hi, i add bond function on my project , now the Master Control Panel can work correctly(show the Confirm Box ) but the iOS app(on LightBlue),not show any Confirm Box for pairing.
In my opinion,the bond function is on the GAP. The BLE service and Characteristics no relation with bond.
can you give some suggestion ?
follow my code:
to redefine macro
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 1 /**< Man In The Middle protection required (applicable when display module is detected). */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_DISPLAY_ONLY
add the new macro for bond data
#define FLASH_PAGE_SYS_ATTR (BLE_FLASH_PAGE_END - 3) /**< Flash page used for bond manager system attribute information. */
#define FLASH_PAGE_BOND (BLE_FLASH_PAGE_END - 1)
and the ble event handle function
static void on_ble_evt(ble_evt_t * p_ble_evt)
err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
BLE_GAP_SEC_STATUS_SUCCESS,
&m_sec_params);
case BLE_GAP_EVT_TIMEOUT:
if (p_ble_evt->evt.gap_evt.params.timeout.src == BLE_GAP_TIMEOUT_SRC_ADVERTISEMENT)
nrf_gpio_pin_clear(ADVERTISING_LED_PIN_NO);
GPIO_WAKEUP_BUTTON_CONFIG(KEY_PRESS_BUTTON_PIN_NO);
GPIO_WAKEUP_BUTTON_CONFIG(BONDMNGR_DELETE_BUTTON_PIN_NO);
case BLE_GAP_EVT_PASSKEY_DISPLAY:
p_passkey = (char *)p_ble_evt->evt.gap_evt.params.passkey_display.passkey;
success = nrf6350_lcd_write_string(PASSKEY_TXT,
PASSKEY_TXT_LENGTH,
LCD_UPPER_LINE,
0);
APP_ERROR_CHECK_BOOL(success);
case BLE_GAP_EVT_AUTH_STATUS:
case BLE_GAP_EVT_CONN_SEC_UPDATE:
add the ble_bondmngr_on_ble_evt
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
ble_bondmngr_on_ble_evt(p_ble_evt);
ble_gls_on_ble_evt(&m_gls, p_ble_evt);
ble_bas_on_ble_evt(&m_bas, p_ble_evt);
ble_conn_params_on_ble_evt(p_ble_evt);
