How to configure and setup an SPI device to nRF5340
I am trying to setup a device (Semtech LR1110) connected to SPI 1 peripheral on the nRF5340pdk.
I have a driver code for it. My question is this.
How can I set it up in the .dts file and keep the code that drives it with my source code on my local drive without having to put it the C:\Zypher\v1.3.0\zephyr\drivers\LR1110?
Q1/ Will the proposed Device Tree fragment do the job?
spi1: spi@9000 {
   compatible = "nordic,nrf5340";
   status = "okay";
   reg = < 0x9000 0x1000 >;
   interrupts = < 0x9 0x1 >;
   label = "SPI_1";
   sck-pin = < 0x?? >;
   mosi-pin = < 0x?? >;
   miso-pin = < 0x?? >;
Q2/ How do I get the device binding to work?
Will this work?
device_get_binding( DT_PROP( DT_NODELABEL(spi1), label );
Thank you.
Kind regards
    Do you still get the same issue if you move this board out of the boards/arm folder? If it is work-in-progress, it might be that the build system picks it up, especially if the names within the folder isn't changed.
    Håkon
  • Hi Hakon,
    Both SES v452c and v510d are behaving themselves now :), meaning I can open and build the project with this commented out line
    #CONFIG_BOARD_ENABLE_CPUNET=n
    However, I am having other problems with SES when sometimes, at random times, SES (v452c and v510d) cannot open a project that has not been changed for a while and was working fine before. If I keep trying few times it eventually works. See pictures and error log below.
    Have you come across this problem before?
    What am I doing wrong?
    Could it be something to do with my laptop because I have not restarted it for over a week now?
    Loading solution light_controller-Pot.emProject
    Executing load commands
    cmake -GNinja -DBOARD=nrf5340pdk_nrf5340_cpuapp -DBOARD_DIR=C:/Zypher/v1.3.0/zephyr/boards/arm/nrf5340pdk_nrf5340 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/Zypher/v1.3.0/toolchain/opt -BC:/Dev/NCS_projects/light_controller-Pot/build_nrf5340pdk_nrf5340_cpuapp -HC:/Dev/NCS_projects/light_controller-Pot -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:/Zypher/v1.3.0/toolchain/segger_embedded_studio/html/configure_nordic_project_menuconfig.py
    Including boilerplate (Zephyr base (cached)): C:/Zypher/v1.3.0/zephyr/cmake/app/boilerplate.cmake
    -- Application: C:/Dev/NCS_projects/light_controller-Pot
    -- Zephyr version: 2.3.0-rc1 (C:/Zypher/v1.3.0/zephyr)
    CMake Error at C:/Zypher/v1.3.0/zephyr/cmake/extensions.cmake:926 (file):
      file failed to open for writing (Permission denied):
        C:/Dev/NCS_projects/light_controller-Pot/build_nrf5340pdk_nrf5340_cpuapp/zephyr/include/generated/snippets-sections.ld
      C:/Zypher/v1.3.0/zephyr/cmake/app/boilerplate.cmake:134 (zephyr_linker_sources)
      C:/Zypher/v1.3.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
      C:/Zypher/v1.3.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
      CMakeLists.txt:3 (find_package)
    CMake Error at C:/Zypher/v1.3.0/zephyr/cmake/extensions.cmake:927 (file):
        C:/Dev/NCS_projects/light_controller-Pot/build_nrf5340pdk_nrf5340_cpuapp/zephyr/include/generated/snippets-ram-sections.ld
    CMake Error at C:/Zypher/v1.3.0/zephyr/cmake/extensions.cmake:928 (file):
        C:/Dev/NCS_projects/light_controller-Pot/build_nrf5340pdk_nrf5340_cpuapp/zephyr/include/generated/snippets-rom-start.ld
    CMake Error at C:/Zypher/v1.3.0/zephyr/cmake/extensions.cmake:929 (file):
        C:/Dev/NCS_projects/light_controller-Pot/build_nrf5340pdk_nrf5340_cpuapp/zephyr/include/generated/snippets-noinit.ld
    CMake Error at C:/Zypher/v1.3.0/zephyr/cmake/extensions.cmake:930 (file):
        C:/Dev/NCS_projects/light_controller-Pot/build_nrf5340pdk_nrf5340_cpuapp/zephyr/include/generated/snippets-rwdata.ld
    CMake Error at C:/Zypher/v1.3.0/zephyr/cmake/extensions.cmake:931 (file):
        C:/Dev/NCS_projects/light_controller-Pot/build_nrf5340pdk_nrf5340_cpuapp/zephyr/include/generated/snippets-rodata.ld
    -- Board: nrf5340pdk_nrf5340_cpuapp
    -- Found west: C:/Zypher/v1.3.0/toolchain/opt/bin/Scripts/west.exe (found suitable version "0.7.3", minimum required is "0.7.1")
    -- Found toolchain: gnuarmemb (C:/Zypher/v1.3.0/toolchain/opt)
    CMake Error at C:/Zypher/v1.3.0/zephyr/cmake/dts.cmake:3 (file):
      file problem creating directory:
      C:/Zypher/v1.3.0/zephyr/cmake/app/boilerplate.cmake:505 (include)
    -- Found BOARD.dts: C:/Zypher/v1.3.0/zephyr/boards/arm/nrf5340pdk_nrf5340/nrf5340pdk_nrf5340_cpuapp.dts
    cc1.exe: fatal error: opening output file C:/Dev/NCS_projects/light_controller-Pot/build_nrf5340pdk_nrf5340_cpuapp/zephyr/nrf5340pdk_nrf5340_cpuapp.dts.pre.tmp: Permission denied
    compilation terminated.
    CMake Error at C:/Zypher/v1.3.0/zephyr/cmake/dts.cmake:146 (message):
      command failed with return code: 1
    Project load failed
    Reported error: solution load command failed (1)
    Kind regards
    Mohamed
    Great!
    The log states that you have permission error:
    "file failed to open for writing (Permission denied)"
    Try deleting the build folder and re-import the project.
    Håkon
  • Hi Hakon,
    This does not make sense since I have admin rights on my machine. Plus, this problem is intermittent, one minute I don't have permission and the next I have full permission. It is frustrating and time consuming.
    I do try to delete the build folder, again it does not make sense, sometimes I can and at other times I am not allowed to delete the folder build/zephyr. I can delete its content but not the folder itself Disappointed.
    Has this type pf problems been reported by other users? I know a colleague of mine is having similar issues.
    It would be greatly appreciated if you could help us come to the bottom of this and find the root cause. Because I  know I will be facing the same problem soon.
    Kind regards
    Mohamed
    If there's some program (notepad or similar) that has opened up one of the files in the build folder, windows will not allow you to delete the file.
    Could this be the case here? There's a process keeping one of the files open?
    This sounds like a process is keeping the folder open. Its a generic problem on windows:
    https://superuser.com/questions/1333118/cant-delete-empty-folder-because-it-is-used
    Håkon
