在构建轻型switch客户端时,遇到以下错误
我使用SDK17.0.2,对于网格4.2.0,可以帮我吗?
谢谢。
谢谢。
Try to use the v16.0.0 of the nRF5 SDK.
This build error is related to the nRF5 SDK v17.0.2. I had the same issue with this SDK.
thanks!I've got the solution
The following files need to be modified
1. In the flash_placement.xml file:
MemorySegment name must be changed from "RAM" to "RAM1":
<MemorySegment name="RAM1" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)">
2. In the .emProject file:
In "linker_section_placements_segments" you must refer to "RAM1", replacing "RAM":
linker_section_placements_segments="FLASH RX 0x0 0x100000;RAM1 RWX 0x20000000 0x40000"
that solved my problem.
That's good!
Thank you
