SPI_Master_Example .. Where is SPI_MASTER_0_ENABLE defined?
I went to so many references and definitions of variables and functions but I can't seem to find where is decided to use either spi_master_0 or 1.. where is this magic config file mentioned here:
  • This example uses only one instance of the SPI master.
  • Please make sure that only one instance of the SPI master is enabled in config file.
or what exactly does this do:
#if defined(SPI_MASTER_0_ENABLE)
    #define SPI_MASTER_HW SPI_MASTER_0
#elif defined(SPI_MASTER_1_ENABLE)
    #define SPI_MASTER_HW SPI_MASTER_1
#else
    #error "No SPI enabled"
It defines SPI_MASTER_HW SPI_MASTER_0 when SPI_MASTER_0_ENABLE is defined? But where is SPI_MASTER_0_ENABLE defined??? I can't seem to find it nowhere.
  • In Keil defining a constandName in targetoptions is similar to giving gcc -DsomeDevineName at the compile options. This values are passed to the preprocessing of the compilation stage. You could overwrite these defines in the source and header files.
