USB interface in light switch client implemented for nrf-dongle gives mesh assert upon receiving data on USB
Using
SW : NRF_SDK_16, SDK_MESH_v4.0
HW:  NRF52840 DONGLE.
I have implemented light_switch_client which also has USB part initialization and then added in USB_DONGLE. I have followed below mentioned guide for the necessary changes while loading the code in dongle
https://devzone.nordicsemi.com/nordic/short-range-guides/b/getting-started/posts/nrf52840-dongle-programming-tutorial
Now my PC detects Dongle as one of the USB ports.All I want to do is send the data from serial terminal on detected USB PORT and then publish it over the mesh.
Issue as below :-
I am getting app_error_weak.c,  105, Mesh assert at 0x0002C8FA (:0) upon trying to publish the received data over mesh.
1.I think this issue is related to interrupt priority of USB and MESH. Mesh uses NRF_MESH_IRQ_PRIORITY_LOWEST where as USB uses NRFX_USBD_CONFIG_IRQ_PRIORITY 6  as a interrupt priority levels.
Please see the attached code for the reference
        case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
            index++;
            do
              if(m_cdc_data_array[index-1]==0xFA && m_cdc_data_array[index-2]==0x5F)
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "ready to publish\n");
                app_onoff_status_publish(&m_onoff_server_0); // publishing the data here which causes the error
                index=0;
                memset(m_cdc_data_array,0,sizeof(m_cdc_data_array));
              ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
                                         &m_cdc_data_array[index],
                                         1);
              if (ret == NRF_SUCCESS)
                    index++;
             __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "--index=%d-----\n",index);
             __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO,"RX: Msg : Received", m_cdc_data_array,index);
            }while(ret == NRF_SUCCESS);
