getting gatt error while uploading the firmware over ota
hi..
development board - nRF52832
SDK version -15.2 version
Fellowed method - B1b. Use Oberon crypto library instead of uECC
softdevice version - v 6.1.0
tools using - nrfconnect to upload the secure bootloader and softdevice .
generated the zip file by using the below
nrfutil pkg generate --hw-version 52 --application-version 1 --application ble_app_blinky_pca10040_s132.hex --sd-req 0xAF --sd-id 0xAF --key-file private.key blinky_package.zip
while i am uploading the zip file over ota i am getting the gatt error ,
i am using nrftoolbox , dfu option to upload the file .
when i am clicking the upload file ,it is reaching upto 18% after that it is throwing the error ,  led state changing from led1 and led2  to led1 and led3 is blinking , why i am getting this error please suggest  me
    Have you tried using the debug variant of the bootloader(pca10040_ble_debug), and see if you get any errors or asserts printed in the terminal?
    PS: If you are having issues with the RTT logging, then you might need to set NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED in sdk_config.h to 0
  • yes i tried .
    In app i am getting the gatt error 0x85 error
    <info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <warning> nrf_dfu_settings: Resetting bootloader settings since neither the settings page nor the backup are valid (CRC error).
    <debug> nrf_dfu_settings: Writing settings...
    <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 0
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x200091BC, len=440 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <debug> app: Enter nrf_dfu_app_is_valid
    <debug> app: No valid app to boot.
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: timer_stop (0x200057D4)
    <debug> app: timer_activate (0x200057D4)
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_ble: Initializing BLE DFU transport
    <debug> nrf_dfu_ble: Setting up vector table: 0x00072000
    <debug> nrf_dfu_ble: Enabling SoftDevice.
    <debug> nrf_dfu_ble: Configuring BLE stack.
    <debug> nrf_dfu_ble: Enabling the BLE stack.
    <debug> nrf_dfu_ble: No advertising name found
    <debug> nrf_dfu_ble: Using default advertising name
    <debug> nrf_dfu_ble: Advertising...
    <debug> nrf_dfu_ble: BLE DFU transport initialized.
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
    <debug> app: Enter main loop
    <debug> nrf_dfu_ble: Connected
    <debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST.
    <debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE (27, max_rx_time 328).
    <debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
    <debug> nrf_dfu_ble: max_conn_interval: 12
    <debug> nrf_dfu_ble: min_conn_interval: 12
    <debug> nrf_dfu_ble: slave_latency: 0
    <debug> nrf_dfu_ble: conn_sup_timeout: 600
    <debug> nrf_dfu_ble: max_conn_interval: 6
    <debug> nrf_dfu_ble: min_conn_interval: 6
    <debug> nrf_dfu_ble: conn_sup_timeout: 500
    <debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 517, reply: 247).
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_ble: Set receipt notif
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
    <debug> app: Shutting down transports (found: 1)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    <debug> nrf_dfu_ble: Buffer 0x20008120 acquired, len 141 (244)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
    <debug> nrf_dfu_ble: Freeing buffer 0x20008120
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    <debug> nrf_dfu_validation: PB: Init packet data len: 64
    <info> nrf_dfu_validation: Signature required. Checking signature.
    <info> nrf_dfu_validation: Calculating init packet hash (init packet len: 64)
    <info> nrf_dfu_validation: Verify signature
    <info> nrf_dfu_validation: Image verified
    <debug> app: Enter nrf_dfu_cache_prepare()
    <debug> app: required_size: 0x574C.
    <debug> app: single_bank: false.
    <debug> app: keep_app: false.
    <debug> app: keep_softdevice: true.
    <debug> app: SD_PRESENT: true.
    <debug> app: Bank contents:
    <debug> app: Bank 0 code: 0x00: Size: 0x0
    <debug> app: Bank 1 code: 0x00: Size: 0x0
    <debug> app: pass: 0.
    <debug> app: cache_address: 0x26000.
    <debug> app: cache_too_small: false.
    <debug> app: keep_firmware: false.
    <debug> app: delete_more: false.
    <debug> nrf_dfu_validation: Write address set to 0x00026000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x200091BC, len=440 bytes), queue usage: 2
    <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
    <debug> nrf_dfu_settings: Erasing old settings at: 0x0007E000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 3
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x20009374, len=440 bytes), queue usage: 4
    <debug> nrf_dfu_req_handler: Writing valid init command to flash.
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
    <debug> nrf_dfu_req_handler: crc = 0x0, offset = 0x0, max_size = 0x1000
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 4
    <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 3
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00026000, len=1 pages), queue usage: 3
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
    Error 133 (0x85): GATT ERROR is an generic error, it happens in different occasions. We have observed it on:
    1) Packet collision
    2) CONNECT_REQ missed by the target
    3) Timeout (30 or 20 seconds after connection was initiated)
    4) in general, an expected packet wasn't received or an unexpected was.
    It used to be much more common in the old days, now we see it less and less with the new phones, but the low-end devices might see this issue.
    What phone model/brand are you using ? Do you see this issue on several phones, or only on one phone ?
