CPU halted for about 100 ms when FDS writing in background ?
On a device that is pretty sensitive to lag (with a display and HW drivers), I observe sometimes some lags of about 100 ms.
I tried to disable some part of code to see what component could cause this lag and I found that if I stopped writing to FDS, I remove these lags !
By reading the nrf52840 datashet, I saw "The CPU is halted if the CPU executes code from the flash while the NVMC is writing to the flash.", which is 85 ms so could be exactly the root cause of what I observe.
So my questions are:
  1. Is it possible that FDS write can causes lags of about 85 ms ? (I use FDS from SDK 15.2)
  2. And if yes, any Idea to protect (suspend FDS) to prevent these lags into some part of code, sensitive to timing ?
I also read from another post that this CPU halted for 85 ms could also result to miss some I/O interrupts. This sound a little scary to me.
Anyone else experiencing similar issues ?
