChip(void);
void init_spi_master(void);
void init_nordic(void);
void InterruptHandler_SPI(void);
void InterruptHandler_Nordic(void);
void delay(void);
void spi_write(int data);
void transmit_data(int data);
unsigned char spi_transmission_done;
unsigned char data_sent;
unsigned char data;
unsigned char dummy;
  RESET VECTORS: REMOVE IF NOT USING BOOTLOADER!!!
extern void _startup (void);
#pragma code _RESET_INTERRUPT_VECTOR = 0x000800
void _reset (void)
    _asm goto _startup _endasm
#pragma code
  Interrupt Service Routines
#pragma code _HIGH_INTERRUPT_VECTOR = 0x000808
void _high_ISR (void)
	InterruptHandler_SPI();
	InterruptHandler_Nordic();
#pragma code
#pragma code _LOW_INTERRUPT_VECTOR = 0x000818
void _low_ISR (void)
#pragma code
void delay() {
	int counter = 0;
    for (counter = 0; counter<30000; counter++) {
	Interrupt Handlers
#pragma interrupt InterruptHandler_SPI
void InterruptHandler_SPI(void) {
   if(PIR1bits.SSPIF == 1)	// SPI Interrupt
		PIR1bits.SSPIF = 0; // clear interrupt
		spi_transmission_done = 1;
#pragma interrupt InterruptHandler_Nordic
void InterruptHandler_Nordic(void) {
	if(INTCON3bits.INT2IF == 1)	// Nordic Interrupt
		INTCON3bits.INT2IF = 0; // clear interrupt
//		spi_write(W_REGISTER+STATUS); // Write to the STATUS register
//		spi_write(0b01111110);		  	  // Reset
//		spi_write(FLUSH_TX); 		    // Flush the FIFO
		data_sent = 1;
			Initialize the PIC
void initChip(){
	PORTA = 0x00;			// reset all PORT registers
	PORTB = 0x00;
	PORTC = 0x00;
	PORTD = 0x00;
	PORTE = 0x00;
	TRISA = 0x00;			// set all PORTA to be OUTPUT
	TRISB = 0b00000101;		// set RB0 and RB2 as INPUT
							// and the rest of PORTB as OUTPUT
	TRISC = 0x00;			// set all PORTC to be OUTPUT
	TRISD = 0x00;			// set all PORTD to be OUTPUT
	TRISE = 0x00;			// set up PORTE to be OUTPUT
	ADCON1 = 0b00001111;	// set up PORTA to be digital I/Os
	spi_transmission_done = 0; // initilize variables
	data_sent = 0;
	dummy = 0b00000000;
	data = 0b11111111;
			Initialize the SPI Master
void init_spi_master() {
	SDI = 1;	// Serial Data In 			- enable master mode
	SCK = 0;	// Serial Clock				- clear TRISB1 for master
	SDO = 0;	// Serial Data Out 			- clear TRISC7
	SS = deselect;
	SMP = 0;	// Sample bit 				- sample in middle
	CKP = 0;	// Clock Polarity			- low when idle		**MUST BE SAME ON MASTER AND SLAVE**
	CKE = 0;	// Clock Edge Select		- transmit on transition from idle clock state to active
	SSPCON1bits.SSPM3 = 0;	// Set the clock rate in master mode
	SSPCON1bits.SSPM2 = 0;	// to be FOSC/16 (Frequency of Oscillation)
	SSPCON1bits.SSPM1 = 0;
	SSPCON1bits.SSPM0 = 1;
	SSPEN = 0;	// Wait to enable serial port and configure SCK, SDO, SDI and SS as serial port pins
	PIE1bits.SSPIE = 1;	// enable SPI interrupt
			Initialize the Nordic
void init_nordic() {
	RCONbits.IPEN = 1;			// enable priorities levels on interrupts
	INTCON3bits.INT2IE = 1;		// enable the INT2 (IRQ) external interrupt
	INTCON3bits.INT2IP = 1;		// IRQ is high priority
	INTCON2bits.INTEDG2 = 0;	// IRQ is triggered on falling edge
	spi_write(W_REGISTER+CONFIG); 	// Write to the CONFIG register
	spi_write(0b01001110);		  	  // [7] Reserved
									  // [6] RX_DR Interrupt 1 - mask
									  // [5] TX_DS Interrupt 0 - unmask
									  // [4] MAX_RT Interrupt
									  // [3] Enable CRC
									  // [2] 2 byte CRC
									  // [1] PWR_UP
									  // [0] TX
	spi_write(W_REGISTER+SETUP_AW); // Write to the SETUP_AW register
	spi_write(0b00000011);		  	  // Set the width to 5 bytes
	CE = 0;						    // hold CE low to transmit
			Functions for Writing Data
void spi_write(int data) {
	SSPEN = 1;			   // Enable serial port and configure SCK, SDO, SDI and SS as serial port pins
	if(WCOL == 0) { 	   // collision testing
		SS = select;
		SSPBUF = data;
		SS = deselect;
	else {				   // there is a collision
		WCOL = 0;
		WCOL_LED = !WCOL_LED; //visual to see a collision
	delay();  // band-aid that fixes collisions during multiple writes
void transmit_data(int data) {
	data_sent = 0;
	spi_write(W_TX_PAYLOAD);	// send command for transmission
	spi_write(data);			// load data
	CE = 1;						// toggle CE for >10ns to send packet
	delay();
	CE = 0;
/* Main Program                                                               */
void main() {
	initChip();
	init_spi_master();
	init_nordic();
	INTCONbits.GIEH = 1;    // enables all high priority interrupts
	INTCONbits.GIEL = 1;    // enables all low priority interrupts
	transmit_data(data);	// send some data
	while (1) {
		LED1 = !LED1; 		// toggle LED - program is running
		dummy = SSPBUF;		// in case there is something in there, get rid of it
		if(IRQ == 0){
				PORTD = 0b11111111;
		if(spi_transmission_done == 1){
				dummy = SSPBUF;
		if(data_sent == 1){
				PORTD = 0b11111111;
				transmit_data(data);	// send some more data
		delay(); // LED blinks
		data++;
  • It's been a while since I did any work with the nRF24L01+, but it seems you are writing one byte at a time, and set SS high and low for each byte. If that is the case then you are not actually writing anything to a specific register or payload, you are just writing commands without any data. Take a look at Figure 27. in datasheet: www.nordicsemi.com/.../nRF24L01P_Product_Specification_1_0.pdf
    There are some commands that doesn't require any data, but most do, ref Table 20.
  • Thanks for pointing that out! However, I am still encountering some problems. I'm write to the CONFIG register and then when I try to read what I just wrote, I get back some garbage.
    After looking at the datasheet, I tried writing to the register twice thinking that the PWR_UP but must be set first before commanding the other bits, but that doesnt work either...
    Any thoughts?
    	SS = select;
    	spi_write(0b01011110);		  	  // [7] Reserved as 0
    									  // [4] MAX_RT Interrupt 1 - mask
    									  // [3] Enable CRC
    									  // [2] 2 byte CRC
    									  // [1] PWR_UP
    									  // [0] TX 0
    	SS = deselect;
    	DelayMS(2); // time for PWR_UP
    	SS = select;
    									  // [3] Enable CRC
    									  // [2] 2 byte CRC
    									  // [1] PWR_UP
    									  // [0] TX 0
    	SS = deselect;
    	SS = select;
    	spi_write(R_REGISTER+CONFIG);   // Read the CONFIG register
    	spi_write(0b00000000);   // Read the CONFIG register
    	SS = deselect;
  • For some reason the PWR_UP bit is still not being set... Any ideas?
    /***************************************************** Includes **************************************************** */
    // Include files #include // Finds correct header for any PIC18 #include // Enables you to add varying amount of NOPs (Delays) #include #include // Just in case we want to cheat with SPI
    // Define names for LED pins #define LED1 LATAbits.LATA0 // blinky light (code is running)
    // Define names for SPI connection pins #define CE LATAbits.LATA2 // Chip Enable (CE) -- Pin that activates RX or TX mode #define IRQ PORTBbits.RB2 // Interrupt Request (IRQ) -- Pin that signals transmission #define SDO TRISCbits.TRISC7 // Serial Data Out (SDO) -- Pin that data goes out from #define SDI TRISBbits.TRISB0 // Serial Data In (SDI) -- Pin that data comes in to #define SCK TRISBbits.TRISB1 // Serial Clock (SCK) -- Pin that sends clock signal to sync all SPI devices
    // Define names for "Slave Select" pins #define SS LATAbits.LATA4 // Slave Select (SS) -- Pin that selects "slave" module to communicate with
    #define select 0 // Device is "active low," define "select" as 0 #define deselect 1
    // Define names for SPI configuration pins #define SMP SSPSTATbits.SMP // Sample Bit (SMP) -- Pin that sets where to sample data #define CKP SSPCON1bits.CKP // Clock Polarity (CKP) -- Pin that sets where SCK will idle #define CKE SSPSTATbits.CKE // Clock Edge Select (CKE) -- Pin that sets which transition transmission takes place #define SSPEN SSPCON1bits.SSPEN // Serial Prt Enbl (SSPEN) -- Pin that will enable serial port and configure SCK, SDO, SDI and SS as serial port pins
    #define WCOL SSPCON1bits.WCOL // Write Collision (WCOL) -- Detect bit #define WCOL_LED LATCbits.LATC0 // Write Collision (WCOL) -- Pin for collision visual #define MAXRT_LED LATCbits.LATC1 // MAX_RT -- Pin for max retries visual #define TX_LED LATCbits.LATC2 // TX_DS -- Pin for transmission successful visual
    // Define commands for Nordic via SPI #define R_REGISTER 0x00 #define W_REGISTER 0x20
    // Define Nordic registers #define CONFIG 0x00 #define STATUS 0x07
    /***************************************************** Function Prototypes & Variables **************************************************** */
    void initChip(void); void init_spi_master(void); void init_nordic(void); void InterruptHandler_SPI(void); void DelayMS(unsigned long milliseconds); void spi_write(int data);
    /************************************************* RESET VECTORS: REMOVE IF NOT USING BOOTLOADER!!! **************************************************/
    #pragma code _RESET_INTERRUPT_VECTOR = 0x000800 void _reset (void) { _asm goto _startup _endasm } #pragma code
    /************************************************* Interrupt Service Routines **************************************************/
    //#pragma code _HIGH_INTERRUPT_VECTOR = 0x000808 //void _high_ISR (void) //{ // InterruptHandler_SPI(); //} //#pragma code
    void DelayMS(unsigned long milliseconds) { unsigned long count;
    for(count = 0; count ad the CONFIG register
    SS = deselect;
    /************************************************* Functions for Writing Data **************************************************/
    	SSPBUF = data;
    	WCOL = 0;
    while(!DataRdySPI());
    PORTD = SSPBUF;
    // / Main Program / //
    void main() { initChip(); init_spi_master(); // INTCONbits.GIEH = 1; // enables all high priority interrupts // INTCONbits.GIEL = 1; // enables all low priority interrupts init_nordic(); while (1){ } }
    SS = deselect;
    	SSPBUF = data;
    	WCOL = 0;
    PORTD = SSPBUF;
  • As Kenneth says, you should make sure to don't toggle chip select in between each byte. Also, if you're not able to read out a single register from the nRF24L01+ properly, you should make sure that your SPI interface complies with all the requirements in the nRF24L01+ specification.
    To verify that things are working correctly, you can try to read out a registers with known reset values, and first make sure that you get the correct values. The reset value of all registers are given in the product specification.
