Hi Dev team,
I am working with a nRF9160DK board. I am currently getting an error while building my SPM folder in : C:\Users\adeel\ncs\v1.3.0\nrf\samples\nrf9160\spm.
The error is as follows: #include expects "FILENAME" or <FILENAME>
The log file is as follows:
Building ‘C:/Users/adeel/ncs/v1.3.0/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’ Building ‘C:/Users/adeel/ncs/v1.3.0/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/misc/generated/subsystems.json’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/zephyr_generated_headers’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’ Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_zephyr’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/libzephyr.a’ from solution ‘build’ in configuration ‘Common’ Building ‘C:/Users/adeel/ncs/v1.3.0/zephyr/misc/empty_file.c’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_..__modules__hal__nordic’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_..__nrf__drivers__hw_cc310’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_..__nrf__lib__fatal_error’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_..__nrf__subsys__fw_info’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m__cmse’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m__mpu’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m__tz’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_arch__common’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_drivers__gpio’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_drivers__serial’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_kernel’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_lib__libc__minimal’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_lib__posix’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_mbedcrypto_cc310_noglue’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_mbedcrypto_cc310’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_mbedcrypto_shared’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_mbedtls_base_vanilla’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_soc__arm__common__cortex_m’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/linker.cmd’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/CMakeFiles/linker_script_target’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/linker_script_target’ from solution ‘build’ in configuration ‘Common’ Building ‘cmake_object_order_depends_target_zephyr_prebuilt’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/arch/common/libarch__common.a’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/libarch__arm__core__aarch32__cortex_m__mpu.a’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/libarch__arm__core__aarch32__cortex_m__tz.a’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/lib/libc/minimal/liblib__libc__minimal.a’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/lib/posix/liblib__posix.a’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/drivers/gpio/libdrivers__gpio.a’ from solution ‘build’ in configuration ‘Common’ Building ‘zephyr/drivers/serial/libdrivers__serial.a’ from solution ‘build’ in configuration ‘Common’ Building ‘modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a’ from solution ‘build’ in configuration ‘Common’ Building ‘modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a’ from solution ‘build’ in configuration ‘Common’ Building ‘modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a’ from solution ‘build’ in configuration ‘Common’ Building ‘modules/nrfxlib/nrf_security/src/mbedtls/cc310/libmbedcrypto_cc310_noglue.a’ from solution ‘build’ in configuration ‘Common’ 1> Compiling ‘ecjpake.c’ 1> C:/Users/adeel/ncs/v1.3.0/mbedtls/library/ecjpake.c:30:10: error: #include expects "FILENAME" or <FILENAME> Build failed
I could not understand the error and was looking for some guidance to solve it.
Adeel.
