nrf9160dk SPI pins
From the datasheet I understand that any pins in port0 can be used as SPI. But I tried using the pins defined in nrf-sdk here and but there is no response. After searching through devzone, I found pins 11 and 12 can act as MOSI and MISO and I tested it working with spi_loopback. But I couldn't find correct pins to use for CS and SCK. Also I need 2 more pins for SPI slave interrupt and Reset control.
How to configure any pins to act as SPI? I am fine with disabling other interfaces like UART1, UART2 if pin clashes.
Board: nrf9160DK
SDK(latest) : https://github.com/nrfconnect/sdk-zephyr
SDK nrf: https://github.com/nrfconnect/sdk-zephyr
EDIT:
SPI works fine with https://docs.zephyrproject.org/latest/boards/arm/actinius_icarus/doc/index.html Actinius Icarus board and the pins are here.
Thanks in advance for sharing the details.
