Hex file flashing using cli on to the NRF52840 target board.
Hello
I'm using the  nrf52840 DK with sdk version of 15.0.0.
My requirement is to flash my project through cli commands, so I have followed the following steps in below.
1) For my project I have used the ble_app_freertos example project.
2) Then Executed the "MAKE" command at the following location where the makefile.txt is located. "C:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_hrs_freertos\pca10056\s140\armgcc"
3) After a successful build process a "_build" folder will be generated at the same location, that folder comprises of generated file like below.
   a) nrf52840_xxaa.bin
   b) nrf52840_xxaa.hex
  c)  nrf52840_xxaa.in
  d) nrf52840_xxaa.out
  e) nrf52840_xxaa.map
4) Now I will change directory to the "_build" folder, then I executed the following commands
 "nrfjprog -f NRF52 --program nrf52840_xxaa.hex --chiperase"   to dump the hex file into nrf52840 DK.
"nrfjprog -f nrf52 --reset" for resetting the device.
After this actual output is "the device has to advertise"
But I'm not getting the actual output. so can anyone explain,
1) How to flash the ble_peripheral project to the target boards using cli commands like nrjprog?
2) Is there any wrong in my procedure, if yes then what is the correct way to do this?
