How to configure and setup an SPI device to nRF5340
I am trying to setup a device (Semtech LR1110) connected to SPI 1 peripheral on the nRF5340pdk.
I have a driver code for it. My question is this.
How can I set it up in the .dts file and keep the code that drives it with my source code on my local drive without having to put it the C:\Zypher\v1.3.0\zephyr\drivers\LR1110?
Q1/ Will the proposed Device Tree fragment do the job?
spi1: spi@9000 {
   compatible = "nordic,nrf5340";
   status = "okay";
   reg = < 0x9000 0x1000 >;
   interrupts = < 0x9 0x1 >;
   label = "SPI_1";
   sck-pin = < 0x?? >;
   mosi-pin = < 0x?? >;
   miso-pin = < 0x?? >;
Q2/ How do I get the device binding to work?
Will this work?
device_get_binding( DT_PROP( DT_NODELABEL(spi1), label );
Thank you.
Kind regards
  • Hi Hakon,
    I've  re-downloaded the zip file and extracted ok.
    I opened the project spi_example and built it ok.
    I then commented out the line CONFIG_BOARD_ENABLE_CPUNET=n in prj.conf.
    I tried to open the project but failed as with the old SES version.
    I re-instated the line CONFIG_BOARD_ENABLE_CPUNET=n in prj.conf again in prj.conf but I still cannot reload the project. Below is the error.
    This is very bizarre. SES seems to be very moody, one minute it is happy the next it is not.
    Thank you for your help.
    Kind regards
    Mohamed
     Could you click on "OK" and paste the full output from the build-window in SES? I can see that the failure is in line 35 of ZephyrConfig.cmake, but it would be good to see if there's anything interesting before that.
    Håkon
  • As I said in my previous post, SES v5.10d is very moody. Guess what? I can open and build the solution now. This is with the line CONFIG_BOARD_ENABLE_CPUNET=n enabled. However, when I commented it out I could not open the project. Below is the error log.
    Creating solution spi_test.emProject
    cmake -GNinja -DBOARD=nrf5340pdk_nrf5340_cpuapp -DBOARD_DIR=C:\Zypher\v1.3.0\zephyr\boards\arm\PID4_nRF5340 -BC:\Dev\NCS_projects\spi_example\spi_test\build_SESv510d_nrf5340pdk_nrf5340_cpuapp -SC:\Dev\NCS_projects\spi_example\spi_test -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:\Zypher\v1.3.0\toolchain\opt -DDTC_OVERLAY_FILE=C:\Dev\NCS_projects\spi_example\spi_test/nrf5340pdk_nrf5340_cpuapp.overlay -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:\Program Files\SEGGER_V5.10c\arm_segger_embedded_studio_v510d_win_x64_nordic/html/configure_nordic_project_menuconfig.py
    -- Application: C:/Dev/NCS_projects/spi_example/spi_test
    -- Zephyr version: 2.3.0-rc1 (C:/Zypher/v1.3.0/zephyr)
    -- Found Python3: C:/Program Files/WindowsApps/PythonSoftwareFoundation.Python.3.8_3.8.1776.0_x64__qbz5n2kfra8p0/python3.8.exe (found suitable version "3.8.6", minimum required is "3.6") found components: Interpreter
    -- Board: nrf5340pdk_nrf5340_cpuapp
    -- Found west: C:/Zypher/v1.3.0/toolchain/opt/bin/Scripts/west.exe (found suitable version "0.7.3", minimum required is "0.7.1")
    -- Found toolchain: gnuarmemb (C:/Zypher/v1.3.0/toolchain/opt)
    -- Found BOARD.dts: C:/Zypher/v1.3.0/zephyr/boards/arm/PID4_nRF5340/nrf5340pdk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: C:\Dev\NCS_projects\spi_example\spi_test/nrf5340pdk_nrf5340_cpuapp.overlay
    Including boilerplate (Zephyr base): C:/Zypher/v1.3.0/zephyr/cmake/app/boilerplate.cmake
    In file included from C:/Zypher/v1.3.0/zephyr/boards/arm/PID4_nRF5340/nrf5340pdk_nrf5340_cpuapp.dts:9,
    from <command-line>:
    C:/Zypher/v1.3.0/zephyr/boards/arm/PID4_nRF5340/nrf5340_cpuapp_common.dts:179:10: fatal error: nrf5340_cpuapp_partition_conf.dts: No such file or directory
    179 | #include "nrf5340_cpuapp_partition_conf.dts"
    compilation terminated.
    CMake Error at C:/Zypher/v1.3.0/zephyr/cmake/dts.cmake:146 (message):
    command failed with return code: 1
    C:/Zypher/v1.3.0/zephyr/cmake/app/boilerplate.cmake:505 (include)
    C:/Zypher/v1.3.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
    C:/Zypher/v1.3.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
    CMakeLists.txt:13 (find_package)
    error: cmake failed
    create_nordic_project.py failed (1)
    Thank you
    Kind regards
    Mohamed
    Is this a board that you have defined?
    Does this file exist in your PID4_nRF5340/ folder?
    Håkon
  • Hi Hakon,
    It is a board that is being defined but not complete yet.  It is work in progress and I was not expecting this board to be picked up. The board intended to be used is the nRF5340pdk_nRF5340.                     C:\Zypher\v1.3.0\zephyr\boards\arm\nrf5340pdk_nrf5340
    No, it does not exist.
    Kind regards
    Mohamed
