Not able to read analog value from a Proteus III board (nrf52840 SoC)
I am working on a Proteus III module which work with a nrf52840 SoC. I am using nrf52840 DK to test and develop code and at the same time testing the codes in the Proteus III module by flashing the firmware using SWD interface. The firmware is flashed on to Proteus III BLE Evaluation board. I was able to flash in few example projects and was able to successfully use the GPIO pins and BLE in the Proteus III Evaluation board. I am also sending analog signals from an anlog pin to a central (Developed mobile phone app) successfully on both NRFDK and Proteus Evaluation board. However, I am facing difficulties in sending correct analog readings from Proteus III Evaluation board. For debugging purpose, I have enabled the RTT and hence visualizing the signal through a serial monitor.
I am able to read correct analog value from P0.02 (Analog Pin) of NRF52840 DK. When I try to read the value from the Proteus III evaluation board, I am always getting values around 3400+ (using a 12 bit SAADC). Connecting this analog pin to GND and VDD does not change the value in serial monitor.
Here is a screenshot of the serial monitor reading the value from analog pin of Proteus III Evaluation Board.
The Custom board does not contains an external low frequency clock. In order to run Nordic examples I have made all the required changes in the sdk.confic file suggested by the manufactures of the Proteus III module. I have also included proper board files for pin mapping. I am also using the internal DCDC voltage converter instead of LDO as suggested by the Proteus III manufactures. Kindly note that I am able to use digital pins and BLE features on Proteus board successfully.
Here are some hardware descriptions and important notes from the documentations of the Proteus III evaluation board which I found relevant to this issue.
Proteus III PinoutThis is the Pinout of Proteus III.
Kindly note that the BOOT pin is used as an anlog pin. This is shown in the layout of the Proteus III evaluation board.
Evaluation board Layout
Please refer this document to see the complete layout of the board (Page 19) and other details if required.
In order to clarify, I am using BOOT pin as mentioned in the layout above. (BOOT -> AIN0 / P0.02).
An internal pull up register is connected with this pin and this explains the reading of 3400+ value of ADC as mentioned earlier.
The firmware came with the Proteus III module might had configurations for BOOT Pin but I have erased the whole chip and I have written my own firmware. So this wouldn't be a problem to use BOOT pin as an analog Pin right?
I am not understanding why the pin is not changing its analog value. Even when the pin is provided with GND and VDD, its output in serial monitor remains same. Quite confusing.
1. Included proper pin mapping (Board Files).
2. Added required configurations to use internal HFCLK.
3. Digital pins and BLE working properly with the nordic examples and custom Firmware.
I dont know what I am missing out. I would appreciate any valuable feedback on this issue. In order to makes much more clear, kindly refer the documents  in this page if required.
Thank you in advance.
    I see that you've included the custom board file but where do you tell the application to use that instead of the nRF52840 standard board file?
    "To add support for a custom board, you must create a custom board support file with the name custom_board.h. This file must be located in a directory in the Include path. You can then select to use the custom board by adding the define statement #define BOARD_CUSTOM".
  • Hai Jared,
    If you go in the "boards.h" header file which is included in the program, you can see that the custom board ("ProteusIII.h") file is included as you have mentioned above. I have linked the Proteus III hardware instead of BOARD_PCA10056 in PREPROCESSOR -> SET PREPROCESSOR DEFINISION according to this post. Is there a need to add the step you mentioned even after adding the board in the preprocessor?
    If so, can you refer some links on how to do it.
    I am certain that the compiler is already linked with the board files since I am able to provide digital signals to different pins in the custom board using the same application and header file.
    Thank you
    regards,
    Adarsh
  • Edit:
    This is a bug:
        nrf_saadc_channel_config_t channel_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_PIN_BOOT);
    It uses 2 as a parameter, which is AIN1 not AIN0. Change to this:
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    See the enum:
    #define SAADC_CH_PSELP_PSELP_AnalogInput0 (1UL) /*!< AIN0 */
    #define SAADC_CH_PSELP_PSELP_AnalogInput1 (2UL) /*!< AIN1 */
     * @brief Input selection for the analog-to-digital converter.
    typedef enum
        NRF_SAADC_INPUT_DISABLED = SAADC_CH_PSELP_PSELP_NC,           ///< Not connected.
        NRF_SAADC_INPUT_AIN0     = SAADC_CH_PSELP_PSELP_AnlogInput0, ///< Analog input 0 (AIN0).
        NRF_SAADC_INPUT_AIN1     = SAADC_CH_PSELP_PSELP_AnalogInput1, ///< Analog input 1 (AIN1).
        NRF_SAADC_INPUT_AIN2     = SAADC_CH_PSELP_PSELP_AnalogInput2, ///< Analog input 2 (AIN2).
        NRF_SAADC_INPUT_AIN3     = SAADC_CH_PSELP_PSELP_AnalogInput3, ///< Analog input 3 (AIN3).
        NRF_SAADC_INPUT_AIN4     = SAADC_CH_PSELP_PSELP_AnalogInput4, ///< Analog input 4 (AIN4).
        NRF_SAADC_INPUT_AIN5     = SAADC_CH_PSELP_PSELP_AnalogInput5, ///< Analog input 5 (AIN5).
        NRF_SAADC_INPUT_AIN6     = SAADC_CH_PSELP_PSELP_AnalogInput6, ///< Analog input 6 (AIN6).
        NRF_SAADC_INPUT_AIN7     = SAADC_CH_PSELP_PSELP_AnalogInput7, ///< Analog input 7 (AIN7).
        NRF_SAADC_INPUT_VDD      = SAADC_CH_PSELP_PSELP_VDD           ///< VDD as input.
    } nrf_saadc_input_t;
    Maybe try some explicit setting in saadc_init() like this (removes the bbug):
            //NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_PIN_BOOT);
            .resistor_p = NRF_SAADC_RESISTOR_DISABLED,
            .resistor_n = NRF_SAADC_RESISTOR_DISABLED,
            .gain       = NRF_SAADC_GAIN1, //1_6,
            .reference  = NRF_SAADC_REFERENCE_INTERNAL,
            .acq_time   = NRF_SAADC_ACQTIME_40US,
            .mode       = NRF_SAADC_MODE_SINGLE_ENDED,
            .burst      = NRF_SAADC_BURST_DISABLED,
            .pin_p      = NRF_SAADC_INPUT_AIN0,
            .pin_n      = NRF_SAADC_INPUT_DISABLED
    Edit: Just a thought, is the SoftDevice enabled? If so PPI changes have to use the sd functions:
    uint32_t 	sd_ppi_channel_enable_get (uint32_t *p_channel_enable)
     	Get PPI channel enable register contents. More...
    uint32_t 	sd_ppi_channel_enable_set (uint32_t channel_enable_set_msk)
     	Set PPI channel enable register. More...
    uint32_t 	sd_ppi_channel_enable_clr (uint32_t channel_enable_clr_msk)
     	Clear PPI channel enable register. More...
    uint32_t 	sd_ppi_channel_assign (uint8_t channel_num, const volatile void *evt_endpoint, const volatile void *task_endpoint)
     	Assign endpoints to a PPI channel. More...
    uint32_t 	sd_ppi_group_task_enable (uint8_t group_num)
     	Task to enable a channel group. More...
    uint32_t 	sd_ppi_group_task_disable (uint8_t group_num)
     	Task to disable a channel group. More...
    uint32_t 	sd_ppi_group_assign (uint8_t group_num, uint32_t channel_msk)
     	Assign PPI channels to a channel group. More...
    uint32_t 	sd_ppi_group_get (uint8_t group_num, uint32_t *p_channel_msk)
     	Gets the PPI channels of a channel group. More...
  • This is a bug:
    See edit above
    Yes it was it. A wrong Pin mapping. The files came along with the product was wrong. Thank you so much. Now it is working as expected.
    regards,
    Adarsh
