It looks like "SPI event handler" is not processed when we control slave select pin manually
we have interfaced Accelerometer Module with NRF52832 using SPI Communication.
Psuedo code of code snippet is :
<<Place the snippet here>>
Expected:
After nrf_spi_transfer with accelerometer
1. spi event handler is processed
2. SPIXferdone flasg set to true
3. Come out from while loop
Actual:
Struggled in while loop
Observation:
It looks like SPI event handler is not processed.
so SPIXferdone not updated to true and Struggled in while loop
Please guide me what was the cause of issue
Please guide us
  • SRINI
    SpiXferDone = true;
    acc_cs_low();
    nrf_drv_spi_transfer()
    while (!SpiXferDone) { printf("spi transfer is in progress"); }
    acc_cs_high();
    Expected:
    Actual:
    Observation:
    Please guide us
    SpiXferDone = true;
    acc_cs_low();
    acc_cs_high();
    I assume that the snippet you shared is what's being done in main(). Is the application actually entering the while loop? As you've shared it will not enter it because SpiXferDone is not false initially, unless you set it to false in acc_cs_low(). It would be much easier to help you if you actually shared your code.
    regards
    Jared
  • Jared,
    Thanks for the response.
    Sorry for missed portion of code.
    code snippet is:
    SPI Event Handler:
    void spi_event_handler(nrf_drv_spi_evt_t const * p_event, void *p_context)
    SpiXferDone = true;
    Application Code:
    SpiXferDone = false;
    acc_cs_low();
    nrf_drv_spi_transfer();
    based on above snippet,
    Expected:
    2. SPIXferdone flag is set to true
    Actual:
    Entered into while loop
    but Struggled in while loop
    Observation:
    It looks like spi event handler is not processed.
    Please guide us.
    • Where do you initialize the spi driver?
    • Could you check what the init function returns?
    • Do you see any activity on the SPI lines?
    regards
    Jared
